UNSOLVED DCS Not starting (Could not connect to Duet)
  • I have a Raspberry Pi 4 with a Duet 3 I'm using on my Jubilee 3D Printer. I get a message saying DCS is not running when I access the Duet Web Interface.
    I'm using a different ribbon cable because my last one is damaged.
    pi@duet3:~$ apt-cache policy duetcontrolserver
    duetcontrolserver:
    Installed: 3.1.1
    Candidate: 3.1.1
    Version table:
    *** 3.1.1 500
    500 https://pkg.duet3d.com stable/armv7 armhf Packages
    100 /var/lib/dpkg/status
    3.1.0 500
    1.2.4.0 500
    1.2.3.0 500
    1.2.2.1 500
    1.1.0.5 500
    1.0.4.1 500
    1.0.3.1 500
    pi@duet3:~$ sudo systemctl status duetcontrolserver.service
    ● duetcontrolserver.service - Duet Control Server
    Loaded: loaded (/lib/systemd/system/duetcontrolserver.service; enabled; vendor preset: enabled)
    Active: activating (auto-restart) since Mon 2020-08-17 22:44:53 BST; 3s ago
    Process: 7422 ExecStart=/opt/dsf/bin/DuetControlServer (code=exited, status=0/SUCCESS)
    Main PID: 7422 (code=exited, status=0/SUCCESS)
    pi@duet3:~$
    pi@duet3:~$ journalctl -u duetcontrolserver.service -f
    -- Logs begin at Mon 2020-08-17 22:12:32 BST. --
    Aug 17 22:48:57 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 53.
    Aug 17 22:48:57 duet3 systemd[1]: Stopped Duet Control Server.
    Aug 17 22:48:57 duet3 systemd[1]: Started Duet Control Server.
    Aug 17 22:48:58 duet3 DuetControlServer[8173]: Duet Control Server v3.1.1
    Aug 17 22:48:58 duet3 DuetControlServer[8173]: Written by Christian Hammacher for Duet3D
    Aug 17 22:48:58 duet3 DuetControlServer[8173]: Licensed under the terms of the GNU Public License Version 3
    Aug 17 22:48:58 duet3 DuetControlServer[8173]: [info] Settings loaded
    Aug 17 22:48:58 duet3 DuetControlServer[8173]: [info] Environment initialized
    Aug 17 22:48:58 duet3 DuetControlServer[8173]: [fatal] Could not connect to Duet (Board is not available (no header))
    Aug 17 22:48:59 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
    Aug 17 22:49:04 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=5s expired, scheduling restart.
    Aug 17 22:49:04 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 54.
    Aug 17 22:49:04 duet3 systemd[1]: Stopped Duet Control Server.
    Aug 17 22:49:04 duet3 systemd[1]: Started Duet Control Server.
  • can you connect using the micro usb cable and run M115 if it says 3.0beta12 or something you need to update the firmware on the duet manually as the apt upgrade skips a step.
    if your pi has a internet connection i found it easiest to just build bossa and do the upgrade from there as windows & osx can be subject to a bug. I've put together a script that attempts to do everything with a single copy/paste command if you want to try that wget https://pastebin.com/raw/Wa1kYf3G -O - | tr -d "\r" | bash (needs the Duet's micro usb port connected to the pi)
    manual instuctions if you prefer: https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_main_board_firmware
  • @bearer said in DCS Not starting (Could not connect to Duet):
    pi@duet3:~$ wget https://pastebin.com/raw/Wa1kYf3G -O - | tr -d "\r" | bash
    --2020-08-17 23:28:27-- https://pastebin.com/raw/Wa1kYf3G
    Resolving pastebin.com (pastebin.com)... 104.23.98.190, 104.23.99.190, 2606:4700:10::6817:63be, ...
    Connecting to pastebin.com (pastebin.com)|104.23.98.190|:443... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: unspecified [text/plain]
    Saving to: ‘STDOUT’
    •                                [ <=>                                                       ]     897  --.-KB/s    in 0s
    2020-08-17 23:28:27 (4.97 MB/s) - written to stdout [897]
    Cloning into '/home/pi/BOSSA'...
    remote: Enumerating objects: 11, done.
    remote: Counting objects: 100% (11/11), done.
    remote: Compressing objects: 100% (10/10), done.
    remote: Total 1727 (delta 4), reused 5 (delta 1), pack-reused 1716
    Receiving objects: 100% (1727/1727), 1.15 MiB | 10.41 MiB/s, done.
    Resolving deltas: 100% (1318/1318), done.
    make: wx-config: Command not found
    CPP APPLET src/WordCopyArm.cpp
    CPP COMMON src/Samba.cpp
    CPP COMMON src/Flash.cpp
    CPP COMMON src/D5xNvmFlash.cpp
    CPP COMMON src/D2xNvmFlash.cpp
    CPP COMMON src/EfcFlash.cpp
    CPP COMMON src/EefcFlash.cpp
    CPP COMMON src/Applet.cpp
    CPP COMMON src/WordCopyApplet.cpp
    CPP COMMON src/Flasher.cpp
    CPP COMMON src/Device.cpp
    CPP COMMON src/PosixSerialPort.cpp
    CPP COMMON src/LinuxPortFactory.cpp
    CPP BOSSAC src/bossac.cpp
    CPP BOSSAC src/CmdOpts.cpp
    LD bin/bossac
    /dev/ttyACM0 not found
    pi@duet3:~$
  • @bcrazycramer said in DCS Not starting (Could not connect to Duet):
    sugget the duet micro usb isn't connected to the pi or the cable isn't working properly?
