    Solved Duet3 6HC RC-Servo on io port (What am I missing?)
    207
    • MaxGyver
      MaxGyver last edited by MaxGyver
      Hey all,
      I would like to controll a RC-servo that is connected to the IO_0 port on my Duet3 6HC.
      The round Signal and 5V lines of the servo are connected to GND, io0.out and 5V_Ext of the io_0 port. But I have the impression that the servo has no power at all...
      in the config.g i have added the following code:
      M950 S0 C"io0.out"
      M280 P0 S0
      I am using RRF 3.2-beta1 with SBC
      What am I missing here ?
      Cheers Max
      droftarts 2 Replies Last reply Reply Quote 0
      • droftarts
        droftarts administrators @MaxGyver last edited by
        @MaxGyver Most servos need 5V PWM signal. I think io0.out is 3.3V. Why not use the dedicated 5V PWM output of out9?
          Which firmware version are you using? Until recently, IO0 was only available for connecting a PanelDue.
          • droftarts
            @MaxGyver Also, do you have a jumper on Internal 5V enable? See https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_5V
            • MaxGyver
              @droftarts: I would like to use more than one Servo and I use the default jumper configuration with jumpers on the "Int 5V EN" and "5V -> SBC"
              @dc42 I am using RRF version 3.2-beta1. I have also tried to connect to other IO-ports
              Thanks a lot!
              Max
              • achrn
                achrn last edited by
                https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview says io0 doesn't do PWM.
                4, 5 and 7 do PWM.
                droftarts 1 Reply Last reply Reply Quote 2
                • droftarts
                  droftarts administrators @achrn last edited by
                  @achrn said in Duet3 6HC RC-Servo on io port (What am I missing?):
                  io0 doesn't do PWM.
                  4, 5 and 7 do PWM.
                  @MaxGyver That too!
                  • MaxGyver
                    4, 5 and 7 do PWM.
                    Yep! thats what I have missed!
                    Cheers,
                    Max
