Endstop x,y
  • Hello all,
    just bought a duet 2 wifi and I am struggling with the Endstops for x and y. The Endstops are recognized correctly and the LEDs on the boards lights if I hit the appropriated switch. Anyhow the movement respectively motors do not stop.
    Firmware Version: 1.21 (2018-03-21)
    config file; Endstops
    M574 X2 S0 P“xstop"
    M574 Y1 S0 P“ystop" ;Snnn Endstop type: 0 = active low endstop input
    M118 if the switch is not triggered:
    Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: at min stop
    standard home file:
    ; homex.g
    ; called to home the X axis
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Sep 12 2020 06:05:28 GMT+0200 (CEST)
    G91 ; relative positioning
    G1 H1 X215 F1800 ; move quickly to X axis endstop and stop there (first pass)
    G1 X-5 F6000 ; go back a few mm
    G1 H1 X215 F360 ; move slowly to X axis endstop once more (second pass)
    G1 H2 Z-5 F6000 ; lower Z again
    G90 ; absolute positioning
    If someone has an idea how to proceed would be fine.
    Thanks is advanced.
  • @Christoph said in Endstop x,y:
    your firmware is to old. the files are for version 3
    so please update to 3.11
    see
    https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
  • Hi!
    You have very old firmware (1.x). This is the reason why your script doesn't work. It is dedicated to newest firrmware (3.x) so you need to upgrade. I prefer use Bossa and USB cable
  • Thanks for the fast response. I will do and come back with the result.
  • Thanks a lot again, should had this idea by my own 😉 but it is working now, so I can do the next steps.
