problem with irregular bltouch mesh
@Phaedrux
you were right, after the home all and the two engines are aligned with the table, I decided to make a g30 on each side (x5 and x295) and try to lower the nozzle to the table to see if there is a difference.
the result: at x5 and in the center of the table, the g30 corresponds exactly, so after the g30, I put the nozzle at 0.1 and it really has 0.1. But in position x295 after g30, I should have the same result, but immediately after g30, when I send the nozzle go up to 0 it touches the table, and I found that it only moves away from the table when it is at 0.2, so I have that difference.
There is no software error, there is no mesh error. all measurements were made at 150 y.
as much as I insist on the g30 in position x295 and y150 I have the same result, it is as if the bltouch measured wrong only in that position, the whole mechanics seems to be correct, but I do not understand what may be happening. -
Attached is a 4 point height map of my FT5 printer which is currently undergoing some upgrades.
While it might look like the problem is in the bed it is actually in the left and right Y rails.
Instead of the two rails being in the same plane, the right rail is canted with respect to the plane of the left rail.
When I get around to fixing this problem I will need to lower the rear end and raise the front end of the this rail.
As was mentioned by @Phaedrux there are a few different things that can contribute to a less than perfect height map - this rail problem is just one of them.
@fcwilt thanks for the example. but in my case the touch does not understand the bed slightly higher at x +, it is as if on the right side of the table the z offset was different from the left side of the table. I need to identify where there may be a difference for this to happen, when I find it I will put it here. thank you
