    Error: attempting to extrude with no tool selected
    67
    10.0k
    • theshaboboundefined
      theshabobo
      Hi all. I just did the Duet 2 Wifi Upgrade on my printer and I am getting this error when I print any file generated by Simplify3D.
      Note: This issue only occurs with S3D, not any other Slicers.
      History: The printer was not having this issue with S3D before the Duet 2 Wifi conversion.
      This issue will happen at random points during any print. It starts the print fine, then at a random point it will throw this error. Even with the same file, it's random! I have had it happen halfway thru the 1st layer, or on the 10th layer, or the 50th while using the same .gcode file.
      There is only 1 extruder, labeled as T0. In the S3D Profile. T1 is the heated bed.
      Printer Specs:
      Model: Anycubic Predator
      Duet 2 Wifi
      Paneldue 7i
      Smarteffector
      BMG extruder
      Duet Version: RepRap Firmware 3.1.1
      S3D version: 4.1.2
      Please Help.
      • Vetiundefined
        Veti
        Add a T0 to the end of you config.g
          theshabobo
          I did, and the issue still happens.
            Provide a sample gcode file and your config.g please.
              theshabobo
              End of Config.g
              M563 P0 D0 H1                               				; Define tool 0 and fan 0
              G10 P0 X0 Y0 Z0                             				; Set tool 0 axis offsets
              G10 P0 R0 S0                                				; Set initial tool 0 active and standby temperatures to 0C
              T0															; select Tool 0
              ;Extrusion settings
              M593 F39.1													;Resonance Frequency WIP
              ;Nonlinear extrusion
              ;M592 D0 A-0.057410915 B0.015877315							;Nonlinear extrusion WIP
              M501														;load config-override
              ;Pressure Advance
              ;M572 D0 S0.22												;Rosa Silk PLA
              ;M572 D0 S0.15												;PLA
              ;M572 D0 S0.492												;PETG White 230
              M572 D0 S0.08												;0.8 PLA
              ; Retraction
              M207 S2 F3000 R0 T2200 Z0									;0.8 PLA
              ;M207 S2 F1400 R0 T1200 Z0									;0.8 PETG
              ;M207 S2 F3000 R0 T2500 Z0.0								;Silk PLA
              ;M207 S4 F3600 R0 T2400 Z0.2			       				;0.8 PLA
              ;M207 S2 F3600 R0 T2400 Z0.0		   						;ABS
              ;M207 S2 F3000 R0 T2500 Z0.0								;Blue Thumann
              ;M207 S4 F3000 R0 T2400 Z0.0								;PETG
              ;M207 S4 F1500 R0 T1200 Z0.0								;TPU TEST
              T0
              Sample G-code file:
              ; G-Code generated by Simplify3D(R) Version 4.1.2
              ; Sep 17, 2020 at 1:27:27 PM
              ; Settings Summary
              ;   processName,Process1
              ;   applyToModels,PredatorSpoolSupport_ExtendedGuide
              ;   profileName,Predator_Hatchbox_PETG (modified)
              ;   profileVersion,2020-09-14 19:46:39
              ;   baseProfile,M2-E3Dv6-0.4mm
              ;   printMaterial,PLA
              ;   printQuality,Medium
              ;   printExtruders,
              ;   extruderName,Left Extruder
              ;   extruderToolheadNumber,0
              ;   extruderDiameter,0.4
              ;   extruderAutoWidth,1
              ;   extruderWidth,0.48
              ;   extrusionMultiplier,1
              ;   extruderUseRetract,1
              ;   extruderRetractionDistance,1.6
              ;   extruderExtraRestartDistance,0
              ;   extruderRetractionZLift,0.6
              ;   extruderRetractionSpeed,3000
              ;   extruderUseCoasting,1
              ;   extruderCoastingDistance,0
              ;   extruderUseWipe,1
              ;   extruderWipeDistance,5
              ;   primaryExtruder,0
              ;   layerHeight,0.25
              ;   topSolidLayers,5
              ;   bottomSolidLayers,5
              ;   perimeterOutlines,3
              ;   printPerimetersInsideOut,1
              ;   startPointOption,2
              ;   startPointOriginX,0
              ;   startPointOriginY,0
              ;   sequentialIslands,0
              ;   spiralVaseMode,0
              ;   firstLayerHeightPercentage,95
              ;   firstLayerWidthPercentage,100
              ;   firstLayerUnderspeed,0.4
              ;   useRaft,0
              ;   raftExtruder,0
