    polar printer?
    Firmware wishlist
    • tekstyleundefined
      tekstyle
      just wondering if there is a setup for polar printer? honestly, i only need a polar kinematics for X and Y. i have no need for a Z.
      • oliofundefined
        oliof
        Polar kinematics are supported. See https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwarePolarPrinter
        • tekstyleundefined
          tekstyle
          oh nice! i didnt see that in th configurator tool so i was wondering. thank you. out of curiosity, since the Y min and Y max is essentially the same position, is it necessary to have a dedicated home position for Y axis? like if i were to print a circle that requires 2 passes, would the G code go full circle and then reverse or would it go around the second time in the same direction?
            dc42 administrators @tekstyle
            @tekstyle said in polar printer?:
            Read the section and examples on homing Y on that page.
            It will do whatever the slicer tells it to, which will typically be to do 2 passe sin the same direction. When doing a travel move, it will take the shortest route.
            tekstyleundefined 1 Reply Last reply Reply Quote 0
            • tekstyleundefined
              tekstyle @dc42
              @dc42 thank you David!
