Multiple Errors Duet3
I bought Duet3 board for my new 380x660mm Delta printer, and I can't configure the firmware in any way. I bought Pi4, downloaded DuetPi Lite (I try DuetPi also), get updates (sudo apt-get update
sudo apt-get upgrade). Using https://configtool.reprapfirmware.org/Start I configured Delta printer settings. After loading the system files and reloading board, web interface looks just as empty (in the attachment).
I see 10 errors in the Console :
Error: Bad command: Q0 @"Custom settings are not defined"
Error: Bad command: Q0 @"Tools"
Error: Fan number 1 not found
Error: Fan number 0 not found
Error: Response timeout: CAN addr 1, req type 6027, RID=10 ...And a warning. Warning: Incompatible firmware, please upgrade as soon as possible
Please help me find out what the problem is and how I can fix it.
I've already read all the manuals 5 times but I can't figure out what the problem is -
you probably need to upgrade to RRF 3.0 first. I'd try in ssh
echo M115 | /opt/dsf/bin/CodeConsole cd /opt/dsf/sd/sys wget -q https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet3iap_spi_MB6HC.bin wget -q https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet3Firmware_MB6HC.bin echo M997 | /opt/dsf/bin/CodeConsole echo M115 | /opt/dsf/bin/CodeConsole wget -q https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet3Firmware_MB6HC.bin echo M997 | /opt/dsf/bin/CodeConsole echo M115 | /opt/dsf/bin/CodeConsole
edit: hmm, that might not work once you've updated with apt. two options, re-image your sd card with DuetPi (lite if you like) and run the above commands before updating apt.
or try https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_main_board_firmware - skip past apt and go with the windows or pi solution using usb.
(for the pi, i've wrapped it up in a script, so all you need to do is connect the micro usb cable from the duet to the pi and run
wget https://pastebin.com/raw/Wa1kYf3G -O - | tr -d "\r" | bash
<- assumes the updated firmware is in/opt/dsf/sd/sys/Duet3Firmware_MB6HC.bin
as a result of upgrading with apt and loosing the connection to the duet) -
It may be easier to get up and running with the Duet 3 in standalone mode to ensure the firmware is updated and ready to go before adding the Pi4 into the mix.
I re-image sd card with DuetPi and see the same empty DWC screen. When I try to connect to Pi4 via ssh in Terminal (I use Mac) I see WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED!
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the ECDSA key sent by the remote host is
SHA256:vB0nvZExndjvDSVpb545HYrolT0a1g/iInydOf8zvQ0.
Please contact your system administrator.
Add correct host key in /Users/dmitrykomkov/.ssh/known_hosts to get rid of this message.
Offending ECDSA key in /Users/dmitrykomkov/.ssh/known_hosts:3
ECDSA host key for 192.168.1.5 has changed and you have requested strict checking.
Host key verification failed.Is it related to the firmware or is it a computer problem?
I also tried BOSSA, but it's freeze at 44-45%
@dk said in Multiple Errors Duet3:
it happened because you re-imaged the sd-card, which generates new host keys on the pi - and the client keeps track of the hostname and fingerprint of the past keys to detect changes (or attacks). nothing to worry about as you did (unknowingly) change they keys on the pi
from the pi or the computer? try the other one and try a different usb cable, seems to help for most cases.
did you make a not of what happened when trying to run M997 after downloading the 3.0 files?
If you skip the pi for now and setup in standalone mode you can probably get your firmware updated using this method.
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Running_in_standalone_mode
@bearer Bossa finally works! third cable!
Thank you very much for your help!
Now I trying to figure out how to get BL-touch on 1LC Tool board get to work. It can't be done through https://configurator.reprapfirmware.org isn't it? -
https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitationsafaik thats not going to work until 3.3 is released, unless the toolboard is also controlling the z motor -
@bearer BLTouch on toolboard works fine for Z homing and bed levelling. Some people are having issues with intermittent comms or power supply, but we’re having difficulty replicating that to troubleshoot.
For physical connections, see https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board#Section_Connecting_a_BL_Touch
The configuration tool can produce the code, but doesn't set the CAN address, and I've noticed an error in the input pin drop down. So you'll need to edit config.g afterwards. Setting the following:
and
Produces:
; Z-Probe M950 S0 C"1.io0.out" ; create servo pin 0 for BLTouch M558 P9 C"^1.temp1" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height Assuming CAN address is 121, change this to:
; Z-Probe M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch M558 P9 C"^121.io0.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height Not sure if you actually need the pull-up resistor ^, but shouldn't hurt. Test and report back!
@droftarts said in Multiple Errors Duet3:
All Duet 3 ioX.in ports have permanent pullup resistors, on the main board and on expansion boards. So you never need to use ^ in the name. We recommend that you do not, because enabling it reduces the noise margin..
@droftarts Unfortunately, this didn't help. I tried with and without ^. BL-touch lights up in red but does not extend.
Can I find somewhere configuration files for any real working Delta printer on Duet3 with Tool board? This would help me a lot in setting up my printer. -
@dk Please post your config files so we can see what you have now.
Every time after reboot I get Error messages :
Error: M950: Response timeout: CAN addr 1, req type 6027, RID=8
Error: M106: Fan number 0 not found
Error: M950: Response timeout: CAN addr 1, req type 6027, RID=10
Error: M106: Fan number 1 not foundAnd when I push Home all only one motor moves.
