Solved Multiple Errors Duet3
@dk said in Multiple Errors Duet3:
Now I trying to figure out how to get BL-touch on 1LC Tool board get to work. It can't be done through https://configurator.reprapfirmware.org isn't it?
For physical connections, see https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board#Section_Connecting_a_BL_Touch
The configuration tool can produce the code, but doesn't set the CAN address, and I've noticed an error in the input pin drop down. So you'll need to edit config.g afterwards. Setting the following:
and
Produces:
; Z-Probe M950 S0 C"1.io0.out" ; create servo pin 0 for BLTouch M558 P9 C"^1.temp1" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
Assuming CAN address is 121, change this to:
; Z-Probe M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch M558 P9 C"^121.io0.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
Not sure if you actually need the pull-up resistor ^, but shouldn't hurt. Test and report back!
@droftarts said in Multiple Errors Duet3:
All Duet 3 ioX.in ports have permanent pullup resistors, on the main board and on expansion boards. So you never need to use ^ in the name. We recommend that you do not, because enabling it reduces the noise margin..
@droftarts Unfortunately, this didn't help. I tried with and without ^. BL-touch lights up in red but does not extend.
Can I find somewhere configuration files for any real working Delta printer on Duet3 with Tool board? This would help me a lot in setting up my printer. -
@dk Please post your config files so we can see what you have now.
Every time after reboot I get Error messages :
Error: M950: Response timeout: CAN addr 1, req type 6027, RID=8
Error: M106: Fan number 0 not found
Error: M950: Response timeout: CAN addr 1, req type 6027, RID=10
Error: M106: Fan number 1 not foundAnd when I push Home all only one motor moves.
Config.g
; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Sep 01 2020 22:07:15 GMT-0400 (EDT); General preferences
M550 P"Duet 3" ; set printer name
M665 R240 L460 B190 H750 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Drives
M569 P0.1 S0 ; physical drive 0.1 goes forwards
M569 P0.2 S0 ; physical drive 0.2 goes forwards
M569 P1.0 S1 ; physical drive 1.0 goes forwards
M584 X0.0 Y0.1 Z0.2 E1.0 ; set drive mapping
M92 X160.00 Y160.00 Z160.00 E415.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E800.00 ; set maximum instantaneous speed changes (mm/min)
M203 X3000.00 Y3000.00 Z3000.00 E600.00 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z3000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1600 Y1600 Z1600 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 S1 P"io0.in" ; configure active-high endstop for HIGH end on X via pin io0.in
M574 Y2 S1 P"io1.in" ; configure active-high endstop for HIGH end on Y via pin io1.in
M574 Z2 S1 P"io2.in" ; configure active-high endstop for HIGH end on Z via pin io2.in; Z-Probe
M558 P9 C"121.io0.in" H5 F120 T1000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X20 Y25 Z3 ; set Z probe trigger value, offset and trigger height
M557 R160 S40 ; define mesh grid; Heaters
M308 S0 P"temp3" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp3
M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
M308 S1 P"1.temp0" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin 1.temp0
M950 H1 C"1.out0" T1 ; create nozzle heater output on 1.out0 and map it to sensor 1
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"1.out2" Q500 ; create fan 0 on pin 1.out2 and set its frequency
M950 F1 C"1.out1" Q500 ; create fan 1 on pin 1.out1 and set its frequency
; homedelta.g
; called to home all towers on a delta printer
G91 ; relative positioning
G1 H1 X760 Y760 Z760 F1800 ; move all towers to the high end stopping at the endstops (first pass)
G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
G1 Z-5 F3600 ; move down a few mm so that the nozzle can be centred
G90 ; absolute positioning
G1 X0 Y0 F3600 ; move X+Y to the centre; deployprobe.g
; called to deploy a physical Z probe
; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Sep 01 2020 22:07:15 GMT-0400 (EDT)M950 S0 C"121.io0.out"
M280 P0 S10 ; deploy BLTouch; retractprobe.g
; called to retract a physical Z probe
M280 P0 S90 ; retract BLTouch -
Can you send M122 and M98 P"config.g" and post the results?
@dk you have a Duet 3, and a Toolboard, correct? Did you follow the steps in this guide: https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board
Have you changed the CAN address of your Toolboard? And if so, what to? See https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board#Section_Set_the_CAN_addressWhatever it’s set to, at the moment you have some commands referring to CAN address 1 (extruder motor, hit end heater, fan etc), and some as CAN address 121, which is the default (BLTouch). Also, it may need a firmware update (further up in the document linked above).
