    Im getting a basic error:563 bad driver number for my heater 1
    175
    • Jeffrey_101
      Jeffrey_101 last edited by
      i have my hot end hooked up to heater 1, my tool settings are
      but when i run the heater test, it flashes a error: m563 bad driver number
      what is happening?
      • jay_s_uk
        jay_s_uk last edited by
        can you post your full config please?
          The results of M122 and M98 P"config.g" wouldn't hurt either.
          • Jeffrey_101
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Sep 20 2020 15:20:40 GMT-0700 (Mountain Standard Time)
            M550 P"Jeffrey's printer" ; set printer name
            M665 R155 L397.19 B155 H520 ; Set delta radius, diagonal rod length, printable radius and homed height
            M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S1 ; enable FTP
            M586 P2 S1 ; enable Telnet
            M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
            M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
            M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
            M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 Z0 S1 ; set minimum Z
            M574 X2 S1 P"!xstop" ; configure active-high endstop for high end on X via pin !xstop
            M574 Y2 S1 P"!ystop" ; configure active-high endstop for high end on Y via pin !ystop
            M574 Z2 S1 P"!zstop" ; configure active-high endstop for high end on Z via pin !zstop
            M307 H3 A-1 C-1 D-1 ;
            M558 P5 H5 F100 T2000;
            G31 X0 Y0 Z2.613 P25;
            M557 R150 S25
            M143 H1 S280 ; Set temperature limit for heater 1 to 280
            M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M106 P2 S1 I0 F500 H0 T50
            • jay_s_uk
              You have a mishmash of RRF2 and RRF3 commands there.
              for example,
              M307 to free up a pin is not required, M305 is not valid in RRF3 and M106 requires an M950 before hand.
              Confirm you are running some form of RRF3 using M115 and then I suggest you revisit the online configurator to generate a new set of config files.
              • Jeffrey_101
                so i got a new set from the configurator and now im not getting any temp readings or anything. but it should all be in RRF3.
                ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Sep 24 2020 10:58:07 GMT-0700 (Mountain Standard Time)
                M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                M557 R85 S20 ; define mesh grid
                • droftarts
                  droftarts administrators @Jeffrey_101 last edited by
                  @Jeffrey_101 please send M115 and post response.
                  Jeffrey_101 1 Reply Last reply Reply Quote 0
                    Phaedrux Moderator @Phaedrux last edited by
                    @Phaedrux said in Im getting a basic error:563 bad driver number for my heater 1:
                    • Jeffrey_101
                      Jeffrey_101 @droftarts last edited by
                      @droftarts
                      M115
                      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
                      • jay_s_uk
                        ok, so you have RRF2 installed and not RRF3.
                        Therefore you will need to generate your config for RRF2 from the online configurator
                        Jeffrey_101 2 Replies Last reply Reply Quote 0
                        • Jeffrey_101
                          Jeffrey_101 @jay_s_uk last edited by
                          @jay_s_uk
                          oh, I see. thank you!
                            Alternatively, you can upgrade to 3.0 and then 3.1.1, and if you're starting a new build that is fairly standard that might be the best way to go.
                            If you have access to the web interface, the easy way to upgrade is to download these two zip files and then upload them one at a time as is (don't extract them) to the /system folder in DWC. It will detect them and update everything and reboot, then repeat for the second file. Then your config for RRF3 should work and you'll be on the current firmware release.
                            https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                            https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
                            • Jeffrey_101
                              @jay_s_uk
                              So i just regenerated my config for RRF2. i ran the test heater function and it threw me this:
                              M98 P"0:/macros/03-Test_Heaters"
                              Error: M563: Tool creation: bad drive number
                              my tool code in my config is:
                              G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to
                              this concerns me because it looks correct
                              • jay_s_uk
                                can you post your whole config?
                                • Jeffrey_101
                                  M574 X2 Y2 Z2 S1 ; set active high endstops
                                  M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                                  M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                  G31 P500 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
                                  M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
                                  M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
                                  M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                  M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                  • jay_s_uk
                                    nothing wrong there i can see.
                                    Whats in your macro?
                                    • jay_s_uk
                                      oh wait, is that the test macro thats come on the card?
                                      • Jeffrey_101
                                        @jay_s_uk yeah
                                          Don't run those. They are for factory testing and you won't have the same hardware connected obviously.
                                          You can test the heater by turning it on in the web interface.
                                          • Jeffrey_101
                                            Jeffrey_101 @Phaedrux last edited by Jeffrey_101
                                            @Phaedrux
                                            i tried but it trips an error
                                            Error: Heating fault on heater 1, temperature rising much more slowly than the expected 1.7°C/sec
                                            its wired to the correct heater and everything
                                            • jay_s_uk
                                              PID tune your hot end and your bed.
                                              For your bed
                                              M303 H0 S60
                                              For your hotend
                                              M303 H1 S200
                                              Tune your hotend with it close to your bed and your part cooling fan running at the speed you would usually use for printing
                                                After tuning PID send M500 to save the results and add M501 to the end of your config.g to load them at startup.
                                                • jay_s_uk
                                                  yes, that helps
                                                  • Jeffrey_101
                                                    @jay_s_uk
                                                    im thinking the hardware might be broken
                                                    9/24/2020, 1:59:35 PM Auto tune cancelled because temperature is not increasing
                                                    9/24/2020, 1:58:58 PM Auto tune phase 1, heater on
                                                    9/24/2020, 1:58:53 PM M303 H1 S200
                                                    Auto tuning heater 1 using target temperature 200.0°C and PWM 1.00 - do not leave printer unattended
                                                    jay_s_uk droftarts 2 Replies Last reply Reply Quote 0
                                                    • jay_s_uk
                                                      jay_s_uk @Jeffrey_101 last edited by
                                                      @Jeffrey_101 where do you have the heater wired into?
                                                      maybe post a photo
