SOLVED Sending command to move Z moves X axis, (X commands also move X)
  • Hi there,
    I have a Cartesian set up, with dual motors on the X and also dual motors on Z. Single Y, single extruder.
    As the title says, every command that is sent to move the Z axis instead causes the X axis to move. Right now I can't get the Z to move at all. Commands to move X or Y do so normally.
    I'll post my config below, but I'm very flabbergasted. I've triple checked that my physical connections match where my M584 command maps them to. (M584 X0.0:0.1 Y0.2 Z0.3:0.4 E0.5)
    Things were working well(ish) before I switched the X motors from running off a single driver with spliced wires.
    Only thing I can think of is that I am only using one end stop for the dual X motors, could that roll over and cause this sort of problem?
    Config Below
    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Mar 05 2020 02:18:09 GMT+0000 (Greenwich Mean Time)
    M550 P"Duet 3" ; set printer name
    M569 P0.0 S1 ;
    M569 P0.1 S0 ;
    M569 P0.2 S1 ;
    M569 P0.3 S1
    M569 P0.4 S1 ;
    M569 P0.5 S0;
    M584 X0.0:0.1 Y0.2 Z0.3:0.4 E0.5 ; set drive mapping
    M671 X-80:780 Y150:150 S5;Set location of z-rods
    M92 X80.00 Y80.00 Z720.00 E409.00 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X1000 Y1000 Z800 E1100 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    ; Axis Limit
    M208 X700 Y320 Z387 S0 ; set axis maxima
    M574 X1 S0 P"io0.in" ; configure active-low endstop for low end on X via pin io0.in
    M574 Y1 S0 P"io1.in" ; configure active-low endstop for low end on Y via pin io1.in
    M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
    M558 P9 C"io7.in" H1 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X0 Y-30 Z0.84 ; set Z probe trigger value, offset and trigger height
    M557 X0:700 Y0:280 S70 ; define mesh grid
    M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.060000e-8 ; configure sensor 1 as thermistor on pin temp1
    M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
    M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
    M106 P0 S0.7 H1 T45 ; set fan 0 value. Thermostatic control is turned on
    M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
    M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
  • Moderator
    @codyc firmware version? Are you using the Duet 3 with SBC or standalone? Early RRF 3 versions needed the M584 command splitting onto separate lines where multiple motors were defined on multiple axes, eg
    M584 X0.0:0.1 Y0.2
    M584 Z0.3:0.4 E0.5 ; set drive mapping
    So you could try that.
  • Ah, still on an earlier version. I'll give that a shot right now. Duet 3 with SBC.
  • And that made it work. Thanks for sharing your knowledge @droftarts !
