    Tevo Little Monster calibration issues with RRF 3.1.1
    562
    • Sytac072undefined
      Sytac072
      Hi everyone. I own a Tevo Little Monster which I have upgraded with Duet2 WiFi, magnetic rods and Smart Effector.
      I have used the printer for a long time with RRF firmware until the latest one which was 2.05.1 and the printer works perfectly, without any trouble. Then I tried to upgrade to RRF 3.1.1 (doing the needed changes to the config files).
      At this point, I started to have troubles with the Z offset, which was always to be calibrated at every startup of the printer, as well as the mesh calibration, which is not working.
      Even during the printing process, it's difficult to have a good result, then I have reinstalled the previous one (2.05.1) and everything went back to normal.
      Anyone has any idea?
      • Vetiundefined
        Veti
        post your config and overwrite
        Sytac072undefined 1 Reply Last reply Reply Quote 0
        • Sytac072undefined
          Sytac072
          ; generated by RepRapFirmware Configuration Tool v2.1.4 on Mon Jan 06 2020 13:06:19 GMT+0100 (Ora standard dell’Europa centrale)
          G28 ; Home all axes
          M111 S0 ; Debugging off
          G21 ; Works in millimiters
          M555 P1 ; Set firmware compatibility to look like RepRap Firmware
          M665 L400.25:400.25:400.25 R165 B160 H485 ; Set delta radius, diagonal rod length, printable radius and homed height (With extra glass 13/07/2020)
          M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
          M575 P1 B57600 S1 ; set paneldue communication parameters
          M550 P"TEVO Little Monster" ; Set machine name
          M552 S1 ; Enable network
          M586 P0 S1 ; Enable HTTP
          M586 P1 S1 ; Enable FTP
          M586 P2 S0 ; Disable Telnet
          M569 P0 S0 ; physical drive 0 goes backwards
          M569 P3 S0 ; physical drive 3 goes backwards
          M579 X1.00806 Y1.007252 Z1.0040 ; Scale parameter for axes X, Y and Z calculated on 16/05/2020
          M92 X160.00 Y160.00 Z160.00 E819.338 ; set steps per mm
          M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
          M906 X1250 Y1250 Z1250 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 Z0 S1 ; set minimum Z
          M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
          M558 P8 R0.8 C"zprobe.in+zprobe.mod" H5 A5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds (New setting from 15/05/2020)
          ;M558 P5 R0.4 C"zprobe.in+zprobe.mod" H1 F1200 T6000 ; set Z probe type to effector and the dive height + speeds (New setting from 10/01/2020)
          ;M558 P5 R0.4 C"zprobe.in+zprobe.mod" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds (Original setting)
          G31 P500 X0 Y0 Z-0.152 ; set Z probe trigger value, offset and trigger height
          M557 R150 S15 ; define mesh grid (New setting from the old config.g)
          ;M557 R85 S15 ; define mesh grid (Original setting from configurator)
          ; Reference page : https://duet3d.dozuki.com/Wiki/Connecting_thermistors_or_PT1000_temperature_sensors
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 R4700 A"Piatto" ; configure sensor 0 as thermistor on pin bedtemp
          M140 H0 ; define and create the bed heater (set on 13/05/2020, needed with RRF 3)
          M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 R4375 C7.06e-8 A"Estrusore"; configure sensor 1 as thermistor on pin e0temp
          M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
          M106 P0 C"Part cooling fan" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
          M106 P1 C"Hotend fan" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
          M563 P0 D0 H1 F-1 ; define tool 0
          ; Filament run-out sensor
          M591 D0 P2 C3 S1 ; Filament run-out sensor Input high when filament is in
          ; Automatic power saving
          M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
          ; Miscellaneus
          M375 ; Load the grid probing mesh
          M501 ; read stored parameters from config override
          • Sytac072undefined
            Sytac072 @Veti
            @Veti
            ; config-override.g file generated in response to M500 at 2020-09-17 13:01
            ; Delta parameters
            M665 L407.671:407.671:407.671 R167.529 H473.244 B160.0 X-0.109 Y-0.362 Z0.000
            M666 X1.320 Y0.069 Z-1.390 A0.07 B-0.19
            ; Heater model parameters
            M307 H0 A171.3 C936.8 D0.9 S1.00 V23.9 B0
            M307 H1 A294.8 C253.4 D3.1 S1.00 V23.7 B0
            ; Workplace coordinates
            G10 L2 P1 X0.00 Y0.00 Z0.00
            G10 L2 P2 X0.00 Y0.00 Z0.00
            G10 L2 P3 X0.00 Y0.00 Z0.00
            G10 L2 P4 X0.00 Y0.00 Z0.00
            G10 L2 P5 X0.00 Y0.00 Z0.00
            G10 L2 P6 X0.00 Y0.00 Z0.00
            G10 L2 P7 X0.00 Y0.00 Z0.00
            G10 L2 P8 X0.00 Y0.00 Z0.00
            G10 L2 P9 X0.00 Y0.00 Z0.00
              jay_s_uk
              my first question would be why your endstops are set to the low end of the printer?
              surely being a delta you home with the carriages being at the top of the frame?
              • Sytac072undefined
                Sytac072 @jay_s_uk
                @jay_s_uk
                Yes, you are right. This is already a mistake but the homing process works correctly anyway.
                  jay_s_uk
                  I would also suggest looking at your trigger value. you have P500 but the recommended value for the smart effector is P100
                  https://duet3d.dozuki.com/Wiki/Smart_effector_and_carriage_adapters_for_delta_printer#Section_Commissioning
                    Phaedrux Moderator @Sytac072
                    @Sytac072 said in Tevo Little Monster calibration issues with RRF 3.1.1:
                    G28 ; Home all axes
                    You probably should not initiate a homeall in your config.g. For one thing, you have it at the start of the config.g before any of the configuration has loaded. Second, having movement start with power on is potentially dangerous.
                    Did you change the endstops to be at high end?
                    Also, you should not load the heightmap until after the printer has been homed and the bed probed to establish Z0. This is likely part of the problem with your inconsistent offset.
                    Are you using G32/bed.g to do a calibration? It should be in your bed.g macro that you home the towers and probe the bed for calibration and only then do a G29 to create or load a heightmap.
