Availability PanelDue & Duex5
  • Hi !
    Does anybody know when the PanelDue & Duex5 is again available from Duet3D ?
    Duex5 should be available again since 21th of June…. but it isn´t.
    Hi, we have had a manufacturing delay on the Duex5s so are just starting to get boards in. I expect to update the website with stock next week.
  • thanks, what about the PanelDue 5" ?
    I also read that the 7" version isn´t shipped at all. For another 3d-printer i use a cheap amazon Fire7 and the webinterface as interface. I also know that the Duet has an webinterface, so i am asking if i should wait for the PanelDue or just use the amazon Fire7 and the Duet webinterface ….
    Same sort of lead time on the PanelDue 5s. We are working with a new supplier for the 7 inch LCDs as we were not happy with the old supplier, those will be significantly longer to get the required changes implemented. Using a tablet is fine using Duet Web Interface.
