    Some hints to a newbie?
    159
    • A Former User
      A Former User last edited by
      Good morning, I'm Andrea from Italy, I'm a 3D printer since 5 years but I've always used printers based on Marlin. Now for my new custom printer (a CoreXY based on a Tronxy X5S chassis) I've ordered a Duet 2 WiFi board....to pass from Marlin to RapRap firmware for me it's a little bit difficult because I'm realizing I have to change all my points of view....so I'm here to ask a little help to understand better the things to do:
      Before that I describe my configuration: my printer, as I said, is a CoreXY, my extruder is a direct drive (BMG with an E3D V6 with volcano nozzle), the X and Y endstop are optical endstops, I have an original BLTouch for the Z and tha bed leveling and I have a mosfet to control the heated bed because the main board is powered with 12VDC but the bed will be powered with 19VDC taken from a dedicated power supply.
      As filament runout sensor I've ordered an original DUET3D FILAMENT MONITOR - ROTATING MAGNET.
      Here ar some doubts I have now:
      1. About the BLTouch: with Marlin I've added a G29 in EVERY start gcode in every print, with RRF does it works like this too? I've read that you can "build" a level matrix and then use it with every print, I have the problem that in my heated bed I mount a magnetic steel plate with a PEI sheet so when I detach it at the end of the print and re attach it for a new print the leveling, of course, will be almost impossible to be the same each time
      2. With marlin every time I made a change on the console i had to give M500 to store it in the EEPROM, is it still valid with RRF?
      3. I own a license for Repetier server mounted on a Raspberry 3 wich is connected via usb to the board, I use it because it allows me to remotely monitor the printer with a webcam connected to the Raspy. Is it possible to connect the Duet to a Raspy via USB and sending the gcodes from Repetier server? In case what firmware functionality will i lose?
      4. (last for now) In the documentation I read that DUET3D FILAMENT MONITOR - ROTATING MAGNET looks to work only when the print is started from the board SD, so in case I can use Repetier server and lunch the prints from it will not I be able to use the filament monitor?
      For now I quit making questions...
      Thanks for any help!
      Andrea
      • Veti
        Veti last edited by
        @the_dragonlord said in Some hints to a newbie?:
        yes that works with the duet as well
        not exactly. there is a M500 feature, but generally all changes are made in the file config.g
        first see: https://duet3d.dozuki.com/Wiki/USB_ground_loops
        the duet inbuild web ui has support to display a network video stream.
        you can send commands in g code directly from the web ui. no need for repetier
        there is no need for repetier, as the inbuild web ui has all those features.
        A Former User 1 Reply Last reply Reply Quote 0
        • A Former User
          A Former User @Veti last edited by
          @Veti said in Some hints to a newbie?
          the duet inbuild web ui has support to display a >network video stream.
          but, if I'm not wrong it works only with particular kind of ipcams, am I wrong?
          • Veti
            Veti last edited by
            see
            https://duet3d.dozuki.com/Wiki/How_to_include_a_web_camera_image_in_Duet_Web_Control
              Many of the RRF features require printing gcodes from the internal SD card. Streaming gcode over USB is not recommended.
              Using the Duet Web Control interface is the normal way to interact with and configure the printer.
              If you have a raspberry pi and usb webcam you can use Motion to create a streaming web url that can be used in the DWC to show the camera.
              M500 behaves much differently than the EEPROM. It's intended to capture some of the calculated or automatically measured values like heater PID values from auto tuning, or measured offsets, delta calibration, etc. All those values get saved to config-override.g and get read back when M501 is sent. All normal configuration is done by editing the macro files directly. config.g is just a macro that gets executed at startup.
              https://duet3d.dozuki.com/Wiki/Gcode#Section_M500_Store_parameters
              • theruttmeister
                theruttmeister last edited by
                The biggest difference is explained in the RRF wiki g-code page:
                G-code everywhere.
                That means the config file is just a collection of g-code that is run when the board boots up.
                The home commands are actually macros stored on the SD card.
                And the Macro's are potentially really powerful too, as they can be used to do basically anything the firmware is capable of, not just having a little routine that heats up the head and ejects the filament.
                Once you have things setup correctly its not really important, but when you are first getting things setup its really handy because there's nothing that can't be changed be sending some g-code.
                There are some other pluses, but not needing to compile the firmware every time you need to change something is nice.
                If you want to get really fancy the changes get more significant. Like being able to have conditional arguments in the configuration.
                Isolate, substitute, verify.
                • A Former User
                  A Former User @Phaedrux last edited by
                  @Phaedrux said in Some hints to a newbie?:
                  Hi, if you mean to use MotionEyeOS I've read that this only works with the Pi Cam not an USB camera, am I wrong?
                  • A Former User
                    @Veti said in Some hints to a newbie?:
                    see
                    Thanks, I give it a deep read!
                    • Veti
                      Veti last edited by
                      there is https://github.com/jacksonliam/mjpg-streamer which supports video4linux and raspberry pi webcam.
                      his creates an mjpeg stream which should work
                      • A Former User
                        @Veti thanks but unfortunately I own a USB camera and not the Raspy Camera
                        jay_s_uk Veti 2 Replies Last reply Reply Quote 0
                        • jay_s_uk
                          jay_s_uk @Guest last edited by
                          @the_dragonlord that will also work with a USB camera
                          • Veti
                            Veti @Guest last edited by
                            @the_dragonlord
                            video4linux support all the different linux video standard including uvc.
                            if you webcam is a standard webcam that exposes the mjpeg stream, then this will work.
                              Phaedrux Moderator @Guest last edited by
                              Motion and MotionOS are two different things.
                              Check this out: https://www.instructables.com/How-to-Make-Raspberry-Pi-Webcam-Server-and-Stream-/
                              • A Former User
                                sorry, my fault, I misunderstood