    (maybe i should move that test up to the top, good idea)
    connect the pi or try another cable? you can run lsusb and just see when the output changes, then run the script again
  • pi@duet3:~$ lsusb
    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    pi@duet3:~$
    Can I have both the USB plugged in from the Duet to the PI and Duet VIN power at the same time?
    if the ribbon cable is connected then adding the usb cable isn't going to make any difference, but you can also do it without Vin if it feels safer.
  • I found another usb cable:
    pi@duet3:~$ lsusb
    Bus 001 Device 003: ID 1d50:60ee OpenMoko, Inc.
    pi@duet3:~$
    Trying it again.
    Erase Flash
    SAM-BA operation failed
    this was the duet, so better cable, presumably that changed to something like Bus 001 Device 008: ID 03eb:6124 Atmel Corp. at91sam SAMBA bootloader
    but either there is still an usb issue or the beforementioned bug is affecting the pi as well. I'd maybe try using the manual procedure from windows and see if its the same. if still troublesome, try yet another cable.
  • Same thing.
    Verify:
  • other options include SAM-BA software or atmel studio. you could also find it works with another computer and/or usb cable.
  • I got it to switch to COM4 and got farther:
  • thats a bit fishy; sounds like the connection was broken when it was COM3 and because the software still were using COM3 it had to be assigned to COM4 when it reconnected (or do you happen to have two separate Duet3 boards connected to to different USB ports?)
    edit: I'd focus on trying other usb cables/usb ports based on that
  • I will give all this a try tomorrow. Thanks!!
  • I'm having the same issue this morning using a Dell Laptop. The Duet 3 shows up as Com 3 in Device Manager. Bossa Program Port (Com3). When I try to verify I get the SAM-BA operation failed.
  • With another USB cable when I Verify I get Verify failed with page errors and byte errors.
  • given the board was flashed and tested before it shipped I'm inclined to think the issue is the usb cables still. its not the first time someone have tried 3 and 4 cables before getting a new one and then succeeding.
    alternatively trying sam-ba or atmel studio instead of bossa.
  • I wasn't clicking write and then verify. My bad.
    Current status after the write and verify:
    Aug 18 19:43:25 duet3 systemd[1]: Stopped Duet Control Server.
    Aug 18 19:43:25 duet3 systemd[1]: Started Duet Control Server.
    Aug 18 19:43:26 duet3 DuetControlServer[1654]: Duet Control Server v3.1.1
    Aug 18 19:43:26 duet3 DuetControlServer[1654]: Written by Christian Hammacher for Duet3D
    Aug 18 19:43:26 duet3 DuetControlServer[1654]: Licensed under the terms of the GNU Public License Version 3
    Aug 18 19:43:26 duet3 DuetControlServer[1654]: [info] Settings loaded
    Aug 18 19:43:26 duet3 DuetControlServer[1654]: [info] Environment initialized
    Aug 18 19:43:26 duet3 DuetControlServer[1654]: [fatal] Could not connect to Duet (Board is not available (no header))
    Aug 18 19:43:26 duet3 systemd[1]: duetcontrolserver.service: Succeeded.
    Aug 18 19:43:32 duet3 systemd[1]: duetcontrolserver.service: Service RestartSec=5s expired, scheduling restart.
    Aug 18 19:43:32 duet3 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 51.
    Aug 18 19:43:32 duet3 systemd[1]: Stopped Duet Control Server.
    Aug 18 19:43:32 duet3 systemd[1]: Started Duet Control Server.
  • How can I get an original 26 pin to 40 pin ribbon cable for the Duet 3 to Raspberry Pi?
  • Why do you say it won't help?
  • The Pi seems to indicate the Duet is connected but not responding properly.
    Are you able to connect to the usb serial console and execute M115 to show which version of the firmware is running on the Duet now?
    So connect it up with Repetier host or something similar and issue M115?
  • Yeah, although any serial terminal will suffice
  • Duet 3 MB6HC Firmware Version 3.1.1 Electronics: Duet 3 MB6HC V1.01 or later
  • Well, thats good news!
    Is the cable damaged? Its theoretically possible the cable is the issue, but its at least partially functioning.
    There are a few tests you could run to verify the pi and cable is okay by placing some jumpers to connect together some pins on the duet end of the ribbon cable.
    this post (and the rest of the thread has a lot of information on this) https://forum.duet3d.com/post/149055
    i'd set up the software according to that that link, test the pins of the pi without a ribbon cable, then connect the ribbon cable, and move the shorts to the duet side of the ribbon cable with the pi end connected to the pi. should help pinpoint where the issue is
