    Log temperatures for post analysis
    299
    • MaracMB
      MaracMB last edited by
      I am testing a bunch of things and would like to log and further analyse the data on temperatures in Excel
      So how do i log and export temperature readings?
      • A Former User
        A Former User last edited by
        no built in function i'm affraid; which board and firmware version?
        MaracMB 1 Reply Last reply Reply Quote 0
        • MaracMB
          MaracMB @Guest last edited by
          @bearer duet wifi+duex5 on latest fw 3
          I thought there is somesort of debugging/logging function that generates log (m929 ?).
          Would be nice if it just logged temperatures on sensors like every 0.5 or 1 second reading interval.. any extra parameters would be supercool.
          Example #1
          I am inserting a thermistor in a hemera’s heatsink. Just looking at DWC and logging stuff manually is a bad way of doing it. Log would show the gradual increase (or not) throughout a print.
          #2
          Ambient temperature in relation to buildspace temperature throughout a 24 hour print.
          List goes on.
          That would be very helpful stuff
          I don’t have explicit coding skills, but friends do, so is there an API for this? So a separate service would just read and log from DWC?
          A Former User 1 Reply Last reply Reply Quote 0
          • A Former User
            A Former User @MaracMB last edited by
            @MaracMB said in Log temperatures for post analysis:
            m929 only logs start/stop of prints, so no good for graphing temps.
            you could use daemon.g with M118 to send a message containing a object model refrence to serial or telnet, and collect the data there; or use M408 from serial or telnet to poll data from the duet - or M409 for a more targeted query of the object model
            M111 enables debug info, not sure of contents and intervals - might affect operation but you could poke it and see what you find?
            you can also query the duet with M408/M409 using HTTP, but in generall it'll be a bit of DIY i think,
            tampermonkey to capture the temp graph from DWC might be an option; there have been a few other threads on the same topic, maybe search to see if I missed someting
            • MaracMB
              @bearer thank you. At least i have some options now. I think tampermonkey would be best as it wouldn't load the duet at all. fan tastic 🙂
              • A Former User
                btw if you missed this, it might be of interest?
                https://forum.duet3d.com/topic/18688/firmware-package-3-2beta1-released?_=1600243427741
                although the post wasn't clear if it would work with a duet2 running rrf3.2 or just a duet3 in standalone mode - the mention of dsf that runs on the sbc made it a bit confusing.
                • MaracMB
                  MaracMB last edited by MaracMB
                  oooook... that confused the hell out of me.
                  i'm no expert but i guess this would then need raspberry pi and not sure if this even runs on Duet2... as you said. confusion is building up.
                  for a simple guy like me, tampermonkey is best bet.
                  • A Former User
                    sleep
                    tell me more about this thing you call sleep?:P
                    anyways, if you could share your work I'm sure others will appreciate it. as mentioned there has been a couple of similar threads recently. godspeed!
                    • MaracMB
                      i edited/deleted because i thought you won't get it 🙂
                      i'll call my coding brain friend and will share if anything comes out of this.
                      Thank you for a very constructive debate.
                      • MaracMB
                        @bearer @Phaedrux @dc42
                        Sorry for nagging, but could i get a link to an API for this for my programmer?
                        He said he’ll write in python. I guess that’s ok?
                        • A Former User
                          try the links in this thread?
                          https://forum.duet3d.com/post/178347
                          MaracMB 1 Reply Last reply Reply Quote 1
                          • MaracMB
                            @bearer found it. thank you
