    M500 wont save
    • bigwood247
      bigwood247 last edited by
      i just installed a duet 2 wifi on my cr10s and everything works great but it wont save my pid auto tune results with the M500 command and it also wont create a config override file ither anyone know whats going on here
      peter247 Phaedrux 2 Replies Last reply Reply Quote 0
      • peter247
        peter247 @bigwood247 last edited by
        @bigwood247
        The reprap works different than marlin , M500 does not save the setting to eeprom , but makes a config-override.g file which you need to add the line M501 to the end of config.g to load it.
        Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
          Phaedrux Moderator @bigwood247 last edited by
          @bigwood247 said in M500 wont save:
          No config-override.g files exists in /sys?
          What firmware version are you using? M115 to find out.
          Do you get any errors when sending M500?
