Ayuda core xy con duet2wifi
Buenos días, necesito de su ayuda no termino de configurar la impresora , me encuentro con problemas para configurar la cama y el extrusor directo titan con ev6 , llevo muchas horas ya no se por donde llegar a buen puerto , solo pude hacer funcionar los ejes xy y z y el bltouch, luego no paso de aqui
de antemano gracias y pongo mi configConfiguration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Aug 15 2020 11:23:04 GMT+0200 (hora de verano de Europa central); General preferences
M550 P"CORE XY FR" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M350 Z16 E16 I0 ; configure microstepping without interpolation
M350 X16 Y16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z2756.00 E406.00 ; set steps per mm
M566 X900.00 Y900.00 Z150.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
M203 X30000.00 Y30000.00 Z300.00 E6000.00 ; set maximum speeds (mm/min)
M201 X5000.00 Y5000.00 Z100.00 E1000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X330 Y330 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P9 C"^zprobe.in" H5 F120 T12000 ; set Z probe type to bltouch and the dive height + speeds
M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
G31 P25 X37 Y0 Z1.5 ; set Z probe trigger value, offset and trigger height
M557 X15:280 Y15:280 S20 ; define mesh grid; Heaters
M308 S1 P"e0temp" Y"pt1000" R4700 ; configure sensor 1 as PT1000 on pin e0temp
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P2 S1 H1 T180 ; set fan 2 value. Thermostatic control is turned on; Tools
M563 P1 S"CAMA" D0 F-1 ; define tool 1
G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
T1 ; select first tool
Can you be more specific about what problems you have with the bed and extruder?
Hola me explico mejor , no acabo de poder configurar la impresora para que funcione correctamente
; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Aug 17 2020 00:51:19 GMT+0200 (hora de verano de Europa central); General preferences
M575 P1 S1 B115200 ; enable support for PanelDue; Network
M569 P0 S0 ; physical drive 0 goes forwards
M569 P1 S0 ; physical drive 1 goes forwards
M557 X15:280 Y15:280 S20 ; define mesh grid; Calentadores
M308 S0 P "temperatura de la cama" Y "termistor" T100000 B4092; configurar el sensor 0 como termistor en la clavija temperatura de la cama
M950 H0 C "calefacción de la cama" T0 ; cree la salida del calentador de la cama en el calor de la cama y asignela al sensor 0
M143 H0 S120 ; ajuste el límite de temperatura para el calentador 0 a 120C
M307 H0 B0 S1.00 ; deshabilite el modo bang-bang para el calentador de cama y establezca el límite PWM
M140 H0 ; mapear la cama calentada al calentador 0
M308 S1 P "e0temp" Y "termistor" T100000 B4092 ; configurar el sensor 1 como termistor en el pin e0temp
M950 H1 C "e0heat" T1 ; crear la salida del calentador de la boquilla en e0heat y asignarla al sensor 1
M143 H1 S280 ; ajuste el límite de temperatura para el calentador 1 a 280C
M307 H1 B0 S1.00 ; deshabilite el modo bang-bang para el calentador y establezca el límite PWM; Ventiladores
M950 F0 C "fan0" Q500 ; cree el ventilador 0 en el pin fan0 y configure su frecuencia
M106 P0 S0 H-1 ; establecer el valor 0 del ventilador. El control termostático está apagado
M950 F1 C "fan1" Q500 ; cree el ventilador 1 en el pin fan1 y configure su frecuencia
M106 P1 S1 H1 T45 ; establecer el valor del ventilador 1. El control termostático está encendido; Fans
M106 P1 S1 H0 T45 ; set fan 1 value. Thermostatic control is turned on
M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off; Tools
M563 P0 D0 H1 F0 ; definir herramienta 0
T0 ; select first tool
Por favor puede ayudarme en la configuracion correcta ?
Yes I see the configuration, but I don't understand the problem. From your photo of the PanelDue it looks like your thermistors are disconnected or not connected correctly. That's what -273 means. Can you post a photo of your thermistor connections on the duet?
What firmware version is the PanelDue using? Check in the settings tab on the panel. It should be 1.24.
Are you sure this is the correct steps per mm for Z?
M92 X80.00 Y80.00 Z2756.00 E406.00 ; set steps per mm; Calentadores M308 S0 P "temperatura de la cama" Y "termistor" T100000 B4092; configurar el sensor 0 como termistor en la clavija temperatura de la cama M950 H0 C "calefacción de la cama" T0 ; cree la salida del calentador de la cama en el calor de la cama y asignela al sensor 0 M143 H0 S120 ; ajuste el límite de temperatura para el calentador 0 a 120C M307 H0 B0 S1.00 ; deshabilite el modo bang-bang para el calentador de cama y establezca el límite PWM M140 H0 ; mapear la cama calentada al calentador 0 M308 S1 P "e0temp" Y "termistor" T100000 B4092 ; configurar el sensor 1 como termistor en el pin e0temp M950 H1 C "e0heat" T1 ; crear la salida del calentador de la boquilla en e0heat y asignarla al sensor 1 M143 H1 S280 ; ajuste el límite de temperatura para el calentador 1 a 280C M307 H1 B0 S1.00 ; deshabilite el modo bang-bang para el calentador y establezca el límite PWM
Is that section straight out of the configurator? The spacing seems weird, but maybe it's a translation thing.
; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
You have double the fan blocks. YOur second block changes the fan1 to use the bed temp to turn on the hot end fan. You probably don't want that?
@Fabián Send M122 and post reply, to show the firmware version. I suspect you are using RepRapFirmware v2.xx, but your config.g is for v3. You probably need to update your Duet 2 WiFi firmware.
Gracias a los por responder, esta tarde lo pruebo y les comento si mejora
M122
=== Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later<LF>Board ID: 0JD0M-9K662-MG5TD-6JTDG-3SJ6K-1BLYW<LF>Used output buffers: 1 of 24 (20 max)<LF>=== RTOS ===<LF>Static ram: 27980<LF>Dynamic ram: 93828 of which 60 recycled<LF>Exception stack ram used: 312<LF>Never used ram: 8892<LF>Tasks: NETWORK(ready,348) HEAT(blocked,1224) MAIN(running,1824) IDLE(ready,80)<LF>Owned mutexes: WiFi(NETWORK)<LF>=== Platform ===<LF>Last reset 00:00:56 ago, cause: power up<LF>Last software reset at 2020-08-19 09:23, reason: User, spinning module GCodes, available RAM 8940 bytes (slot 2)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN<LF>Error status: 0<LF>MCU temperature: min 35.9, current 37.1, max 37.4<LF>Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes<LF>Driver 0: standstill, SG min/max not available<LF>Driver 1: standstill, SG min/max not available<LF>Driver 2: standst[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
@Fabián Okay, you're running firmware 3.1.1, and your config.g is correct for this version. If the temperature sensor is still showing -273, you need to post a picture of your wiring. Also note that you are using the default thermistor, which may not be the same as your actual thermistor. Please post what thermistor you are using.
Try sending
M308 S0
to show the thermistor settings. I think you may need to change the Y parameter from Y"termistor" to Y"thermistor".Ian
Hola Droftarts, pone lo siguiente:
9/8/2020 13:35:35: M308 S0: Sensor 0 type Thermistor using pin bedtemp, reading 26.8, last error: sensor not ready, T:100000.0 B:4138.0 C:0.00e+0 R:4700.0 L:0 H:0
luego de ver la version del panel due que es la 1,24 , ahora se ve la temp. de la cama , pero el hotend no, te paso foto
@Fabián Perdon por mi ignorancia , todo esto es nuevo para mi y estoy muy perdido en programacion, solo quiero que imprima
@Fabián It looks like the thermistors are not being linked to the bed or tool. Can you post your config.g again, as it appears now?
Also send
M308 S1
to check the second thermistor.Ian
; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Aug 18 2020 23:41:07 GMT+0200 (hora de verano de Europa central); General preferences
M550 P"CoreXY" ; set printer name
G31 P500 X37 Y0 Z1.5 ; set Z probe trigger value, offset and trigger height
M308 S0 P"bedtemp" Y "thermistor" T100000 B4138 R4700 ; configure sensor 0 as thermistor on pin bedtemp
M307 H0 B0 S1.00 ; dissable bang-bang mode for heater and set PWM limit
M308 S1 P"e0temp" Y"thermistor" T100000 B4138 R4700 ; configure sensor 1 as thermistor on pin e0temp
M950 H1 C"e0heat" ; create nozzle heater output on e0heat and map it to sensor 1
M307 H1 B0 S1.00 ; dissable bang-bang mode for heater and set PWM limit; Fans
M563 P0 S"Hotend" D0 F0 ; define tool 0
19/8/2020 14:53:15 M308 S1
Tipo de sensor 1 Termistor usando pin e0temp, lectura 26.2, último error: sensor no listo, T: 100000.0 B: 4138.00.00e + 0 R: 4700.0 L: 0 H: 0
19/8/2020 14:53:48: M308 S1: Sensor 1 type Thermistor using pin e0temp, reading 26.2, last error: sensor not ready, T:100000.0 B:4138.0 C:0.00e+0 R:4700.0 L:0 H:0
el termistor es el original de Titan aero E3D , conectado al E0 de la placa duet2 y la cama caliente es de silicona 220v/750w aliexpress china que viene con su termistor colocado sin datos , esta conectada a un mosfet externo
@Fabián For the heated bed, change the order of commands (M140 must come after M950, but before M143):
M308 S0 P"bedtemp" Y "thermistor" T100000 B4138 R4700 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B0 S1.00 ; dissable bang-bang mode for heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C
If you can find the specification of the thermistor that is in your heated bed (maybe the AliExpress link?), post the details and we can update the M308 with the correct values.
For the hot end, your tool does not have a heater/thermistor defined! Change to:
M563 P0 S"Hotend" D0 H1 F0 ; define tool 0
For an E3D Semitec 104-GT2 thermistor (used in the Titan Aero), change M308 to this:
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
You will also need to tune the hot end heater and bed with M303 to get accurate values for M307; see https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M303_Run_heater_tuning
Hola de nuevo Ian, la cama de silicona el fabricante dice que es NTC 100K 3950 180ºC
Comprueba si lo modifique bien por favor el config sys
M308 S0 P"bedtemp" Y "thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M143 H0 S180 ; set temperature limit for heater 0 to 180C
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8; configure sensor 1 as thermistor on pin e0temp
M140 H0 ; map heater 1
@Fabián looks good. Does it show correctly on PanelDue and DWC now?
no sigue siendo desigual Ian
Ian acabo de pedir una duet2wifi original a DUET y una Placa PT100,
