Setting bed origin
  • I don't know why but I have problems setting my bed origin which should be in the front left corner. Printer is a Corexy with Duet 3 running the latest version. X and Y stop is at min. When I move the nozzle to the front left corner coordinates are X77 Y84. What do I have to do to define this point as 0,0? I already read the "Centering_the_bed_or_setting_the_bed_origin" Wiki guide but for any reason I don't get it to work. I think my brain is just a little bit twisted 🤒
    config.g
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Aug 10 2020 22:00:49 GMT+0200 (Central European Summer Time)
    G90                                                      ; send absolute coordinates...
    M83                                                      ; ...but relative extruder moves
    M550 P"duet3"                                            ; set printer name
    M669 K1                                                  ; select CoreXY mode
    ; Drives                                                 ; X:0.0, Y:0.1, E:0.2, Z_left_rear:0.3, Z_left_front:0.4, Z_right:0.5
    M569 P0.0 S0                                             ; physical drive 0.0 goes forwards
    M569 P0.1 S0                                             ; physical drive 0.1 goes forwards
    M569 P0.2 S1                                             ; physical drive 0.2 goes forwards
    M569 P0.3 S0                                             ; physical drive 0.3 goes forwards
    M569 P0.4 S1                                             ; physical drive 0.4 goes forwards
    M569 P0.5 S1                                             ; physical drive 0.5 goes forwards
    M584 X0.0 Y0.1 Z0.3:0.4:0.5 E0.2                         ; set drive mapping
    M350 X16 Y16 Z16 E16 I1                                  ; configure microstepping with interpolation
    M92 X200.00 Y200.00 Z800.00 E405.18                      ; set steps per mm
    M566 X600.00 Y600.00 Z24.00 E120.00                      ; set maximum instantaneous speed changes (mm/min)
    M203 X18000.00 Y18000.00 Z6000.00 E1200.00               ; set maximum speeds (mm/min)
    M201 X3000.00 Y3000.00 Z100.00 E5000.00                  ; set accelerations (mm/s^2)
    M906 X1600 Y1600 Z1600 E1600 I30                         ; set motor currents (mA) and motor idle factor in per cent
    M84 S30                                                  ; Set idle timeout
    ; Three axis setup - leadscrew positions
    M671 X11:11:426 Y355:51:205 S20			                 ; Set up three Z-axis location
    M208 X77 Y84 Z0 S1                                       ; set axis minima
    M208 X391 Y374 Z400 S0                                   ; set axis maxima
    M574 X1 S1 P"io3.in"                                     ; configure active-high endstop for low end on X via pin io3.in
    M574 Y1 S1 P"io4.in"                                     ; configure active-high endstop for high end on Y via pin io4.in
    M950 S0 C"io7.out"                                       ; create servo pin 0 for BLTouch
    M558 P9 C"^io7.in" H10 F500 T6000                        ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X36.47 Y-4 Z1.030                               ; set Z probe trigger value, offset and trigger height
    M557 X70:335 Y55:335 P6:6                                ; define mesh grid
    M308 S0 P"temp1" Y"thermistor" T95000 B3950              ; configure sensor 0 as thermistor on pin temp1
    M950 H0 C"out2" T0                                       ; create bed heater output on out1 and map it to sensor 0
    M307 H0 B0 S1.00                                         ; disable bang-bang mode for the bed heater and set PWM limit
    M140 H0                                                  ; map heated bed to heater 0
    M143 H0 S120                                             ; set temperature limit for heater 0 to 120C
    M308 S1 P"temp0" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin temp0
    M950 H1 C"out3" T1                                       ; create nozzle heater output on out2 and map it to sensor 1
    M307 H1 B0 S1.00                                         ; disable bang-bang mode for heater  and set PWM limit
    ;M950 F0 C"out4" Q25000                                   ; create fan 0 on pin out4 and set its frequency
    M950 F0 C"!out4+out4.tach"
    M106 P0 S1 H-1 I1 C"Hotend"                              ; set fan 0 value. Thermostatic control is turned off
    M950 F1 C"out5" Q500                                     ; create fan 1 on pin out5 and set its frequency
    M106 P1 S0 H-1 C"Bed".                                   ; set fan 1 value. Thermostatic control is turned on
    M950 F2 C"out6" Q500                                     ; create fan 2 on pin out6 and set its frequency
    M106 P2 S0.5 H-1 C"Board"                                ; set fan 2 value. Thermostatic control is turned off
    M950 F3 C"out7" Q500                                     ; create fan 3 on pin out7 and set its frequency
    M106 P3 S1 H-1 C"SBC"                                    ; set fan 3 value. Thermostatic control is turned off
    M563 P0 S"Hotend" D0 H1 F1                               ; define tool 0
    G10 P0 X0 Y0 Z0                                          ; set tool 0 axis offsets
    G10 P0 R0 S0                                             ; set initial tool 0 active and standby temperatures to 0C
    M575 P1 S1 B115200                                       ; enable support for PanelDue
    M501                                                     ; load saved parameters from non-volatile memory
    T0                                                       ; select first tool
  • when you home, the values are taken from M208.
    Your M208 minima value is X77 and Y84. You should change these to X0 Y0
  • @jay_s_uk said in Setting bed origin:
    OK thanks, but what's about the offset I have. The bed starts at 77,84 and not at 0,0? Where do I have to set this?
  • @MartinNYHC M208 X0 Y0 Z0 S1 instead of M208 X77 Y84 Z0 S1
  • @MartinNYHC
    If when you home, it is 77mm away from the bed, set the minima as X-77 and then 0 would be at the bed edge. Same as with Y. This is how I deal with it on my machines, although I use centre origin.
    This of course would throw out all your screw locations etc.
  • Got it and it works. Thanks!
