G32 Error:´´ Z probe was not triggered during probing move´´
@Phaedrux said in G32 Error:´´ Z probe was not triggered during probing move´´:
that is an old issue.... now it´s not possible to start z probe. the message ´´Error: Failed to enable endstops´´ is shown.....
ok.... to all these questions. everything was working ONLY the true auto level not.
please give me time. I haven´t expected that much work again... -
Spam???????
@barbarossa-cologne
I´m sorry but I took a look in the configuration tool via the systems page in the DWC and decided that I just posting the g.codes that you need exactly. Because everything was working or IS working except the Bl-Touch / Z Probe.
After one month having the same problem ONLY with the BL I just want to try fixing it like this. I hope its ok.
Time is rare....; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Duet 3" ; set printer name ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P0.3 S1 ; physical drive 0.3 goes forwards M569 P0.4 S1 ; physical drive 0.4 goes forwards M569 P0.5 S1 ; physical drive 0.5 goes forwards M569 P1.0 S1 ; physical drive 1.0 goes forwards M569 P1.1 S1 ; physical drive 1.1 goes forwards M569 P1.2 S1 ; physical drive 1.2 goes forwards M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E1.0:1.1:1.2 ; set drive mapping M350 X16 Y16 Z16 E16:16:16:16:16:16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z1600.00 E1600.00:1600.00:1600.00:92.70:92.70:92.70 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00:120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E3600.00:3600.00:3600.00:1200.00:1200.00:1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z40.00 E250.00:250.00:250.00:250.00:250.00:250.00 ; set accelerations (mm/s^2) M906 X1200 Y1200 Z3000 E3000:3000:3000:1200:1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X700 Y700 Z800 S0 ; set axis maxima ; Endstops M574 X2 S1 P"!io3.in" ; configure active-high endstop for high end on X via pin !io3.in M574 Y2 S1 P"!io0.in" ; configure active-high endstop for high end on Y via pin !io0.in ; Z-Probe M558 P9 C"io4.in" H10 F200 T1800 ; set Z probe type to bltouch and the dive height + speeds M950 S0 C"io4.out" ; create servo pin 0 for BLTouch G31 P25 X-20 Y-20 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X15:650 Y15:650 S200 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H1 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S90 ; set temperature limit for heater 0 to 90C M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency M106 P0 S0.8 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off M950 F2 C"out8" Q500 ; create fan 2 on pin out8 and set its frequency M106 P2 S1 H T45 ; set fan 2 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined M671 X-12:92:92:-12 Y185:185:615:615 S2.5 ; Miscellaneous M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power deploy---------------------------- ; deployprobe.g ; called to deploy a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit) M280 P0 S10 ; deploy BLTouch retract.g-------------------------------- ; retractprobe.g ; called to retract a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit) M280 P0 S90 ; retract BLTouch homez.g------------------------- ; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Thu Jun 25 2020 00:21:12 GMT+0200 (Mitteleuropäische Sommerzeit) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning G1 X15 Y15 F6000 ; go to first probe point G30 ; home Z by probing the bed
; bed.g ; Called using G32 ; Called to perform True Autolevel using 4-point probe ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit) M561 ; clear any bed transform G29 S2; Clear bed height map ; Probe 4-point G30 P0 X150 Y135 Z-9999 ; Front Right G30 P1 X550 Y135 Z-9999 ; Front Left G30 P2 X550 Y565 Z-9999 ; Back Left G30 P3 X150 Y565 Z-9999 S4 ; Back Right
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit) G91 ; relative positioning G1 H2 Z15 F2400 ; lift Z relative to current position G1 H1 Z-805 F1200 ; move Z down until the endstop is triggered G92 Z0 ; set Z position to axis minimum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z15 F40 ; lift Z relative to current position ;G90 ; absolute positioning
this are codes from the systems page.... NOT a macro. I´m sorry for beeing stupid in this thread and posting macros. I was tired after working much.