Config.g
; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Sep 01 2020 22:07:15 GMT-0400 (EDT); General preferences
M550 P"Duet 3" ; set printer name
M665 R240 L460 B190 H750 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Drives
M569 P0.1 S0 ; physical drive 0.1 goes forwards
M569 P0.2 S0 ; physical drive 0.2 goes forwards
M569 P1.0 S1 ; physical drive 1.0 goes forwards
M584 X0.0 Y0.1 Z0.2 E1.0 ; set drive mapping
M92 X160.00 Y160.00 Z160.00 E415.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E800.00 ; set maximum instantaneous speed changes (mm/min)
M203 X3000.00 Y3000.00 Z3000.00 E600.00 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z3000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1600 Y1600 Z1600 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 S1 P"io0.in" ; configure active-high endstop for HIGH end on X via pin io0.in
M574 Y2 S1 P"io1.in" ; configure active-high endstop for HIGH end on Y via pin io1.in
M574 Z2 S1 P"io2.in" ; configure active-high endstop for HIGH end on Z via pin io2.in; Z-Probe
M558 P9 C"121.io0.in" H5 F120 T1000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X20 Y25 Z3 ; set Z probe trigger value, offset and trigger height
M557 R160 S40 ; define mesh grid; Heaters
M308 S0 P"temp3" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp3
M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
M308 S1 P"1.temp0" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin 1.temp0
M950 H1 C"1.out0" T1 ; create nozzle heater output on 1.out0 and map it to sensor 1
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"1.out2" Q500 ; create fan 0 on pin 1.out2 and set its frequency
M950 F1 C"1.out1" Q500 ; create fan 1 on pin 1.out1 and set its frequency
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
; homedelta.g
G91 ; relative positioning
G1 H1 X760 Y760 Z760 F1800 ; move all towers to the high end stopping at the endstops (first pass)
G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
G1 Z-5 F3600 ; move down a few mm so that the nozzle can be centred
G90 ; absolute positioning
G1 X0 Y0 F3600 ; move X+Y to the centre; deployprobe.g
; called to deploy a physical Z probe
; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Sep 01 2020 22:07:15 GMT-0400 (EDT)M950 S0 C"121.io0.out"
M280 P0 S10 ; deploy BLTouch; retractprobe.g
; called to retract a physical Z probe
M280 P0 S90 ; retract BLTouch -
Can you send M122 and M98 P"config.g" and post the results?
@dk you have a Duet 3, and a Toolboard, correct? Did you follow the steps in this guide: https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board
Have you changed the CAN address of your Toolboard? And if so, what to? See https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board#Section_Set_the_CAN_addressWhatever it’s set to, at the moment you have some commands referring to CAN address 1 (extruder motor, hit end heater, fan etc), and some as CAN address 121, which is the default (BLTouch). Also, it may need a firmware update (further up in the document linked above).
@Phaedrux
M122
RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
Board ID: 08DJM-956L2-G43S4-6JTDJ-3SJ6S-986GH
Used output buffers: 1 of 40 (21 max)
Static ram: 154604
Dynamic ram: 161404 of which 276 recycled
Exception stack ram used: 224
Never used ram: 76708
Tasks: NETWORK(ready,1972) HEAT(blocked,1248) CanReceiv(suspended,3424) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4528) IDLE(ready,76)
Owned mutexes:
Last reset 00:00:44 ago, cause: power up
Last software reset at 2020-09-22 22:34, reason: User, spinning module LinuxInterface, available RAM 76708 bytes (slot 0)
Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 39.2, current 39.6, max 39.7
Supply voltage: min 23.9, current 23.9, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
Driver 0: standstill, reads 24456, writes 0 timeouts 0, SG min/max not available
Driver 1: standstill, reads 24456, writes 0 timeouts 0, SG min/max not available
Driver 2: standstill, reads 24456, writes 0 timeouts 0, SG min/max not available
Driver 3: standstill, reads 24456, writes 0 timeouts 0, SG min/max not available
Driver 4: standstill, reads 24457, writes 0 timeouts 0, SG min/max not available
Driver 5: standstill, reads 24456, writes 0 timeouts 0, SG min/max not available
Date/time: 2020-09-22 22:34:11
Slowest loop: 4.22ms; fastest: 0.20ms
=== Storage ===
Free file entries: 10
Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP* is ready with "M122" in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon* is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 0.47ms; fastest: 0.01ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
HTTP sessions: 0 of 8- Ethernet -
State: disabled
Error counts: 0 0 0 0 0
=== CAN ===
Messages sent 20, longest wait 0ms for type 0
=== Linux interface ===
State: 0, failed transfers: 3
Last transfer: 18ms ago
RX/TX seq numbers: 539/540
SPI underruns 3, overruns 3
Number of disconnects: 0
Buffer RX/TX: 0/0-0
=== Duet Control Server ===
Duet Control Server v3.1.1
Code buffer space: 4096
Configured SPI speed: 8000000 Hz
Full transfers per second: 0.02
M98 P"config.g"
Error: M569: Response timeout: CAN addr 1, req type 6018, RID=12
Error: M350: Response timeout: CAN addr 1, req type 6021, RID=13
Error: M906: Response timeout: CAN addr 1, req type 6017, RID=14
Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
Error: M308: Response timeout: CAN addr 1, req type 6011, RID=19
Error: M950: Response timeout: CAN addr 1, req type 6026, RID=20
Error: M307: Heater 1 not found
Error: M950: Response timeout: CAN addr 1, req type 6027, RID=22
Error: M950: Response timeout: CAN addr 1, req type 6027, RID=24
Error: M106: Fan number 1 not found - Ethernet -
I have Duet3 and Toolboard with BMG and Mosquito Magnum + BL-touch
I have follow all speps frome this guide.
I did not changed the CAN address of ToolboardSending M115 B121 give me :
Board TOOL1LC firmware 3.1.0 (2020-05-15b1) -
@dk then you need to go through your config.g and change all references to CAN address 1 to 121, eg
Changes to:
M569 P121.0 S1 ; physical drive 121.0 goes forwards
