Duet 3 v1.0 Fault on SD slot
i didn't read the whole thread i'll admitt, but if you want to verify the individual parts that make up the connection between the pi and the duet this old-ish thread has a ton of information on where to go digging https://forum.duet3d.com/topic/15551/duet3-pi-dcs-is-unavailable-after-wiring-24v/119?_=1597267914698
(and if not, disregard:)
@bearer
Thanks bearer I was following the thread at the time I did check continuity and chris did manage to recreate an issue I was having so expect there would be a fix at some point
though at the time it was still freezing my issues which are many but with the duet even weirder and may not have been software or communication between the 2 as it ran as expected until a file was loaded everything else perfect probe, mesh G1's all extruding, heaters maybe a buffer/memory conflict/issue ? -
@Carlo These two pins of your SD card socket do not look well soldered:
Can you take a picture of the socket from an angle across the board, as shown here https://duet3d.dozuki.com/Wiki/SD_Card#Section_SD_Card_SocketIan
Hi Ian,
Sorry the board went in the mail run today wanted to keep it a while to test 3.2 beta 1
plus it is out of stock...but you get 7 days for return once they issue a returns # and I may have no access to office or workshop due to another possible 2 week lock down in my areaall the pins looked to be well attached and no oxidation all the contacts look ok..bit hard to see inside the slot
Image I took yesterday from a different angle.
Dunno if it is of help.
Cheers
C
