G32 Error:´´ Z probe was not triggered during probing move´´
hey, when doing the G32 command, the BL Touch stops at the first probing point. After doing this, its just stays in this position.
BL Touch is working find. M401/ M402 + Z probe is working.Duet 3
g32
Status
Idle
Mode: FFF
Tool Position
X
35.0
Y
35.0
Z
-12.50
Extruder Drives
Drive 0
0.0
Drive 1
0.0
Drive 2
0.0
Speeds
Requested Speed
0 mm/s
Top Speed
0 mm/s
Sensors
Vin
24.0 V
V12
12.2 V
MCU Temperature
46.0 C
Z-Probe
0
Tools
Extra
Control All
Tool Heater Current Active Standby
Tool 0
T0 - Load Filament Heater 1
off 26.8 C
0
0
Bed Heater 0
fault 26.6 C
70
0
Temperature Chart
Macros Directorysys
0:/macros/sys/config.g
; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit); General preferences
M550 P"Duet 3" ; set printer name; Drives
M569 P0.1 S1 ; physical drive 0.1 goes forwards
M569 P0.2 S1 ; physical drive 0.2 goes forwards
M569 P0.3 S1 ; physical drive 0.3 goes forwards
M569 P0.4 S1 ; physical drive 0.4 goes forwards
M569 P0.5 S1 ; physical drive 0.5 goes forwards
M569 P1.0 S1 ; physical drive 1.0 goes forwards
M569 P1.1 S1 ; physical drive 1.1 goes forwards
M569 P1.2 S1 ; physical drive 1.2 goes forwards
M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E1.0:1.1:1.2 ; set drive mapping
M350 X16 Y16 Z16 E16:16:16:16:16:16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z1600.00 E1600.00:1600.00:1600.00:92.70:92.70:92.70 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00:120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E3600.00:3600.00:3600.00:1200.00:1200.00:1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z40.00 E250.00:250.00:250.00:250.00:250.00:250.00 ; set accelerations (mm/s^2)
M906 X1200 Y1200 Z3000 E3000:3000:3000:1200:1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X700 Y700 Z800 S0 ; set axis maxima; Endstops
M574 X2 S1 P"!io3.in" ; configure active-high endstop for high end on X via pin !io3.in
M574 Y2 S1 P"!io0.in" ; configure active-high endstop for high end on Y via pin !io0.in; Z-Probe
M558 P9 C"^io4.in" H15 F120 T1200 ; set Z probe type to bltouch and the dive height + speeds
M950 S0 C"^io4.out" ; create servo pin 0 for BLTouch
G31 P500 X-20 Y-20 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:650 Y15:650 S60 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M307 H1 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
M143 H0 S90 ; set temperature limit for heater 0 to 90C
M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
M106 P0 S0.8 H-1 ; set fan 0 value. Thermostatic control is turned off
M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
M950 F2 C"out8" Q500 ; create fan 2 on pin out8 and set its frequency
M106 P2 S1 H T45 ; set fan 2 value. Thermostatic control is turned on; Tools
M671 X-12:92:92:-12 Y185:185:615:615 S2.5; Miscellaneous
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on powerdeploy----------------------------
; deployprobe.g
; called to deploy a physical Z probe
M280 P0 S10 ; deploy BLTouchretract.g--------------------------------
; retractprobe.g
; called to retract a physical Z probe
M280 P0 S90 ; retract BLTouchhomez.g-------------------------
; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v3.1.3 on Thu Jun 25 2020 00:21:12 GMT+0200 (Mitteleuropäische Sommerzeit)
G91 ; relative positioning
G90 ; absolute positioning
G1 X15 Y15 F6000 ; go to first probe point
G30 ; home Z by probing the bedDuet 3
g32
Status
Idle
Mode: FFF
Tool Position
X
35.0
Y
35.0
Z
-12.50
Extruder Drives
Drive 0
0.0
Drive 1
0.0
Drive 2
0.0
Speeds
Requested Speed
0 mm/s
Top Speed
0 mm/s
Sensors
Vin
24.0 V
V12
12.1 V
MCU Temperature
46.0 C
Z-Probe
0
Tools
Extra
Control All
Tool 0
off 26.8 C
0
0
Bed Heater 0
fault 26.6 C
70
0
Temperature Chart
Macros Directorysys
0:/macros/sys/bed.g
; bed.g
; Called using G32
; Called to perform True Autolevel using 4-point probe
; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit)M561 ; clear any bed transform
G29 S3; Clear bed height map
; Probe 4-point
M401 ; Deploy probe - deployprobe.g
G30 P0 X150 Y135 Z-9999 ; Front Right
G30 P1 X550 Y135 Z-9999 ; Front Left
G30 P2 X550 Y565 Z-9999 ; Back Left
G30 P3 X150 Y565 Z-9999 S4 ; Back Right
M402 ; Retract Probe - retractprobe.g=== Diagnostics ===
RepRapFirmware for Duet 3 MB6HC version 3.01-RC9 running on Duet 3 MB6HC v1.01 or later
Board ID: 08DJM-956L2-G43S8-6J9D0-3S46R-9U2ADUsed output buffers: 1 of 40 (15 max)
@barbarossa-cologne said in G32 Error:´´ Z probe was not triggered during probing move´´:
; bed.g
; Called using G32
; Probe 4-point
M402 ; Retract Probe - retractprobe.gRemove the M401 and M402 and try again.
