    BlTouch not triggering, tried everything
    111
    • ChrisF3D
      ChrisF3D last edited by
      I purchased the latest BlTouch but for the life of me can't get it to work. Got all the latest firmware that I know off.
      Using the Duet 2 wifi.
      Heater PWM 7 input
      Everywhere i look it says something different so im really quite stuck...
      attached is my config file, if someone could point me as to where im going wrong i will be so thankful!
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Sep 14 2020 09:23:59 GMT+0100 (British Summer Time)
      M550 P"XL Printer"                                 ; set printer name
      M569 P0 S1                                         ; physical drive 0 goes forwards
      M569 P1 S1                                         ; physical drive 1 goes forwards
      M569 P2 S1                                         ; physical drive 2 goes forwards
      M569 P7 S1                                         ; physical drive 7 goes forwards
      M584 X0 Y1:4 Z2 E7                                   ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E150.00                  ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
      M906 X800 Y1500:1500 Z800 E800 I30                      ; set motor currents (mA) and motor idle factor in per cent
      M208 X30 Y0 Z0 S1                                  ; set axis minima
      M208 X630 Y350 Z350 S0                             ; set axis maxima
      M574 X1 S0 P"!xstop"                               ; configure active-high endstop for low end on X via pin !xstop
      M574 Y1 S0 P"!ystop"                               ; configure active-high endstop for low end on Y via pin !ystop
      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
      M950 S0 C"exp.heater7"                             ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000                ; set Z probe type to bltouch and the dive height + speeds
      G31 P1000 X0 Y40 Z2.5                              ; set Z probe trigger value, offset and trigger height
      M557 X45:215 Y15:195 S50                           ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
      M307 H7 A-1 C-1 D-1
      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
      peter247 1 Reply Last reply Reply Quote 0
      • Veti
        Veti last edited by
        post your retract and deploy script
        • peter247
          peter247 @ChrisF3D last edited by peter247
          @ChrisF3D
          1/ what version of the firmware are you using . try M122
          ( you are on version 3 of the config.g , but have you upgraded to version 3 firmware )
          2/ Are you getting the red light and getting the in and out power on self test
          • ChrisF3D
            Supposedly auto-generated from their new tools.
            ; deployprobe.g
            ; called to deploy a physical Z probe
            M280 P0 S10 ; deploy BLTouch
            ; retractprobe.g
            ; called to retract a physical Z probe
            M280 P0 S90 ; retract BLTouch
            • ChrisF3D
              Board: Duet WiFi 1.02 or later (duetwifi102)
              Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.03 (2019-06-13b2)
              Duet WiFi Server Version: 1.23
              • Stephen6309
                Stephen6309 last edited by
                You config is for the 3.xx firmware version.
                • peter247
                  @ChrisF3D
                  YEP , you are running the version 3 config file , but still running version 2 firmware ..
                  upgrade to version 3 firmware or use the version 2 configurator
                  • ChrisF3D
                    Ive tried upgrading to 3.0 but it doesnt seem to update the firmware... I used "duet2and3firmware-3.1.1.zip" and uploaded it
                    • peter247
                      @ChrisF3D
                      You need to upgrade to I THINK version 3 ? , then 3.1.1 .
                      I know you can't do it in one go !!!
                      • ChrisF3D
                        Lifesavers!!! yes 3.0 first worked!
                        Thank you all so much... hopefully, it's plain sailing now!
                        peter247 2 Replies Last reply Reply Quote 0
                        • peter247
                          This post is deleted!
                          • peter247
                            @ChrisF3D
                            The bits which you normally get it wrong is offsets ( G31 ) , Which you say is level on the X axis , but the probe is 40mm behind the nozzle on the Y axis ?
                            And how you home !!! You need to use G30 to home Z
                              G31 P1000
                              Try G31 P25 instead.
