Firmware update failure..
Firmware installation
2.0k
  • undefined
    Normally I would suggest to replace the 4-wire cable with a new one, but you've already tried the ribbon cable option with the same result.
    Which version of PanelDue is it? Which PanelDue firmware did you use to flash it? Perhaps there was a mismatch.
    undefined 1 Reply Last reply 4 Aug 2020, 22:10 Reply Quote 0
    • undefined
      Phaedrux Moderator @Helensdad
      @Helensdad said in Firmware update failure..:
      after downloading the combined firmware.bin file, I tell it to update, it then drops the Wifi connection and reverts back to 1.0.3...
      This part makes me think that the files might not be placed in the /sys folder or that there might be other files there or files not named correctly and so an older file is being used.
      Can you provide a screenshot of the SD card directory structure?
      undefined 1 Reply Last reply 4 Aug 2020, 22:17 Reply Quote 0
      • undefined
        Helensdad @Phaedrux
        @Phaedrux said in Firmware update failure..:
        Which version of PanelDue is it? Which PanelDue firmware did you use to flash it? Perhaps there was a mismatch. It is a Paneldue 7i and I used 1.24 for 7i downloaded from your repository...
        • undefined
          Helensdad @Phaedrux
          • undefined
            Ok, so your screen shot of the /sys folder shows the bin file is actually a ._ file which is a metadata file used by MacOS and is normally hidden. So at some point there was a firmware bin file, but there isn't at the moment.
            I took a look at the workbee docs and I would try downloading the 1.0.7 full install zip, extracting it, and then trying to upload the combined firmware bin file to the /sys folder in DWC. It should detect it and update the firmware.
            https://ooznest.co.uk/wp-content/uploads/2019/11/WorkBee-Firmware-v1.0.7.2-Full.zip
            Maybe it helps, maybe not, but at least we can confirm that 1.0.7 installed correctly.
            undefined 1 Reply Last reply 5 Aug 2020, 18:38 Reply Quote 0
            • undefined
              Helensdad @Phaedrux
              @Phaedrux I have just connected the Paneldue to my Maestro board and get the same problem, when I look at the card contents, Paneldue says files on card 0, nothing works except foe settings....
              • undefined
                Alright, well that narrows it down to the PanelDue at least.
                I would try updating the firmware on the PanelDue again. Redownload the correct file for the 7i and check the file size.
                Hopefully it's just a case of a bad flash.
                https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
                • undefined
                  Helensdad
                  I have uprated the firmware again and tried on Duet 2 WiFi and Duet Maestro to no avail. I even used a brand new good quality USB lead. I bought it on May 24th last year so out of warranty. Do you know if it is repairable?
                  undefined 1 Reply Last reply 6 Aug 2020, 10:13 Reply Quote 0
                  • undefined
                    droftarts administrators @Helensdad
                    @Helensdad have a close look at the 4-wire cable. It’s possible there’s a poor contact, or wire pulled out of a crimp. If you have a multimeter, check resistance of each wire, should be less than 0.1ohm.
                    • undefined
                      Helensdad
                      Resistance all below 0.1 Ohm, I get the same problem with the 10 way ribbon cable as well...
                      • undefined
                        Just to clarify: the PanelDue screen lights up and shows all the buttons etc. but remains stuck at "Connecting" - yes?
                        • undefined
                          Helensdad
                          Yes, that is correct, tried on 2 Duet boards, updated firmware twice, checked resistance of each conductor on 4 way cable and tried 10 way ribbon cable..
                          • undefined
                            The usual causes of failure to connect:
                            1. Using RRF 3.1 or later, and not having the correct M575 command in config.g.
                            2. Mismatched baud rates. Check that both ends are set to 57600, in M575 on the Duet and on the Setup page of PanelDue.
                            3. Faulty cable, either a bad crimp or Tx/Rx wires crossed. Check the that wire colours at the 2 ends of the 4-pin cable are reversed from one end to the other.
                            • undefined
                              PS - it's occurred to me that I may not have tested connecting a PanelDue to a Maestro with recent firmware, because it's an unusual combination. So if you are using RRF 3.1.x then it could be a firmware issue.
                              undefined 1 Reply Last reply 6 Aug 2020, 16:29 Reply Quote 0
                              • undefined
                                Helensdad @dc42
                                @dc42 Well, I feel a bit daft now, changed baud rate to 5700 and all is well! If my Duet has incorrect baud rate set could that be the cause of my Firmware problem?
                                undefined undefined 2 Replies Last reply 6 Aug 2020, 17:35 Reply Quote 0
                                • undefined
                                  dc42 administrators @Helensdad
                                  What firmware problem is that? I suggest you start a new thread about that unless you already have.
                                  undefined 1 Reply Last reply 8 Aug 2020, 06:35 Reply Quote 0
                                  • undefined
                                    Helensdad @dc42
                                    @dc42 ok, apologies, I thought the two problems may have been interconnected as the paneldue went on the blink immidiately after the firmware update...interconnected
                                    • undefined
                                      If slowing down the baud rate that much has an improvement that might indicate an issue with cabling or interference. Either way, glad you got it sorted out.
                                      21 out of 38
