    Pause the print for the day.
    30
    1.3k
    • CarlBossonundefined
      CarlBosson
      I am new and I did look but did not see an answer to this question. I have a large print to do at work in Nylon, 37 plus hours. I do not want to run the printer at these temps all night with no one here to supervise. Is there a way to pause the print, power down, and restart the next morning? Thanks in advance for any help.
      There is no box!
      • T3P3Tonyundefined
        T3P3Tony administrators
        When you pause (at least on all recent firmware) a file called "ressurrect.g" is saves in the system directory.
        That also happens as part of the powerfail detection if that is enabled.
        So in either case you can use the power fail resume logic to restart the job at the point it was paused (either deliberately or when power fail was detect.
        Have a look at this page for some background,
        https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure
        I would test it before you try a long print job.
        Also note the caveats that its normally important to be able to home the printer with a print on the bed - that may require a modified homing regime depending on how you home.
        Also, since you can choose when to pause, I would pick a point in the middle of infil so any issues with lack of priming or over priming the nozzle will be lost in the infil.
        www.duet3d.com
          CarlBosson
          Thank you, I will test this tomorrow.
          There is no box!
          • fmaundefined
            fma
            But if you cool down the bed, isn't there a good chance that the part will come off?
            Frédéric
            wieman01undefined 1 Reply Last reply Reply Quote 0
            • wieman01undefined
              wieman01 @fma
              @fma said in Pause the print for the day.:
              Yes, it almost certainly will. Resuming from a cooled-down heated is - in my experience - virtually impossible.
              I don't think you will succeed if your heatbed is turned off.
              CarlBossonundefined 1 Reply Last reply Reply Quote 0
                CarlBosson
                I am using glass and Vision Miners "Nano polymer Adhesive". So far my prints come off easier when the bed is hot then when it is cold. In fact they recommend removing when hot.
                First test, the resume print command moved to the correct location in the print but seemed to extrude/prime a lot of filament before it restarted the print. I have made a few changes in the resurrect.g file and trying again. I will also do a trial in which I cool the bed to room temp to see if the print will say in place on the bed. Thanks for all the help. I will update later today or tomorrow.
                There is no box!
                  CarlBosson
                  The last line in my Config.g directory is as follows:
                  ;Automatic Power Saving
                  M911 S21.0 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ;Set voltage threasholds and actions to run on power loss
                  in my system directory I have added a "resurrect-prologue.g" directory and the contents of that directory are as follows:
                  M116; Wait for temp
                  G28; Home all
                  M83; Relative Extrusion
                  G1 E5 F3600; Undo Retraction
                  Upon power resume I use M916 to execute the resurrect-prologue.g file. The printer heats everything up, re homes all axis, returns the point in the print where it left off, then just dumps a huge amount of filament before restating the print. It acts like the undo retraction is set to 100mm. I have changed the undo retraction value from 5mm to 2mm but I do not see a change. What am I missing?
                  There is no box!
                  • fcwiltundefined
                    fcwilt @CarlBosson
                    @CarlBosson
                    Does your Z axis home to Z max?
                    Thanks.
                    Printers: A FT-5 with the 713 upgrade bits, a custom MarkForged style, a small Utilmaker style, a small CoreXY from kit and a E3D MS/TC setup. Various hotends. Using Duets (2 and 3) running 3.4.6
                      CarlBosson
                      Yes, during the axis homing cycle after start up. So the heats all come to temp, then all three axis home, next it tries to resume the print. This is where all the filament is pushed out.
                      There is no box!
                        CarlBosson
                        This is a photo of the over extrusion at restart.
                        There is no box!
                          CarlBosson
                          Could the M916 command be reading for some other location?
                          There is no box!
                            What firmware version are you using?
                              CarlBosson
                              2.02(RTOS) (2018-12-24b1)
                              There is no box!
                                dc42 administrators @CarlBosson
                                @CarlBosson said in Pause the print for the day.:
                                I suggest you upgrade to firmware 2.05.1. From the bug fixes section of the release notes for version 2.05 in the whatsnew file:
                                If a print that was sliced using absolute extrusion mode was resurrected, unwanted extrusion occurred just before the print was resumed
                                Absolute extrusion causes all manner of problems. Relative extrusion is safer.
                                  CarlBosson
                                  Thank you, How do I upgrade the firm ware? Is there so link you can share?
                                  There is no box!
                                    droftarts administrators @CarlBosson
                                    @CarlBosson See https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Usual_procedure
                                    Use files from https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1
                                    You will probably also want to update DWC and possibly your WiFi firmware. See https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_WiFi_firmware_or_DuetWebControl_files
                                    TronXY X5S with Duet 3 MB6HC and Roto toolboard : Cartesian bed-slinger with Duet 3 Mini 5+ WiFi and 1LC : RRP Fisher Delta v1 with Duet 2 Maestro : Polargraph with Duet 2 WiFi
                                      CarlBosson
                                      Thank you all of you for your help so far!
                                      I updated firmware only for now and all seems to be running well. I will conduct the first pause and power down test within the hour and if that goes well then a complete cold shutdown over night tonight and restart test. I will keep you updated. Again thanks!
                                      Carl
                                      There is no box!
                                        CarlBosson
                                        The first test was a success! Thanks for all the help! After the firmware update there was no excessive extrusion at restart after power loss.
                                        Today I will start a test print about an hour before we go home for the day. I will pause and power down like this morning, but I will not restart until tomorrow morning 7am EST. The printer will be at room temp when I get to work 75 deg F, this will test bed adhesion.
                                        There is no box!
                                          CarlBosson @wieman01
                                          @wieman01 Of course you were correct the print did come loose. But I am not finished 🙂 We have bead basted a glass build plate and also using Nano polymer. I will power down tonight and see what we get in the morning. 😳
                                          There is no box!
                                          wieman01undefined 1 Reply Last reply Reply Quote 2
                                          • wieman01undefined
                                            wieman01 @CarlBosson
                                            @CarlBosson Haha... Look forward to the results. You will figure it out, I am sure. But warping is quite a beast that you have to tame.
                                            CarlBossonundefined 2 Replies Last reply Reply Quote 0