I hope somebody can help me in this way -
@barbarossa-cologne you have posted two homez.g files; one on the end of the config.g (also deploy and retract on there), and one separate. Which is the right one? One uses G30 to home Z, the other uses a maximum Z endstop, which isn’t defined in config.g.
@droftarts
the G30 configuration should be the rigth one. Should I copy that to the home z file?
Or how should I handle it? -
@barbarossa-cologne does your config.g contain deploy.g, retract.g and homez.g? These should not be in config.g, they should be separate files in the sys folder, which probably already exist. The homeall.g is run when you press the “Home all” button in DWC, and homez.g is run if you press the “home Z” button, so it is important that both these files are correct. Similarly, pressing “Home X” or “Home Y” runs homex.g or homey.g respectively. Post your homeall.g file, too.
So yes, copy the G30 version to the homez.g and homeall.g files, and also update the deploy.g and retract.g files, then delete from config.g everything after the “Miscellaneous” section.
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit) G91 ; relative positioning G1 H2 Z15 F2400 ; lift Z relative to current position G1 H1 X805 Y805 F1200 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X-5 Y-5 F2400 ; go back a few mm G1 H1 X805 Y805 F360 ; move slowly to X and Y axis endstops once more (second pass) G1 H1 Z-805 F360 ; move Z down stopping at the endstop G90 ; absolute positioning G92 Z0 ; set Z position to axis minimum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z15 F40 ; lift Z relative to current position ;G90 ; absolute positioning
@droftarts
G32 is working perfect. Also the normal Z probe with the BL Touch!!!
Thank you a lot!!!! -
This post is deleted! -
@droftarts
now. when I start printing it comes to this error.10.8.2020, 19:25:13 Error: G0/G1: insufficient axes homed
; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Duet 3" ; set printer name ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P0.3 S1 ; physical drive 0.3 goes forwards M569 P0.4 S1 ; physical drive 0.4 goes forwards M569 P0.5 S1 ; physical drive 0.5 goes forwards M569 P1.0 S1 ; physical drive 1.0 goes forwards M569 P1.1 S1 ; physical drive 1.1 goes forwards M569 P1.2 S1 ; physical drive 1.2 goes forwards M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E1.0:1.1:1.2 ; set drive mapping M350 X16 Y16 Z16 E16:16:16:16:16:16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z1600.00 E1600.00:1600.00:1600.00:92.70:92.70:92.70 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00:120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E3600.00:3600.00:3600.00:1200.00:1200.00:1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z40.00 E250.00:250.00:250.00:250.00:250.00:250.00 ; set accelerations (mm/s^2) M906 X1200 Y1200 Z3000 E3000:3000:3000:1200:1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X700 Y700 Z800 S0 ; set axis maxima ; Endstops M574 X2 S1 P"!io3.in" ; configure active-high endstop for high end on X via pin !io3.in M574 Y2 S1 P"!io0.in" ; configure active-high endstop for high end on Y via pin !io0.in ; Z-Probe M558 P9 C"io4.in" H10 F200 T1800 ; set Z probe type to bltouch and the dive height + speeds M950 S0 C"io4.out" ; create servo pin 0 for BLTouch G31 P25 X-20 Y-20 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X10:600 Y10:600 S200 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H1 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S90 ; set temperature limit for heater 0 to 90C M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency M106 P0 S0.8 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off M950 F2 C"out8" Q500 ; create fan 2 on pin out8 and set its frequency M106 P2 S1 H T45 ; set fan 2 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined M671 X-19.5:99.5:99.5:-19.5 Y110:110:540:540 S2.5 ; Miscellaneous M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power
home all-- >
@fcwilt
It was already homed... -
@barbarossa-cologne said in G32 Error:´´ Z probe was not triggered during probing move´´:
This is not correct for homing with the probe.
This part should be replaced with.
G90 ; absolute positioning G1 X150 Y150 F6000 ; go to first probe point G30 ; home Z by probing the bed
@Phaedrux
thanks!!!Richard
