    The rotating magnet filament monitor is out of stock eveywhere
    Filament Monitor
    294
    • TheDragonLord
      TheDragonLord last edited by
      Good morning, the filament seems to be out of stock in the whole world....does someone know if it is an abbandoned project? In case how to know when will it be available again?
      Thanks
      Andrea
      Andrea
      Custom CoreXY (X5S chassis): Duet 2 WiFi, Double 24VDC Power Supplies, E3D Chimera+ water cooled, E3D Cooling Kit, Bondtech BMG XM-2, Build volume: 290x310x350
      • achrn
        achrn last edited by
        Yes it's out everywhere. I've been looking for it since about July, though with reducing levels of effort, which is now sporadic at best. I understand the delay is to do with production of the casing.
        However, since I disabled the optical filament sensor on my Prusa when I was doing a lot of clear and black PETG (neither of which it liked), and I don't particularly miss it, I might never get round to putting one on the other printer (which is supposedly waiting for the rotating magnetic). It has a microswitch pesent/absent already, and that's most of the required functionality.
        TheDragonLord 1 Reply Last reply Reply Quote 0
        • TheDragonLord
          TheDragonLord @achrn last edited by TheDragonLord
          @achrn said in The rotating magnet filament monitor is out of stock eveywhere:
          would it be possible to use a switch as a filament sensor? I own some sensors with three wires, S, V, G of course just to monitor the presence/absence of filament...
          Andrea
          achrn fcwilt 2 Replies Last reply Reply Quote 0
          • achrn
            achrn @TheDragonLord last edited by
            @the_dragonlord said in The rotating magnet filament monitor is out of stock eveywhere:
            Yes, I have a microswitch with a roller on a lever snapped into a small print that fits over a stub of PTFE tube sticking out from the extruder.
            There are numerous of these on thingiverse, e.g. https://www.thingiverse.com/thing:2577717 but the one I tried (that one) didn't hold the microswitch I had in quite the right place, so it didn't trigger.
            So I rolled my own, which is ugly, slightly fudged in places, but highly parameterised and works for me. You're welcome to the files, though they are offered without any support or warranty:
            runout_sensor.scad
            runout_sensor.stl
            If your extruder moves around (mine doesn't) you might want a more securely located switch mount.
            • TheDragonLord
              runout_sensor.scad
              runout_sensor.stl
              what's the gcode to add to the firmware to configure and make the sensor work? even to configure the pause in event of run out
              Andrea
              achrn 1 Reply Last reply Reply Quote 0
              • achrn
                M591
                I use
                M591 D0 P2 C"io8.in" S1
                because my switch is wired to pull input 'io8.in' low when the filament is present, but it will depend what firmware and hardware you're running - see the description at https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing
                • TheDragonLord
                  M591
                  I use
                  excellent my friend, thanks!
                  Andrea
                  • fcwilt
                    fcwilt @TheDragonLord last edited by
                    Yes but it only tells you if the filament has broken or run out.
                    The failure of filament to feed is of importance and thus the existence of sensors like the laser and rotating magnet designs.
                    But I imagine you already know all that.
                    Printers: A FT-5 with the 713 upgrade bits. A custom MarkForged style. A small Utilmaker style and a CoreXY from kits. Various hotends. Using Duets (2 and 3) running 3.4.0
                    • TheDragonLord
                      TheDragonLord @fcwilt last edited by
                      @fcwilt said in The rotating magnet filament monitor is out of stock eveywhere:
                      sure, infact I'll use a simple switch only for the time needed for the magnet sensor to be available again
                      Andrea
                      fcwilt 1 Reply Last reply Reply Quote 1
                      • fcwilt
                        @the_dragonlord
                        A while back I ordered two but they only had one.
                        So like everyone else I wait...
                        and wait...
                        and wait...
                        and wait...
                        Frederick 😉
                          We were all set up to move to an improved injection-molded housing for the magnetic filament monitor. Then COVID struck, and the supplier concerned has quite reasonably decided to devote its resources to making PPE instead.
                          TheDragonLord fcwilt IOIIOOO 3 Replies Last reply Reply Quote 1
                          • TheDragonLord
                            TheDragonLord @dc42 last edited by
                            @dc42 said in The rotating magnet filament monitor is out of stock eveywhere:
                            We were all set up to move to an improved injection-molded housing for the magnetic filament monitor. Then COVID struck, and the supplier concerned has quite reasonably decide to devote its resources to making PPE instead.
                            uh, ok... but have you got a reasonably forecast for the time needed to the device for be delivered again? are we talking about days, weeks, months or no forecast at all?
                            Andrea
                            • fcwilt
                              fcwilt @dc42 last edited by
                              PPE? Have no idea what that is but it must be important.
                              Stupid virus - mucking everything up - in protest I'm going to refuse to get sick - I'll show that virus who's boss. 😉
                              • achrn
                                achrn @fcwilt last edited by
                                Personal Protective Equipment - something worn by an individual to protect that individual.
                                Previously mostly commonly referring to stuff in industry or construction guarding against physical injury (steel toe-cap boots, helmet, safety glasses, etc) more recently most used with reference to infection control (masks, visors, gloves etc). Used somewhat loosely - face coverings are not for the benefit of the wearer.
                                  And here I thought it was poly propylene elastomer.
                                  TheDragonLord 1 Reply Last reply Reply Quote 1
                                  • TheDragonLord
                                    TheDragonLord @Phaedrux last edited by
                                    @Phaedrux said in The rotating magnet filament monitor is out of stock eveywhere:
                                    I think it stands for Personal Protection Equipment----
                                    Andrea
                                      Phaedrux Moderator @TheDragonLord last edited by
                                      @the_dragonlord I think you're right.
                                      • IOIIOOO
                                        IOIIOOO @dc42 last edited by
                                        @dc42 Is there an option to just buy the electronics in the meantime and print our own less-fancy housing?
                                        • elmoret
                                          elmoret last edited by
                                          We have a few sets of housingless MFMs at Filastruder, drop an email at support@filastruder.com.