              ;   raftTopLayers,1
              ;   raftBaseLayers,1
              ;   raftOffset,5
              ;   raftSeparationDistance,0.4
              ;   raftTopInfill,80
              ;   aboveRaftSpeedMultiplier,0.3
              ;   useSkirt,1
              ;   skirtExtruder,0
              ;   skirtLayers,1
              ;   skirtOutlines,2
              ;   skirtOffset,5
              ;   usePrimePillar,0
              ;   primePillarExtruder,999
              ;   primePillarWidth,12
              ;   primePillarLocation,7
              ;   primePillarSpeedMultiplier,1
              ;   useOozeShield,0
              ;   oozeShieldExtruder,999
              ;   oozeShieldOffset,2
              ;   oozeShieldOutlines,1
              ;   oozeShieldSidewallShape,1
              ;   oozeShieldSidewallAngle,30
              ;   oozeShieldSpeedMultiplier,1
              ;   infillExtruder,0
              ;   internalInfillPattern,Triangular
              ;   externalInfillPattern,Rectilinear
              ;   infillPercentage,30
              ;   outlineOverlapPercentage,30
              ;   infillExtrusionWidthPercentage,103
              ;   minInfillLength,2
              ;   infillLayerInterval,1
              ;   internalInfillAngles,0,60,-60
              ;   overlapInternalInfillAngles,1
              ;   externalInfillAngles,45,135
              ;   generateSupport,1
              ;   supportExtruder,0
              ;   supportInfillPercentage,15
              ;   supportExtraInflation,1
              ;   supportBaseLayers,3
              ;   denseSupportExtruder,0
              ;   denseSupportLayers,3
              ;   denseSupportInfillPercentage,100
              ;   supportLayerInterval,1
              ;   supportHorizontalPartOffset,0.45
              ;   supportUpperSeparationLayers,4
              ;   supportLowerSeparationLayers,4
              ;   supportType,0
              ;   supportGridSpacing,1
              ;   maxOverhangAngle,60
              ;   supportAngles,0
              ;   temperatureName,Primary Extruder,Heated Bed
              ;   temperatureNumber,0,1
              ;   temperatureSetpointCount,2,2
              ;   temperatureSetpointLayers,1,2,1,2
              ;   temperatureSetpointTemperatures,240,240,80,80
              ;   temperatureStabilizeAtStartup,1,1
              ;   temperatureHeatedBed,0,1
              ;   fanLayers,1
              ;   fanSpeeds,0
              ;   blipFanToFullPower,1
              ;   adjustSpeedForCooling,1
              ;   minSpeedLayerTime,8
              ;   minCoolingSpeedSlowdown,30
              ;   increaseFanForCooling,0
              ;   minFanLayerTime,45
              ;   maxCoolingFanSpeed,100
              ;   increaseFanForBridging,0
              ;   bridgingFanSpeed,100
              ;   use5D,1
              ;   relativeEdistances,1
              ;   allowEaxisZeroing,1
              ;   independentExtruderAxes,0
              ;   includeM10123,0
              ;   stickySupport,1
              ;   applyToolheadOffsets,0
              ;   gcodeXoffset,0
              ;   gcodeYoffset,0
              ;   gcodeZoffset,0
              ;   overrideMachineDefinition,1
              ;   machineTypeOverride,1
              ;   strokeXoverride,260
              ;   strokeYoverride,260
              ;   strokeZoverride,410
              ;   originOffsetXoverride,130
              ;   originOffsetYoverride,130
              ;   originOffsetZoverride,0
              ;   homeXdirOverride,-1
              ;   homeYdirOverride,-1
              ;   homeZdirOverride,1
              ;   flipXoverride,1
              ;   flipYoverride,-1
              ;   flipZoverride,1
              ;   toolheadOffsets,0,0|0,0|0,0|0,0|0,0|0,0
              ;   overrideFirmwareConfiguration,1
              ;   firmwareTypeOverride,RepRap (Marlin/Repetier/Sprinter)
              ;   GPXconfigOverride,r2
              ;   baudRateOverride,250000
              ;   overridePrinterModels,0
              ;   printerModelsOverride
              ;   startingGcode,G28 ; home all axes,G29 S1 ; use previous mesh calibration,
              ;   layerChangeGcode,
              ;   retractionGcode,
              ;   toolChangeGcode,
              ;   endingGcode,G28 ; home all axes,M106 S0 ; turn off cooling fan,M104 S0 ; turn off extruder,M140 S0 ; turn off bed,M84 ; disable motors
              ;   exportFileFormat,gcode
