    IR sensor Z probe on RRF3 config issues
    IR Height Sensor
    229
    • alexic
      alexic last edited by
      Hello, I connected the DC42 IR sensor to my board using the Z0 endstop connector, and I can see that electronically the power (3V3) and connection is good (in standby the status led of the sensor is on, when I put something nearby the sensor the led goes off, also, the led on the motherboard has the inverted state of the led on the probe).
      The issue remains with the config file, in which I have the following lines:
      M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2
      M574 Z0 P"nil" ; no Z endstop switch, free up Z endstop input
      M558 P1 C"zstop" H5 F120 T3000  ; Z probe connected to Z endstop input
      G31 P500 X0 Y0 Z2.5
      And I can't seem to figure it out. On the first page under sensors I don't even have a "Probe" sensor. Also, if I run G31 in the console it returns:
      Error: G31: Invalid Z probe index
        Can you send M122 and M98 P"config.g" and post the results?
        Also post the entire config.g.
        • alexic
          Here is all the info, I did not know about M98, it seems very handy.
          m122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
          Board ID: 08DGM-956GU-DJ3SW-6JKD6-3S86R-1BMZG
          Used output buffers: 3 of 24 (10 max)
          Static ram: 27980
          Dynamic ram: 94064 of which 44 recycled
          Exception stack ram used: 264
          Never used ram: 8720
          Tasks: NETWORK(ready,392) HEAT(blocked,1224) MAIN(running,1880) IDLE(ready,80)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:00:37 ago, cause: software
          Last software reset at 2020-09-24 07:15, reason: User, spinning module GCodes, available RAM 8720 bytes (slot 3)
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
          Error status: 0
          MCU temperature: min 34.8, current 36.1, max 36.2
          Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
          Date/time: 2020-09-24 07:16:33
          Cache data hit count 61822017
          Slowest loop: 1.31ms; fastest: 0.13ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 0.4ms, write time 0.0ms, max retries 0
          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
          === MainDDARing ===
          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 70.27ms; fastest: 0.00ms
          Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
          HTTP sessions: 1 of 8
          - WiFi -
          Network state is active
          WiFi firmware version 1.23
          WiFi MAC address cc:50:e3:76:3f:ab
          WiFi Vcc 3.36, reset reason Unknown
          WiFi flash size 4194304, free heap 23888
          WiFi IP address 192.168.1.239
          WiFi signal strength -52dBm, reconnections 0, sleep mode modem
          Socket states: 4 0 0 0 0 0 0 0
          M98 P"config.g"
          Warning: M918: Command is not supported
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          Error: Pin 'zstop' does not support mode analog read
          Error: Invalid Z probe index
          Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
          Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 170C
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Sep 15 2020 22:46:11 GMT+0200 (Central European Summer Time)
          M550 P"Ender-3"                                    ; set printer name
          M918 P1 E4 F2000000                                ; configure direct-connect display
          M569 P0 S0                                         ; physical drive 0 goes backwards
          M569 P1 S0                                         ; physical drive 1 goes backwards
          M569 P2 S1                                         ; physical drive 2 goes forwards
          M569 P3 S1                                         ; physical drive 3 goes backwards
          M584 X0 Y1 Z2 E3                                   ; set drive mapping
          M92 X80.00 Y80.00 Z400.00 E408                   ; set steps per mm, ender original E106
          M566 X1200.00 Y1200.00 Z120.00 E300.00              ; set maximum instantaneous speed changes (mm/min)
          M203 X12000.00 Y12000.00 Z900.00 E6000.00            ; set maximum speeds (mm/min)
          M201 X3000.00 Y3000.00 Z400.00 E5000.00              ; set accelerations (mm/s^2)
          M906 X700 Y700 Z800 E1000 I30                      ; set motor currents (mA) and motor idle factor in per cent
          M204 P600 T2000
          M208 X-10 Y0 Z0 S1                                   ; set axis minima
          M208 X215 Y225 Z260 S0                             ; set axis maxima
          M574 Z1 S2
          G31 P500 X0 Y0 Z2.5
          M557 X15:210 Y15:210 S20                           ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4092     ; configure sensor 0 as thermistor on pin bedtemp
          M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
          M143 H0 S100                                       ; set temperature limit for heater 0 to 100C
          M308 S1 P"e0temp" Y"thermistor" T100000 B4138 C0 R4700      ; configure sensor 1 as thermistor on pin e0temp
          M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
          M950 F2 C"fan2" Q500                               ; create fan 2 on pin fan2 and set its frequency
          M106 P2 S1 H1:0 T45                                ; set fan 2 value. Thermostatic control is turned on
          M572 D0 S0.35
          ; Custom settings
          ; Trigger buttons
          M950 J0 C"^e0stop"
          M950 J1 C"^e1stop"
          M581 P0 T2 S1
          M581 P1 T3 S1
          M501                                               ; load saved parameters from non-volatile memory
            Phaedrux Moderator @alexic last edited by
            @alexic said in IR sensor Z probe on RRF3 config issues:
            Error: Pin 'zstop' does not support mode analog read Error: Invalid Z probe index
            There's our problem. You're going to need to use the Zprobe connector instead of the zstop connector.
            With Duet 2 and earlier Duets: Connect the VCC, GND and OUT pins of the sensor to 3.3V, GND and IN respectively on the Z probe connector, and select mode 1 in the M558 command.
            https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Mini_differential_IR_sensor_by_dc42
            Your M558 command would then become M558 P1 C"zprobe.in+zprobe.mod" H5 F120 T6000
            The direct connect LCD display of the Ender 3 will only work with the Duet Maestro, so that M918 is being ignored.
            You can also remove this line M574 Z0 P"nil" ; no Z endstop switch, free up Z endstop input
            • alexic
              Okay that’s what I will do, move to the Z probe pin.
              • droftarts
                droftarts Moderator @alexic last edited by
                @alexic M918 is only supported on Duet Maestro, or in firmware 3.2.
                Phaedrux alexic 2 Replies Last reply Reply Quote 0
                  Phaedrux Moderator @droftarts last edited by
                  @droftarts said in IR sensor Z probe on RRF3 config issues:
                  or in firmware 3.2.
                  I need to catch up on current events!
                  • alexic
                    alexic @droftarts last edited by
                    @droftarts I am not using that comand, it was there from a configuration file example.
                    • droftarts
                      droftarts Moderator @Phaedrux last edited by
                      @Phaedrux It says that in the Gcode dictionary, I had to look it up!
                      I was explaining the error message. But be careful when using someone else’s config, it won’t always suit your machine, and may cause problems. Make sure you understand every command, and use the Gcode dictionary to help you.
