    New firmware bundle 3.2beta2
    Beta Firmware
    21
    49
    2.7k
    • Stephen6309undefined
      Stephen6309
      I've changed to my genuine BLTouch 3.1, that I've been using on my Duet Ethernet w/3.11. The BLTouch 3.1 does not have that double tap.
      Looks like the genuine original BLTouch with metal pin doesn't work properly.
      Info provided here: https://forum.duet3d.com/post/183881
      • Touchthebitumundefined
        Touchthebitum @Touchthebitum
        @Touchthebitum
        Impossible to go back. I can downgrade but I get "busy" message in DWC and sd access is denied.
        Is it a known issue or I missed something ?
        Here is my diagnostic log :
        RepRapFirmware for Duet 3 MB6HC version 3.2-beta2 running on Duet 3 MB6HC v1.01 or later (SBC mode)
        Board ID: 08DJM-956L2-G43S8-6J9FJ-3S86S-983QD
        Used output buffers: 1 of 40 (14 max)
        Static ram: 157532
        Dynamic ram: 135804 of which 44 recycled
        Exception stack ram used: 272
        Never used ram: 99564
        Tasks: Linux(ready,36) HEAT(blocked,296) CanReceiv(blocked,947) CanSender(blocked,371) CanClock(blocked,353) TMC(blocked,51) MAIN(running,1127) IDLE(ready,20)
        Owned mutexes: HTTP(MAIN)
        Last reset 00:07:20 ago, cause: software
        Last software reset at 2058-01-24 11:14, reason: HardFault imprec, none spinning, available RAM 187280, slot 2
        Software reset code 0x4072 HFSR 0x40000000 CFSR 0x00000400 ICSR 0x0440f803 BFAR 0x00000000 SP 0x20418438 Task MAIN
        Stack: 0000004c 204184e4 204186ac 204186c4 20418518 204187ec 00416198 81000000 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5
        Error status: 0x00
        MCU temperature: min 30.5, current 31.0, max 31.3
        Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
        12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
        Driver 0: position 0, standstill, reads 64862, writes 18 timeouts 0, SG min/max 0/0
        Driver 1: position 0, standstill, reads 64862, writes 18 timeouts 0, SG min/max 0/0
        Driver 2: position 0, standstill, reads 64862, writes 18 timeouts 0, SG min/max 0/0
        Driver 3: position 0, standstill, reads 64863, writes 18 timeouts 0, SG min/max 0/0
        Driver 4: position 0, standstill, reads 64863, writes 18 timeouts 0, SG min/max 0/0
        Driver 5: position 0, standstill, reads 64871, writes 11 timeouts 0, SG min/max 0/0
        Date/time: 2020-10-11 12:56:13
        Slowest loop: 147.69ms; fastest: 0.22ms
        === Storage ===
        Free file entries: 10
        Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
        === MainDDARing ===
        Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
        === AuxDDARing ===
        Segments left: 0
        Movement lock held by null
        HTTP* is ready with "M122" in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Aux2 is idle in state(s) 0
        Code queue is empty.
        === CAN ===
        Messages sent 1729, send timeouts 1729, longest wait 0ms for type 0, free CAN buffers 48
        === SBC interface ===
        State: 0, failed transfers: 1
        Last transfer: 19ms ago
        RX/TX seq numbers: 13846/13847
        SPI underruns 0, overruns 0
        Number of disconnects: 0
        Buffer RX/TX: 0/0-0
        === Duet Control Server ===
        Duet Control Server v3.2.0-beta2
        Code buffer space: 4096
        Configured SPI speed: 8000000 Hz
        Full transfers per second: 31.95
        Sparkcube XL V 1.1 300x300x190, Radds, Raspberry, Keenovo silicone bedheat 220v, Big Booster Extruder, DIY building
        BLV Cube 665mm Direct Drive with Duet3/SBC (RPi 4) Mosquito Magnum/Bond Tech Extruder/Vanadium Nozzle, Keenovo silicone bedheat 220v
          Phaedrux Moderator @Touchthebitum
          @Touchthebitum How are you trying to downgrade?
          Touchthebitumundefined 1 Reply Last reply Reply Quote 0
            Touchthebitum @Phaedrux
            @Phaedrux
            I upload the previous firmware...
              Touchthebitum
              It's ok now. I had to reflash my Raspberry Pi4 and make all the procedure and it worked.
              I don't have sd card access denied anymore.
              • JuJuDeltaundefined
                JuJuDelta
                FYI I have managed to boot the RPi4 straight from SSD on USB3, no pesky uSD cards involved at all.
                T3DP3D Kossel XL+, Duet2Wifi, PanelDue 7i, RRF V3.2, Fl3xdrive, SmartEffector, Berd Air annulus, Cura 4.x, PrusaSlicer, RPi WiFi Camera, Heated Chamber
                  Touchthebitum @JuJuDelta
                  @JuJuDelta said in New firmware bundle 3.2beta2:
                  Very interesting!!
                  • wilrikerundefined
                    wilriker @BoA
                    @BoA said in New firmware bundle 3.2beta2:
                    I just updated PanelDue, DWC and RRF to latest betas.
                    I am afraid the issue with not refreshing temps on Panel during wait on M116 is still there.
                    Duet3 standalone.
                    Thanks again for reporting. This will be finally fixed in the next release of RRF.
                    Manuel
                    My Tool Collection
                    • littlehobbyshopundefined
                      littlehobbyshop
                      This post is deleted!