              ;   celebration,0
              ;   celebrationSong,Star Wars
              ;   postProcessing,
              ;   defaultSpeed,3200
              ;   outlineUnderspeed,0.5
              ;   solidInfillUnderspeed,0.75
              ;   supportUnderspeed,0.75
              ;   rapidXYspeed,12000
              ;   rapidZspeed,1200
              ;   minBridgingArea,10
              ;   bridgingExtraInflation,1
              ;   bridgingExtrusionMultiplier,1.4
              ;   bridgingSpeedMultiplier,1.25
              ;   useFixedBridgingAngle,0
              ;   fixedBridgingAngle,0
              ;   applyBridgingToPerimeters,0
              ;   filamentDiameters,1.75|1.75|1.75|1.75|1.75|1.75
              ;   filamentPricesPerKg,24|26|26|26|26|26
              ;   filamentDensities,1.25|1.25|1.25|1.25|1.25|1.25
              ;   useMinPrintHeight,0
              ;   minPrintHeight,12
              ;   useMaxPrintHeight,0
              ;   maxPrintHeight,15
              ;   useDiaphragm,0
              ;   diaphragmLayerInterval,20
              ;   robustSlicing,1
              ;   mergeAllIntoSolid,0
              ;   onlyRetractWhenCrossingOutline,1
              ;   retractBetweenLayers,1
              ;   useRetractionMinTravel,0
              ;   retractionMinTravel,3
              ;   retractWhileWiping,1
              ;   onlyWipeOutlines,1
              ;   avoidCrossingOutline,0
              ;   maxMovementDetourFactor,3
              ;   toolChangeRetractionDistance,0
              ;   toolChangeExtraRestartDistance,0
              ;   toolChangeRetractionSpeed,360
              ;   externalThinWallType,1
              ;   internalThinWallType,2
              ;   thinWallAllowedOverlapPercentage,0
              ;   singleExtrusionMinLength,1
              ;   singleExtrusionMinPrintingWidthPercentage,50
              ;   singleExtrusionMaxPrintingWidthPercentage,200
              ;   singleExtrusionEndpointExtension,0.2
              ;   horizontalSizeCompensation,0
              G90
              M83
              M106 S0
              M140 S80
              M190 S80
              M104 S240 T0
              M109 S240 T0
              G28 ; home all axes
              ; process Process1
              ; layer 1, Z = 0.237
              T0
              G1 E-1.6000 F3000
              ; feature skirt
              ; tool H0.237 W0.480
              G1 Z0.600 F1200
              G1 X4.089 Y-25.940 F12000
              G1 Z0.237 F1200
              G1 E1.6000 F3000
              G1 X4.911 Y-25.940 E0.0389 F1280
                theshabobo
                anyone have any ideas?
                • fcwiltundefined
                  fcwilt @theshabobo
                  @theshabobo said in Error: attempting to extrude with no tool selected:
                  When I use S3D, T0 is the temperature identifier for the heated bed and T1 is the temperature identifier for the extruder.
                  Have no idea if that would make a difference.
                    Post your full config.g.
                    Do the heaters work otherwise?
                    Does it set the temperatures and attain them before starting to print?
                    I'm not really up on S3D configuration.
                      theshabobo
                      @fcwilt I have tried switching the T0 and T1, did not work, heaters did not function properly.
                      @Phaedrux Yes the heaters work great actually. no heat creep and they pretty much stay on point even after the error is thrown.
                      Here is what it does physically:
                      Printing with PETG
                      1. Bed heats up to 80c
                      2. Nozzle heats up to 240c
                      3. Printer homes
                      4. Starts printing
                      5. At a random point in time, it will show the error.
                      6. During this time, the print head is still moving, the hotend is still staying at temp and the bed is staying at temp. The extruder does not move.
                      7. If I send a T0 it will start extruding again. and then stop at a random point in time.
                      I just tried it again in another slicer, and it did the same thing. So, I am now completely lost.
                      This is the full Config.g
                      G90                                         				; Send absolute coordinates...
