    Hide Heater 1 and 2 in Web Interface
    747
    • fcwilt
      fcwilt last edited by
      I am working on installing a Diamond 5 color head on my printer.
      I added a Duex5 to the printer to handle the extra extruders.
      So to keep all of the Diamond hotend wiring together I was thinking that I would connect all 5 extruders, the 1 heater and the 1 thermistor to the Duex5.
      But when I create the first tool using Heater 3 (the first heater on the Duex5 - correct?) Heater 1 and Heater 2 still appear in the Web Interface.
      Heater 3 displays the correct temp but, naturally, Heater 1 and 2 display an error because there are no thermistors for these.
      Am I trying to do something that cannot be done? Do I have to use Heater 1 from the Duet Wifi board?
      Thanks.
      Printers: A FT-5 with the 713 upgrade bits. A custom MarkForged style. A small Utilmaker style and a CoreXY from kits. Various hotends. Using Duets (2 and 3) running 3.4.0
      • Jackal
        Jackal last edited by
        I had the same Problem, I hope 1.19 will solve this as I have seen "M105 temperature reports are now in tool heater order instead of heater order" in the latest beta release note
        • fcwilt
          @Jackal:
          Thanks.
          I have been avoiding anything that says "BETA" but perhaps I should try it out.
          Can I revert back to 1.18 if 1.19 has issues?
          • elmoret
            elmoret last edited by
            Yes, no problem to roll back.
            • AndreS
              AndreS last edited by
              For up- and downgrade 1.18 to 1.19 see here: https://duet3d.com/wiki/DuetWiFiFirmware_1.19beta
              • fcwilt
                Thanks to all.
                • Jackal
                  Hi Frederick, I have mistaken the RRF changelog.
                  The problem lies with DWC instead of RRF
                  I have uploaded a modified version of DWC on github which should hide heaters with no associated tool
                  https://github.com/SleepyPrince/DuetWebControl/raw/master/DuetWebControl-1.16.zip
                  • fcwilt
                    @Jackal:
                    Thanks.
                    I will give it a try.
                    Have you made any other changes from the "official" 1.16 version?
                    • Jackal
                      @fcwilt:
                      @Jackal:
                      Thanks.
                      That's the only change
                      2 lines of code