@Phaedrux
M122
RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
Board ID: 08DJM-956L2-G43S4-6JTDJ-3SJ6S-986GH
Used output buffers: 1 of 40 (21 max)
Static ram: 154604
Dynamic ram: 161404 of which 276 recycled
Exception stack ram used: 224
Never used ram: 76708
Tasks: NETWORK(ready,1972) HEAT(blocked,1248) CanReceiv(suspended,3424) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4528) IDLE(ready,76)
Owned mutexes:
Last reset 00:00:44 ago, cause: power up
Last software reset at 2020-09-22 22:34, reason: User, spinning module LinuxInterface, available RAM 76708 bytes (slot 0)
Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 39.2, current 39.6, max 39.7
Supply voltage: min 23.9, current 23.9, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
Driver 0: standstill, reads 24456, writes 0 timeouts 0, SG min/max not available
Driver 1: standstill, reads 24456, writes 0 timeouts 0, SG min/max not available
Driver 2: standstill, reads 24456, writes 0 timeouts 0, SG min/max not available
Driver 3: standstill, reads 24456, writes 0 timeouts 0, SG min/max not available
Driver 4: standstill, reads 24457, writes 0 timeouts 0, SG min/max not available
Driver 5: standstill, reads 24456, writes 0 timeouts 0, SG min/max not available
Date/time: 2020-09-22 22:34:11
Slowest loop: 4.22ms; fastest: 0.20ms
=== Storage ===
Free file entries: 10
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP* is ready with "M122" in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon* is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 0.47ms; fastest: 0.01ms
HTTP sessions: 0 of 8- Ethernet -
State: disabled
Error counts: 0 0 0 0 0
=== CAN ===
Messages sent 20, longest wait 0ms for type 0
=== Linux interface ===
State: 0, failed transfers: 3
Last transfer: 18ms ago
RX/TX seq numbers: 539/540
SPI underruns 3, overruns 3
Number of disconnects: 0
Buffer RX/TX: 0/0-0
=== Duet Control Server ===
Duet Control Server v3.1.1
Code buffer space: 4096
Full transfers per second: 0.02
M98 P"config.g"
Error: M569: Response timeout: CAN addr 1, req type 6018, RID=12
Error: M350: Response timeout: CAN addr 1, req type 6021, RID=13
Error: M906: Response timeout: CAN addr 1, req type 6017, RID=14
Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
Error: M308: Response timeout: CAN addr 1, req type 6011, RID=19
Error: M950: Response timeout: CAN addr 1, req type 6026, RID=20
Error: M307: Heater 1 not found
Error: M950: Response timeout: CAN addr 1, req type 6027, RID=22
Error: M950: Response timeout: CAN addr 1, req type 6027, RID=24
Error: M106: Fan number 1 not found - Ethernet -
I have Duet3 and Toolboard with BMG and Mosquito Magnum + BL-touch
I have follow all speps frome this guide.
I did not changed the CAN address of ToolboardSending M115 B121 give me :
Board TOOL1LC firmware 3.1.0 (2020-05-15b1) -
@dk then you need to go through your config.g and change all references to CAN address 1 to 121, eg
Changes to:
M569 P121.0 S1 ; physical drive 121.0 goes forwards
Changed. I still cant extrude
Are there any errors now if you run
M98 P"config.g"
? You need to reset Duet for changes to config.g to take effect, or run M98 P"config.g". If there are still errors, please post your current config.g, along with the list of errors reported.Assuming everything is set correctly with no errors, to extrude you either need to heat up the hot end to a temperature above 160C, or allow cold extrusion with
M302 P1
(see https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M302_Allow_cold_extrudes).For the probe, you have already defined the servo pin with
in config.g, so it's unnecessary (and may cause confusion if you change the configuration later) in deployprobe.g and retractprobe.g. Delete the M950 line in these files.Does the BLTouch do a self-test at startup? It should extend and retract the pin itself twice if it has power (which you say it does as the red LED comes on). If deployprobe.g and retractprobe.g still don't work, try inverting the input in config.g with '!', ie
M950 S0 C"!121.io0.out"
. You can either send this command in the gcode console (and add it to config.g if it works), edit config.g and reset Duet, or edit config.g and run M98 P"config.g" for the command to take effect. If it still isn't functioning, check the wiring, and post a picture of how it's wired.@dk said in Multiple Errors Duet3:
We don't have a machine with this configuration to share a working config with you. Many home-built printers are bespoke, and it's possible that you are the first with this combination! If there are any other users who see this and have a similar setup, please share your config files.
I have change Toolboard address to 20 following this procedure See https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board#Section_Set_the_CAN_address , and change M569 P20.0 S1
Now I can extrude.
I also change address for heater and Thermistor and gget them work to!
M308 S1 P"20.temp0" Y"thermistor" T500000 B4723 C1.19622e-7
M950 H1 C"20.out0" T1And I also change address for BL-touch (with and without ! ) and delete M950 line from deployprobe.g and retractprobe.g files. But it's still don't work.
M950 S0 C"20.io0.out" ; create servo pin 0 for BLTouch
M558 P9 C"20.io0.in" H5 F120 T1000 ; set Z probe type to bltouch and the dive height + speeds
M557 R160 S40 ; define mesh gridAnd BLTouch does not self-test at startup. Just steady red light. I connect it to Duet2 I have on another printer and it perform startup test as usual.
M98 P"config.g" give me just one warning (no Errors any more)
Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365CSo I assume the problem is in Z-probe settings
Does the BLTouch power up if you connect it directly to the main board and change your pin names accordingly?
@Phaedrux
Yes, it does -
Do you have a different BLTouch that isn't V3.1 to test with on the tool board?
I have 3 BL-touch 3.1 And I test all 3 of them. They all work with IO_7 and doesn't work with Toolboard
@Phaedrux
When I change the white and yellow wire in places, BL-touch does self-test at startup. And Status window DWC shows Z-Probe 1000
But it still does not work. I can't extract pin. M280 P0 S10 has no effect.
And G32 give Error: Z probe already triggered at start of probing moveZ-Probe settings from Config.g:
M557 R160 S40 ; define mesh grid; deployprobe.g
What do you mean by this?
@Phaedrux
Swap these two wires