                      M83                                         				; ...but relative extruder moves
                      M575 P1 B57600 S1 											;Set baud rate Duet Board
                      ; Delta Settings
                      M665 L440.49 R185 H405 B185.0 X0 Y0 Z0 						; Set delta radius, diagonal rod length, printable radius and homed height
                      M666 X0 Y0 Z0 A0.00 B0.00               			     	; Put your endstop adjustments here, or let auto calibration find them
                      M550 P"TWHPredator"		                     				; Set machine name
                      ;M551 P"T3chn0l0gy"                 							; Set password
                      M552 S1								          				; Enable network and acquire dynamic address via DHCP
                      M587 S"Darkweb" P"whatpassword" I192.168.1.253
                      M586 P0 S1                                  				; Enable HTTP
                      M586 P1 S0                                  				; Disable FTP
                      M586 P2 S0                                  				; Enable Telnet
                      M569 P0 S0	                                 				; Drive 0 goes backwards
                      M569 P1 S0                                  				; Drive 1 goes backwards
                      M569 P2 S0                                  				; Drive 2 goes backwards
                      M569 P3 S0                                  				; Drive 3 goes forwards
                      M584 X0 Y1 Z2 E3                                            ; set drive mapping
                      ;Stepper Configuration
                      M350 X16 Y16 Z16 E16 I1										; Configure microstepping with interpolation
                      M92 X80 Y80 Z80   											; Set steps per mm
                      M92 E91.0:91.0
                      M906 X2000 Y2000 Z2000  E1000 I13 							; Set motor currents (mA) and motor idle factor in per cent
                      M84 S30 													; Set idle timeout
                      ;Normal Speed
                      M566 X1200  Y1200  Z1200  E3600     	      	   			; Set JERK(mm/min)
                      M203 X18000 Y18000 Z18000 E10000 							; Set maximum speeds (mm/min) 18k is 300mm/s
                      M201 X3500  Y3500  Z3500  E3500    							; Set accelerations (mm/s^2)
                      ;M204 P2000 T3000											; set Print accel and travel accel
                      M208 Z0 S1                                  				; Set minimum Z
                      M574 X2 S1 P"xstop"											; configure active-high endstop for high end on X via pin xstop
                      M574 Y2 S1 P"ystop"                                 		; configure active-high endstop for high end on Y via pin ystop
                      M574 Z2 S1 P"zstop"                                 		; configure active-high endstop for high end on Z via pin zstop
                      ; M558 P8 F1200 R0.4 T5000 H2 A3 I1    			         	  	; Set Z probe type to switch and the dive height + speeds  3 Probe Iterations Inverted
                      M558 C"zprobe.in" P8 R0.4 F1200 H30 T5000
                      G31 P100 X0 Y0 Z-0.1			                 			; Set Z probe
                      M557 R175 S20                               				; Define mesh grid
                      ;Filament Sensor
                      M591 D0 P2 C"e1_stop" S1														;activate Filament Sensor
                      ; Bed Heater
                      M308 S0 A"Heated Bed" P"bedtemp" Y"thermistor" T100000 B4300 C0 R4700		; Set thermistor + ADC parameters for heater 0
                      M950 H0 C"bedheat" Q100 T0                      			         			; create bed heater output on bedheat and map it to sensor 0
                      M307 H0 A137.8 C533.3 D1.5 V24.3 B0                     					  	; Disable bang-bang mode for the bed heater and set PWM limit
                      M140 H0 P0																		; Create bed Heater
                      ; Extruder Heater
                      M308 S1 A"E3D V6" P"e0temp" Y"thermistor" T100000 B4300 C0 R4700		; Temperature Sensor
                      M950 H1 C"e0heat" T1                                							; create nozzle heater output on e0heat and map it to sensor 1
                      M143 H1 S280 A0                               									; Set temperature limit for heater 1 to 280C
                      ;Additional Sensors
                      M308 S2 A"Chamber" P"e1temp" Y"thermistor" T100000 B3800 C0
                      M950 F1 C"fan1" Q100                        	   			;HOTEND FAN create fan 1 on pin fan1 and set its frequency
                      M106 C"HotendFAN" P1 H1 T45                            		; set fan 1 value. Thermostatic control is turned on
                      M950 F0 C"fan0" Q24000 							;CPAP create fan 0 on pin fan0 and set its frequency !fan2+exp.pb6 with RPM readout on PB6
                      M106 C"PartCoolingFan" F65535 P0 S0 H-1 L0.1 ;X0.5     			; set fan 0 value. Thermostatic control is turned off L0.3 X1
                      T0															; select Tool 0
                      ;Extrusion settings
                      ;Pressure Advance
                      ;M572 D0 S0.15												;PLA
                      ; Retraction
                      T0
                        theshabobo
                        *bump
                        I re-did the config.g as below, and am still getting this issue.
                        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Sep 18 2020 09:00:56 GMT-0500 (Central Daylight Time)
                        G90                                            ; send absolute coordinates...
