New Duet 2 extruder not working
@Phaedrux I have made new config homeall as per Veti,s guide and the DWC now homes all fine, however the paneldue does not, whichever home button I press on P/d it activates the homeall button, which is something you spotted in the video, then it homesall and then tells me error Bad command G90 and as I stated I cant bring up any other page on P/d to try and see whats going on. Also I went thru process of reinstalling firmware on P/d with same result
@GG said in New Duet 2 extruder not working:
Do you think this is a clone paneldue as well??.
If it was purchased along side the aliexpress duet, then yes.
It definitely sounds like something is wrong with the touch calibration or digitizer on the screen. Replacing the screen component itself might be enough, but I'm not sure there isn't something wrong with the electronics portion either.
You could try going back to the aliexpress reprapworld store for an exchange/refund.
Well that's something at least. Even without the paneldue you can hopefully successfully print.
@Phaedrux where would be the best place to buy a new paneldue, cause I really want to use the sd card inP/d to print, saves having a computer in workshop
Depends on your location. If you're in the UK, probably direct from Duet.
https://www.duet3d.com/index.php?route=common/home#products
Or from an authorized reseller in your country.
@Phaedrux Thank you guys for all your help, awesome stuff, Ive learnt lots, Im currently in negotiations with ali baba, over panelduue, Im in Newzealand so we dont have Duet store here., im sure Ill be back in touch sometime. Thankyou
Good luck with Ali.
