    Firmware update failure..
    Firmware installation
    2.1k
    • Helensdadundefined
      Helensdad
      Hi, I have attempted to update my firmware from 1.0.3 to 1.0.7 and failed miserably, so much so that I can do nothing, I can't connect via USB, it is as if the SD card doesn't exist any more. If I check the card contents on my computer they are all there, I can read and write to the card but when it is plugged into the board and I try to check the contents using the paneldue, all it says is 'files on card 0'. The top right of the paneldue displays 'connecting', which I have never seen before. I have not formatted the card and it is using the FAT32 file system. I am at a loss now and hope I haven't trashed the entire board. I am using the board on a Workbee CNC machine and the firmware versions mentioned above are for the Duet WiFi/Workbee... Incidentally, if I switch on without the card plugged in, it still says 'files on card 0'Paneldue 2.jpg Paneldue 1.png
      droftartsundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • A Former User?
        A Former User
        @Helensdad said in Firmware update failure..:
        are those workbee version numbers?
          droftarts administrators @Helensdad
          @Helensdad the PanelDue isn’t connecting. Are there any lights on on the Duet? See https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
          I think most likely you have erased the firmware and you’ll need to use Bossa to flash new firmware to it. See https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3
          Helensdadundefined 1 Reply Last reply Reply Quote 0
            Phaedrux Moderator @Helensdad
            What exactly did you do to update?
              Helensdad @Phaedrux
              @Phaedrux I followed Ooznests procedure. I sort of have it working now, I can connect via access point on my laptop, but after downloading the combined firmware.bin file, I tell it to update, it then drops the Wifi connection and reverts back to 1.0.3...
                Helensdad @droftarts
                @droftarts board lit up, works via wifi access point but not with Paneldue...
                  Please send M115 to get a firmware version. 1.0.3 and 1.0.7 must be oozenest provided files as they don't match the Duet RRF versions.
                    Helensdad @Phaedrux
                    @Phaedrux yes, they are the Ooznest provided files for the Workbee CNC machine.
                      Curious to see what M115 reports.
                      What firmware version is on the PanelDue? Can check in the settings page.
                        Helensdad @Phaedrux
                        @Phaedrux yat reports version 2. 02, I think, june 2019. Not near machine or computer at moment...
                          Helensdad @Helensdad
                          @Helensdad Paneldue still won't work properly, completely blank now....
                            Does it still receive power?
                            How is it wired to the duet? 4-wire or ribbon cable?
                              dc42 administrators @Helensdad
                              Try updating the PanelDue firmware through its USB port. You may need to disconnect the PanelDue from the Duet for the firmware update to succeed.
                                Helensdad @dc42
                                @dc42 I have erased and reinstalled the firmware, I have been using the 4 wire cable for about 11 months, since I got it basically. I have just tried the ribbon cable with the same result. It lights up, all the buttons are there but don't have any effect. It I touch the card icon it says files on card 0. The settings tab works and I can invert, change colour scheme, contrast volume etc but it won't communicate with the Duet board. In the top right corner of the screen it says 'connecting' but it doesn't connect...
                                  What firmware version does it show on the PanelDue settings tab?
                                  It looks like the workbee firmware is based on RRF 2.02.
                                    Helensdad @Phaedrux
                                    @Phaedrux 1.24
                                      Have you ever updated the paneldue firmware? 1.24 is the latest released in April.
                                        Helensdad @Phaedrux
                                        @Phaedrux Yes, I updated it this afternoon via USB...
                                          Ah I see, and no change obviously.
                                          I know you're using the oozenest releases, but could you try updating the firmware to the official 2.05.1 release just to see if there's a change.
                                          Also, could you link to the oozenest info and releases? I did a quick googling but wasn't able to find anything.
                                            Helensdad
                                            Here is the link to Ooznest firmware, I will trt the Duet firmware tomorrow, I have a job running now. All works ok from web interface, it even reads the card. It is just the Paneldue I have to sort now....
                                            https://learn.ooznest.co.uk/Wiki/WorkBee_Firmware_Releases