                        M550 P"twhpredator"                            ; set printer name
                        ; Delta Settings
                        M665 R185 L440.49 B175 H405                    ; Set delta radius, diagonal rod length, printable radius and homed height
                        M666 X0 Y0 Z0                                  ; put your endstop adjustments here, or let auto calibration find them
                        M551 P"********"                              ; set password
                        M552 S1                                        ; enable network
                        M586 P0 S1                                     ; enable HTTP
                        M586 P1 S0                                     ; disable FTP
                        M586 P2 S0                                     ; disable Telnet
                        M569 P0 S0                                     ; physical drive 0 goes backwards
                        M569 P1 S0                                     ; physical drive 1 goes backwards
                        M569 P2 S0                                     ; physical drive 2 goes backwards
                        M569 P3 S0                                     ; physical drive 3 goes forwards
                        M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                        M92 X80.00 Y80.00 Z80.00		               ; set steps per mm
                        M92 E91.0:91.0
                        M566 X1200.00 Y1200.00 Z1200.00 E1200.00       ; set maximum instantaneous speed changes (mm/min)
                        M203 X18000.00 Y18000.00 Z18000.00 E1200.00    ; set maximum speeds (mm/min)
                        M201 X1000.00 Y1000.00 Z1000.00 E1000.00       ; set accelerations (mm/s^2)
                        M906 X1000 Y1000 Z1000 E800 I30                ; set motor currents (mA) and motor idle factor in per cent
                        M208 Z0 S1                                     ; set minimum Z
                        M558 P8 C"zprobe.in" R0.4 H30 F1200 T5000            ; set Z probe type to unmodulated and the dive height + speeds
                        G31 P500 X0 Y0 Z0                            ; set Z probe trigger value, offset and trigger height
                        M557 R175 S20                                  ; define mesh grid
                        ;Filament Sensor
                        M308 S0 A"Heated Bed" P"bedtemp" Y"thermistor" T100000 B4300 C0 R4700 ; configure sensor 0 as thermistor on pin bedtemp
                        M307 H0 A137.8 B0 C533.3 D1.5                  ; enable bang-bang mode for the bed heater and set PWM limit
                        M140 H0 P0                                     ; map heated bed to heater 0
                        M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                        M308 S1 A"E3DV6" P"e0temp" Y"thermistor" T100000 B4300 C0 R4700  ; configure sensor 1 as thermistor on pin e0temp
                        ;M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
                        M143 H1 S280 A0
                        M563 P0 S"E3DV6" D0 H1 F0                      ; define tool 0
                        G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                        G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                        M575 P1 S1 B57600                              ; enable support for PanelDue
                        M501                                           ; load saved parameters from non-volatile memory
                        T0                                             ; select first tool
                        JoergS5undefined 1 Reply Last reply Reply Quote 0
                          Do you see any heater error messages in the console?
                          Have you PID tuned the heaters?
                          It almost seems as if the part cooling fan is causing a heater fault.
                          What does your temp graph look like around the time that it happens?
                            theshabobo
                            @Phaedrux
                            Thanks for the reply!
                            No heater errors. I have not PID Tuned, however the temp graph is stable, basically almost a straight line. The issue is that the extruder stops extruding until I send a T0.
                            I manually edited that gcode to add a T0 to each layer and it printed, however this is not a fix.
                              PID tune the heaters.
                              I can't see why it would deselect a tool unless there is a tool change command in the gcode file being printed, or there's been a fault.
                                theshabobo
                                no faults, no tool change commands.
                                One thing I just noticed, the PanelDue 7i displays at random during a print, a bunch of random errors, like "Error: Bad command R12*27"
                                These errors do not show up in any console.
                                  Interesting.
                                  What baud rate is your paneldue using? I've seen that when experimenting with high baud rates than the default.
                                  I've also seen it where interference was getting picked up and generating spurious commands. Are you using the 10 pin cable or the 4 wire cable? How long? And is it routed near any stepper motor wiring?
                                  Also can you download the gcode file from the DWC and check it for anything corrupted looking?
                                  If you try simulating the file do you get any errors?
                                    theshabobo
                                    PID's now tuned, I'll try the print again.
                                    I'm using only the standard 4 pin cable, I believe it's 1 meter long. The cable path is not near a stepper motor, about 6-in away from the nearest motor.
                                    I ran a simulation, no errors.
                                    I looked at a file from the DWC, and it does not seem that any of the commands are corrupted.
                                    • JoergS5undefined
                                      JoergS5 @theshabobo
                                      M92 E91.0:91.0
                                      you have one extruder, but two settings in M92. Maybe this produces that an extruder has no tool.
                                        theshabobo
                                        I have removed that line. I'll run another test print to verify.
                                          theshabobo
                                          Update: ran a test print, same issue.
                                          I am now downgrading versions of the duet firmware to 3.0 to see if that resolves it.
                                            My best guess is that corrupt data received on the PanelDue port is causing the problem. The cable resistance must be no more than 0.1 ohms per conductor. If the cable runs close to stepper motor cables, it must be shielded.
                                            lifeformundefined 1 Reply Last reply Reply Quote 0
