Unsolved rehome.g not found
@Marco-Bona This is the start.g you posted earlier in the thread.
G4 S1 M117 Preparing ;write Preparing G4 S1 ;delay 1 seconds M280 P0 S160 ; Send PWM channel 0 the s160 (angle) command M84 V; ; If the printer hasn't been homed, home it if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed G28 M42 P6 S40 G21 ;metric values G90 ;absolute positioning M107 ;start with the fan off G1 X0 Y0 F10000 ; G1 Z20 F1000 ; M98 P"probe.g" ; T2 P0 ; G1 R2 X0 Y0 Z0 F5000 ; G32 ; G1 Z10 F800 ; G1 X0 Y0 F8000 ;go to the center of bed G30 X0 Y0 S-2 ;probe current position and ajust Z offset G1 Z40 F1000 ;go to Z40 M584 P5 M98 P"homev.g" M584 P3 G1 X-137 Y120 F8000 ;go to X-137 Y160 ;M42 P6 S50 G4 S1
As you have a start.g, it runs first when a print is run. If you run start.g yourself (with M98 P"start.g") then start a print, it will run start.g again. So possibly running start.g once causes an issue, but twice fixes it. I can't see anything obvious, though start.g seems largely related to homing the V axis, and you haven't linked homev.g. Please post that too.
@Marco-Bona Also, in config.g I noticed:
M350 X16 Y16 Z16 W16 16 V16 E32:32 I1 ; configure microstepping with interpolation
There needs to be a 'U' before the '16', eg:
M350 X16 Y16 Z16 W16 U16 V16 E32:32 I1 ; configure microstepping with interpolation
What happens if you step through the start.g manually command by command?
You say after a print is canceled. What do you have in pause.g cancel.g and stop.g?
What else do you have in your slicer start gcode?
@droftarts said in rehome.g not found:
fantastic, correct immediately.
@Phaedrux , @droftarts, sorry but I can't be clear, I'm saying that stall warning occurs only and exclusively when a print is started, if I turn on the printer and execute M98 P "start.g", machine executes the command correctly, I can repeat command at infinity that will always work.
Instead, if I start any printout, stall warning continues to appear.
Again, I assume it is something that conflicts with Cura, but I don't understand what it could be.
If necessary I can post a video.
I am attaching the files you asked me, i am realizing that cancel.g is missing, is that a problem?
homev.g pause.g stop.g -
@Phaedrux said in rehome.g not found:
Can you post a sample gcode?
M84 V;
I think it has something to do with homing V and the high steps per mm.
M92 U37.67 V5245.9
What is the V axis?
The start.g turns off the V motor and then homes all axis if an axis isn't homed, so it runs G28. Then you call the probe. and then below again it calls homev with a M98 instead of a G28 V and then rehides the axis.
Then in your slicer end gcode you have M98 P"end.g". What is in end.g?
You don't have a cancel.g so when you cancel a print it's calling stop.g, or it should anyway.
Minor point, but you could move the contents of stop.g into cancel.g, then move end.g into stop.g, and then change the slicer end gcode to M0 instead of M98 PEnd.g. Then all files would be fulfilling their original intentions.
In start.g you have
What does this do?Can you send M98 P"Config.g" and post the results?
Can you send M584, M350, and M92 and M906 to see if the resulting settings are what you expect them to be? -
@Phaedrux, i try to move the files as you said.
G1 R2 X0 Y0 Z0 is used to translate the position of the probe.
Tomorrow I try to run M98 P "config.g" and let you have the results. -
I suspect that part of the problem may be in stall detection not working for motors on the expansion boards.
@Phaedrux , you are right for the confusion of the files. If I remember correctly I had done end.g because I hadn't noticed that cancel.g was missing.
I'll arrange to fix -
@Phaedrux, even if the X and Y motors are on the main board?
@Marco-Bona That's why I suspected a stall being detected on V or something and maybe related to the high steps per mm, but I'm not sure.
@Phaedrux, here are results:
M98 P"config.g" Warning: M307: Heater 3 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
M584 Driver assignments: X0.0 Y0.1 Z0.2:0.3 U1.0 V1.1 W0.3 E0.4:0.5, 3 axes visible
M350 Microstepping - X:16(on), Y:16(on), Z:16(on), U:16(on), V:16(on), W:16(on), E:32(on):32(on)
M92 Steps/mm: X: 80.000, Y: 80.000, Z: 802.005, U: 37.670, V: 5245.900, W: 802.005, E: 806.000:806.000
M906 Motor current (mA) - X:2240, Y:2240, Z:2100, U:1800, V:1500, W:2100, E:560:560, idle factor 30%
would seem all correct
With 3.2 beta now released you may want to try that out to see if the behaviour remains.
I tried to make a print. The strange behavior of stall remains, however, after fixing name of rehome.g the error occurs less frequently. Part of problem I think was caused by the lack of file. I tried to insert M204 P500 T1000 and M566 X600 Y600 in start.g and I fixed files you told me but nothing changed, motors stalled anyway during start.g execution.
@Phaedrux, I repeat, this behavior only happens when you are running a printout
I'd still like to know how far it gets before it stalls.
Perhaps post a video so we can see exactly what's happening.
At this point we can't see anything obvious so we need to narrow it down.
@Phaedrux, sending the video link while I start a printout. As you can see it is practically impossible to work this way. When I run M98 P-"start.g" from the DWC console, machine is functioning correctly, no rehome.g is performed when running the command.
https://www.youtube.com/watch?v=T0eO3SE1cW8&t=182s
"What happens if you step through the start.g manually command by command?"
You mean some kind of single block? I ask why I don't know, how do I execute every single command?