I you would be so kind as to use the </> tag to enter you .g files and other similar code. It makes it easier as the contents of each file can be wrapped in the tag and appears in it's own scrolling region.
As to your problem. Remote the M401 and M402 commands from your bed.g file.
For a BLTouch, at least, the firmware invokes those commands as needed.
See if it works now.
@fcwilt
ok. I´m sry
@fcwilt
Removing M401- M402 is not working
But it works for homeall? Or a single g30?
@Phaedrux
yes... but only one time. z probe is triggering but then flashing and not moving any more (m402/m401). when I reconnect the BL is working fine... for one time.
When using G32 after the first probe happnes the same but with -->´´z-probe-was-not-triggered-during-probing-move´´
So if you reset the firmware, home everything, move to the center of the bed and do a single G30 the probe pin drops, retracts but then begins to flash?
Is that correct?
@fcwilt
hmm yes... retract --> bl touches the bed --> bed stops as usual -- flashing and no deploy.
after reconnect the bl - touch. m401 / m402 are working normally
So your problem is solved?
@fcwilt
no
after the flashing begins I have to reconnect the Bl Touch to do a sinlge probe.
everytime.....
@barbarossa-cologne
retract --> bl touches the bed --> bed stops as usual -- flashing and no deploy --> reconnect cable --> working fine till the first probe -->
@barbarossa-cologne
retract --> bl touches the bed --> bed stops as usual -- flashing and no deploy --> reconnect cable --> working fine till the first probe -->When you say "retract" do you mean the pin is DOWN or UP?
If the BLTouch has a problem when probing it starts to flash and nothing more can be done with it until the error condition is reset.
Executing a M280 P0 S160 command should clear the error condition.
@fcwilt
retract means the pin goes down.
hmm ok
what can it be?
M280 P0 S160 is working.. now the question is what makes this problem ´..
@fcwilt
hmm ok
what can it be?OK we have a word problem.
DEPLOY means lower the pin. RETRACT means raise the pin.
So the M401 command should lower the pin and the M402 command should raise the pin
Is that happening?
@fcwilt
ok I´m sry for that..
yes. It works (till the first probe point touches the Bl)
@fcwilt
yes. It works (till the first probe point touches the Bl)SO if the printer is just sitting there doing nothing and the BLTouch is far enough away from the bed so that the pin won't touch if it drops can you repeatedly raise and lower the pin using M401/M402 commands without any errors?
@fcwilt
yes..
@fcwilt
yes..OK good.
When the problem occurs is the pin hitting the bed when it tries to drop?
IF that happens it will cause an error.
The pin needs to be all the way down BEFORE the bed moves to touch the pin.
@fcwilt
No. There is almost 1cm between the pin and the bed.
@fcwilt
No. There is almost 1cm between the pin and the bed.SO the pin drops, does NOT touch the bed before it should, the bed moves towards the pin, touches the pin and THEN the error occurs?
@fcwilt exactly
@barbarossa-cologne
and doing g32 it also comes to --: ´´ Z probe was not triggered during probing move´´
not when doing sinlge g30
