    axis problem
    518
    • A Former User?
      A Former User
      I have a problem with my CoreXY 3D printer – it moves in both X and Y direction even I only ask for movement in one of the directions.
      When I ask for a movement of X or Y it does so in both the X and Y direction – this means that it only will move diagonally.
      I am able to make it move in one axis direction using G1 H2 X / Y specified mm; but it still moves diagonally when I press “Home” on X and Y so that does not solve the problem.
      I hope one of you are able to help me with a solution – so it only moves in the direction I specify.
      droftartsundefined JoergS5undefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @A Former User
        @Bak post response to M115 for firmware version, and your config.g, please.
        • A Former User?
          A Former User
          M115
          FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.0 or 1.01 FIRMWARE_DATE: 2020-05-19b2
          From config.g
          M92 X100.00 Y100.00 Z800.00 E742.12 ; set steps per mm
          M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X48000.00 Y48000.00 Z300.00 E1500.00 ; set maximum speeds (mm/min)
          M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
          M906 X500 Y500 Z700 E500 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X200 Y200 Z280 S0 ; set axis maxima
          And thanks for help
            @Bak need to see FULL config. If that is your full config, you haven’t told the firmware that it’s a CoreXY with M669 K1.
            If that is in, see https://duet3d.dozuki.com/Wiki/Test_axes_or_motors_individually and https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter
            • A Former User?
              A Former User
              Here is it all.
              ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Aug 19 2020 14:50:02 GMT+0200 (Centraleuropæisk sommertid)
              M550 P"Min printer" ; set printer name
              M669 K1 ; select CoreXY mode
              M551 P"" ; set password
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
              M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
              M574 Z2 S1 P"!zstop" ; configure active-high endstop for high end on Z via pin !zstop
              M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
              M557 X5:195 Y5:195 S20 ; define mesh grid
              M308 S0 P"spi.cs1" Y"rtd-max31865" ; configure sensor 0 as thermocouple via CS pin spi.cs1
              M308 S1 P"spi.cs2" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs2
              M106 P0 S1 H1:0 T100 ; set fan 0 value. Thermostatic control is turned on
              M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
              M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
              M563 P0 S"A extruder" D0 H1 F0 ; define tool 0
              • Vetiundefined
                Veti
                and thats the config.g from your printer? not one that you have saved locally?
                please post the output of M669
                • A Former User?
                  A Former User
                  No it's from config.g on my printer
                    Post your homeall
                    • JoergS5undefined
                      JoergS5 @A Former User
                      @Bak said in axis problem:
                      Are you sure you have a CoreXY and not a Cartesian printer? Can you make a picture of XY steppers and belt construction please?
                      • A Former User?
                        A Former User
                        ; homeall.g
                        ; called to home all axes
                        G91 ; relative positioning
                        G1 H1 X-205 Y-205 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                        G1 H1 X-205 ; home X axis
                        G1 H1 Y-205 ; home Y axis
                        G1 X5 Y5 F6000 ; go back a few mm
                        G1 H1 X-205 F360 ; move slowly to X axis endstop once more (second pass)
                        G1 H1 Y-205 ; then move slowly to Y axis endstop
                        G1 H1 Z285 F360 ; move Z up stopping at the endstop
                        G90 ; absolute positioning
                        G92 Z280 ; set Z position to axis maximum (you may want to adjust this)
                        ;G91 ; relative positioning
                        ;G1 Z5 F100 ; lift Z relative to current position
                        ;G90 ; absolute positioning!
                        • A Former User?
                          A Former User
                          • oliofundefined
                            oliof
                            That's not a corexy machine, that's a Cartesian with an ultimaker style gantry.
                            • A Former User?
                              A Former User
                              Thanks. I'm reasonably new to this and thought I knew the difference between CoreXY and a Cartesian printer.
                              Thank you very much for your help I have fixed it now so it runs as it should 🙂
