Dual Z setup help
ok i have read the dozuki on bed lvling with multiple independent z motors and its very vague on how to do it and im having a hard time even figuring out how to setup 3.0. Is there a walk through on how to set it up especially on 3.0 and newer?
there is no difference here from rrf2 to rrf3.
start with connecting two z motors by changing the M584 command.
if you have everything working for that move on to define the M671 command and the bed.g file.what command are you unclear about or need help?
Its not the commands its the setup. I understand i need to configure most of it by hand i was just hoping there was a clearer walk through of setting dual z up. So far i have gotten E0 seen as z2 and they workish together i think i need to add E0 to the z probe endstop list so it will stop z and E0. Really most of the gcode im not sure of. im mainly cobbling together what i can and trying and going forward if it works and back if it doesnt.
you either need 2 endstops for each z motor, or your replace the z endstop with a probe.
the second is the better option because then the levelling is based on your actual bed.
do you have a probe?
yeah i have a bltouch and sofar ive gotten the location its at compared to the hotend and the trigger distance setup.
post your current config.g
; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 09 2020 13:00:38 GMT-0700 (Pacific Daylight Time); General preferences
M550 P"My Printer" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P3 S0 ; physical drive 3 goes backwards
M569 P4 S1 ; physical drive 4 goes forwards
M584 X0 Y1 Z2:3 E4 ; set drive mapping
M92 X80.00 Y80.00 Z4000.00 E418.60 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X14000.00 Y14000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X700 Y700 Z700 E500 ; set motor currents (mA)
M84 S0 ; Disable motor idle current reduction; Axis Limits
M208 X330 Y330 Z400 S0 ; set axis maxima; Endstops
M574 X1 Y1 S3 ; set endstops controlled by motor stall detection
M574 Z1 E0 S2 ; set endstops controlled by probe
M915 X330 Y330 S5 F0 R3 H400 ; Stall detection. Higher S value -> less sensitive; Z-Probe
M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-62 Y-14 Z0.18 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 C"Fan0" S1 I0 F500 H-1 ; set fan 0 name, value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 C"Fan0" S0 I0 F500 H1 T45 ; set fan 1 name, value, PWM signal inversion and frequency. Thermostatic control is turned off; Tools
M563 P0 D0 H1 F0:1 ; define tool 0
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
this looks fine.
are you sure you have 4000 z steps and not 400?
this should only be
M574 Z1 S2 ; configure Z-probe endstop for low end on Z
e0 is not required here because you are configuring the probe and its independent of the motorsM305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
your bed is not configured correctly B4138 is not correct for an ender they use epocs 100k
I have a tronxy x5sa pro i wish i had an ender lol. Ill check to see if the bed setting is wrong but sofar its printed like that just fine so far. Well except for the lifting i get with large prints. The stock setting is exactly what i have for lead screws and motor. And when i tell it to move 10mm it moves 10 mm so id say it is the right setting. But ill check.
@User42 said in Dual Z setup help:
tronxy x5sa
according to marlins config
https://github.com/MarlinFirmware/Configurations/blob/import-2.0.x/config/examples/Tronxy/X5SA/Configuration.hthats also a epcos 100k
1 : 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
#define TEMP_SENSOR_BED 1
ah ok never thought to look at marlin for the configs. ill set that up then and see how it works. and you where right about the 4000 i measured with my calipers and it was off. im sorry i doubted you on those.
Well so far im getting way to frustrated with 3. Im gonna stick with 2 for now.
what bit are you still struggling with?
I think its me but i cant seem to get 3 to work with my printer. It doesnt seem to like the e3d hotend or the bltouch or the bed. Ive being working on trying to get 3 to work for about 42 hours and cant seem to get off first base. so im gonna stick with what i know. The only thing is the dang z motors cant seem to stay in sync too well.
are all 3 motors the same model?
@Veti all of the motors are the exact same model. They are all tronxy SL42STH40-1684A-23 motors. 1.8* motors with belts or .8 pitch lead screws or a 7.3 hobb on the extruder motor. I think that most of my troubles are either the download that im getting from the configurator for the firmware update is not completely downloaded or the file coming from the server is not complete which is causing my issues with 3 not working 100% heck i cant even update my firmware to the latest 2.05 im stuck on 2.03 for some odd reason.
what is the error you are getting?
Just after i got your question veti i tried the update again and got this error its this one every time too. M997 S0
Error: M997: In-application programming binary "iap4e.bin" not found -
iap4e
just upload this file to the duet. it contains all the required files. you dont even need to unpack it
https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/Duet2Firmware-2.05.1.zip -
@Veti thank you that worked like a charm.
