    Extending EPS-12S
    • Iamturbo1978undefined
      Iamturbo1978
      Hello all,
      I just bought my 2nd Duet WiFi board. The printer it is going into is a knockoff MakerBot replicator. The whole frame is steel, and the cavity the board will be in is steel. I would rather not cut any of the panels to bring the WiFi module outside of the steel cage.
      So I would like to extend the EPS-12S module to a better location.
      Is there any advice someone could offer, before I make the changes?
      Thanks in advance
      • jens55undefined
        jens55
        Get a wifi module with an external antenna.
        Iamturbo1978undefined 1 Reply Last reply Reply Quote 1
          Iamturbo1978 @jens55
          @jens55 said in Extending EPS-12S:
          That is a great idea. I will check into that
          • jens55undefined
            jens55
            Just as an FYI, I think Duet sells the module (they sell duets as both internal as well as external antennas)
            Iamturbo1978undefined 1 Reply Last reply Reply Quote 0
              I could not find just the module on the Duet3D website, but I was able to get the part number off of the pictures. Digikey offers the module.
              https://www.digikey.com/product-detail/en/rf-solutions/ESP-07S/ESP-07S-ND/9555693
              I'll just de-solder the module, and install the external module. I like this idea so much better then trying to extend the module.
              Thank you
              • PCRundefined
                PCR
                I Made a Post about this ! With Pictures and a method to desolder without hotair
