    How to use a LED Strip with Duet 2 WiFI?
    4.2k
    • A Former User?
      A Former User @ericlmccormick
      @ericlmccormick said in How to use a LED Strip with Duet 2 WiFI?:
      Make sure the M42 code is in the slicer startup code and NOT in config.g
      I put M32 in my slicer start code which calls beg.g and M0 in my slicer end code which runs stop.g
      Then I have M42 P2 S255 in my bed.g and M42 P2 S0 in stop.g and cancel.g
      already done but the stripe turns on when I boot the board even without m42
      ericlmccormickundefined 1 Reply Last reply Reply Quote 0
      • ericlmccormickundefined
        ericlmccormick @A Former User
        @the_dragonlord can you share your config.g file?
        • A Former User?
          here it is:
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 26 2020 18:43:35 GMT+0100 (Ora standard dell’Europa centrale)
          M550 P"DragonCore" ; set printer name
          M669 K1 ; select CoreXY mode
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S1 ; enable FTP
          M586 P2 S1 ; enable Telnet
          M569 P0 S0 ; physical drive 0 goes backwards
          M569 P3 S0 ; physical drive 3 goes backwards
          M92 X160.00 Y160.00 Z1200.00 E420.00 ; set steps per mm
          M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
          M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X330 Y330 Z400 S0 ; set axis maxima
          M574 Z1 S2 ; configure Z-probe endstop for low end on Z
          G31 P500 X0 Y0 Z0.474 ; set Z probe trigger value, offset and trigger height
          M557 X15:315 Y15:315 S20 ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
          M106 P1 S1 H1 T50 ; set fan 1 value. Thermostatic control is turned on
          M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
          M563 P0 S"E3DVolcano" D0 H1 F0 ; define tool 0
          M501
          uh, I forgot to say that I'm using a PWM fan not an heater.....sorry....
          Phaedruxundefined ericlmccormickundefined 3 Replies Last reply Reply Quote 0
            Phaedrux Moderator @A Former User
            @the_dragonlord said in How to use a LED Strip with Duet 2 WiFI?:
            Which fan header and where is the gcode defining the pin?
              @the_dragonlord your problem is you have m106 P2 S1 H-1 and you should have m106 P2 S0 H-1
              A Former User? 1 Reply Last reply Reply Quote 1
                @the_dragonlord but I recommend you use a heater and not a fan
                • A Former User?
                  i can't use a heater because I have to trigger a mosfet to drive the stripe and overriding a heater pin it gives a level of tension not enough for the mosfet to switch. Ay niw I'm using the Fan 2
                  • A Former User?
                    excellent, thanks!
                      @the_dragonlord I'm driving the LEDs directly from the board so that I can control the brightness. But if you are driving a MOSFET, then the fan is a better option I guess.
                      • A Former User?
                        yes it is, thanks
