    SOLVED RRF vs PanelDue compatibility?
    PanelDue
    218
    • tgarr
      tgarr last edited by
      I'm running RRF 3.1.1 on my Duet WiFi, but when I load the latest PanelDue release of 1.24 and try to plug it in I get a white screen. (7i purchased new this year)
      (cable appears to be good, and the panel boots up under usb power)
      Do I need to be running pre-release firmware on my PanelDue? (3.2RC2?)
      Is compatibility listed somewhere and I'm just missing it?
      • Veti
        Veti last edited by
        the paneldue should have a menu, even when not connected. try reflashing it.
          Are you sure you chose the correct bin file for your paneldue hardware and followed the flashing procedure exactly?
          • jay_s_uk
            jay_s_uk last edited by
            and are you sure you haven't pressed the erase button rather than the reset button?
            Owns various duet boards and is the main wiki maintainer for the Teamgloomy LPC/STM32F4 port of RRF
            • tgarr
              I just tried flashing to 3.2. It looks good when on USB power (I can navigate around and verify the firmware, but when connected to the Duet2 WiFi I still get a white screen.
              However, this time I let it sit a bit longer (~2 -5 minutes) and I started getting flickering on the screen with the menu breaking through every once in a while. Then it went away.
              That looked like a cable issue, so I changed the (primary/4-wire) cable, still a white screen. I tried it with and without the ribbon cable also connected. Same white screen with occasional flickering.
              I don't think this is a compatibility issue at this point maybe something in the config.gcode?
              config.g
              I confirmed that the panel baud was set to 57600...should I try messing around with different baud rates?
              • tgarr
                @jay_s_uk Pretty sure I didn't hit the erase again (you have to click it once during the new firmware install)...I mean it takes a tool to get to...and if I switch back to just a micro usb cable I can still get into the menus.
                @Phaedrux I'm pretty sure I did everything correctly, but how would I verify? I can power it up over USB and navigate to the panels settings page. Shows the expected (now 3.2) firmware and 57600 baud. Anything else I should look for?
                  dc42 administrators @tgarr last edited by
                  @tgarr said in RRF vs PanelDue compatibility?:
                  Confirm that you are running the Duet from VIN power? If you are powering the Duet from USB then there may not be enough voltage reaching the PanelDue.
                  • tgarr
                    @dc42 Yes, I am running the duet from 24v power supply.
                    I have been plugging the paneldue back into the microusb to access the settings menu.
                      dc42 administrators @tgarr last edited by dc42
                      If the screen is flashing white when powered from the Duet but not when supplied with USB power, then that looks like a power problem, most likely the cable. Using the wrong baud rate etc. would not cause that.
                      • tgarr
                        Already tried a second cable, anything else to try on the power front besides a third cable?
                        • tgarr
                          tgarr last edited by tgarr
                          Onto the third cable, better, but similar behavior. I'm beginning to suspect something is loose on the board. I have trouble believing that three cables that all show continuity on a multimeter are all bad.
                          Here's a criminally rotated video...(sorry)
                          https://photos.app.goo.gl/ZnUCBZ7fY1Y6Brn8A
                          (just to clarify, that flickering is accurate, not a recording artifact)
                          The paneldue is elevated on a plastic box just to rule out any case issues. The cables aren't touching anything.
                            Can you measure the power voltage at the 4-pin connector of the PanelDue?
                            • tgarr
                              Looks like 4.98V
                                Looks like 4.98V
                                That's a good voltage, unless it's an average and the voltage is suffering sharp dips every time the backlight inverter starts up.
                                The +5V goes through a diode and an inductor before it reaches the common 5V rail. I guess one of those components might not be soldered down properly.
                                • tgarr
                                  Ok, I guess I'll try to return it.
                                  The only other clue I can offer is that if I just plug in the 4 wire I get a white screen, if I power on and then plug in the ribbon cable I can reliably get the flickering.
                                    Please check that there isn't a solder bridge between pins of the ribbon cable connector on the PanelDue.
                                    tgarr 1 Reply Last reply Reply Quote 0
                                    • tgarr
                                      tgarr @dc42 last edited by
                                      I don't see any bridging of solder:
                                      https://photos.app.goo.gl/MZLUyikwGnUVn5YLA
                                      Here's the front and back for a complete picture
                                      https://photos.app.goo.gl/Fq9kcYabgkgEwRNK6
                                      https://photos.app.goo.gl/9BWQ1A1AZsUb39fN6
                                      • tgarr
                                        Is there anything else I can do short of trying to get a return or exchange? This thing is effectively brand new (it did sit in the box for a month before I got around to trying it).
                                          When and where was it purchased?
                                          • tgarr
                                            tgarr @Phaedrux last edited by
                                            @Phaedrux
                                            I had to look it up, Covid time flies, I guess it was more like 2 months sitting in the box.
                                            July 30th through Printed Solid.
                                              Please contact your reseller and request a warranty exchange. Include a link to this thread as authorization.
                                              • tgarr
                                                @Phaedrux Thanks.
                                                Is there anything else I should / could try to make sure it's not the duet2 board first?
                                                  Not that I can think of that hasn't already been tried. Unless @dc42 has any other suggestions.
                                                    If the voltage at the PanelDue power input pins on the 4-way connector is a steady 4.98V even when the display is flashing white then the fault lies in the PanelDue.
                                                    My guess is a badly-soldered diode DA2 or inductor LA1 (or just possibly LA1 is the wrong component). If you wish, you could check that by measuring the voltage between each end of LA1 and ground. Both places should be steady at about 4.5V.
                                                    • tgarr
                                                      @dc42 Before I do anything stupid...(I'm a mechanical engineer not a sparky), which side of those components should I check on?
                                                      I'd assume the side opposite of the 4 wire connector, is that correct?
