    Duet 2 ethernet working with Slic3r PE
    • Deluxe 600
      Deluxe 600 last edited by
      Hi.
      I decided to use Slic3r PE from prusa research because im familiar with it but i ran into problems. The Slic3r has its movement units in mm/sec but duet uses mm/min in its system. Im sure its been solved somewhere but i was unable to find a solution, will you please help? Thank you for your kind help.
        Change the gcode flavor to reprap. Even without that it should still work alright. What exactly isn't working?
        Deluxe 600 1 Reply Last reply Reply Quote 0
        • Deluxe 600
          Deluxe 600 @Phaedrux last edited by
          @Phaedrux Thank you for the fast reply. Well if i set up the slic3r in its mm/sec units the printer moves extremly slow because it seems that the duet reads the mm/sec units as if they were mm/min.
          For example Slic3r has 200mm/sec but the printer moves at 200mm/min
          Sending in a picture of the settings
            You haven't set the gcode flavor to reprap, otherwise you wouldn't even see that machine limits page.
            • Deluxe 600
              Ooooh. I knew it had to be something simple 🙂 . Thank you very much kind sir, have a great day.
