Help PID tuning Dyzend Pro
  • Bonjour apprès plusieurs essai d'impression j'ai toujours se message d'erreur Cancelled printing file 0:/gcodes/CalibrationCube.gcode, print time was 0h 9m Error: Shutting down due to un-cleared heater fault after 600 seconds
    Ma température fluctue beaucoup de 5°C régler a 220 en impression elle monte jusqu'à 225
    et baisse a 218
    PID a bien etait effectuer
    M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
    M143 H0 S150 ; set temperature limit for heater 0 to 150C
    M305 P1 T4606017 B5848 C5.548428e-8 R4700 H0 L0
    M308 S1 P"e0temp" Y"thermistor" T4606017 B5848 ; configure sensor 1 as thermistor on pin e0temp
    M307 H1 A580.4 C256.6 D6.4 S0.50 ; disable bang-bang mode for heater and set PWM limit
    M143 H1 S493
  • Dyze donne sur son site
    Thermistance 500 ° C Thermorétractable noir
    #Modification du fichier config.g
    Recherchez les paramètres suivants et remplacez les valeurs:
    ;Heater and thermistor section
    ;*** If you have a Duet board with 1K thermistor series resistors, change R4700 to R1000 to the following M305 commands
    M305 P1 R4700 H0 L0
    M307 H1 A580.4 C256.6 D6.4 S0.50 ; Heating process parameters for 24V a system
    M143 S493
  • Help Please
    If you haven't already run heater tuning on your hot end, do it.
    If you have already run heater tuning and copied the resulting values into your M307 H1 command in config.g, increase the D parameter in that command until the temperature is stable when the print head is not moving. Try increasing it by 30% initially.
  • This post is deleted!
  • @dc42 PID effectuer
    Paramètre D changer et le résultat est le même
  • Auto tune cancelled because starting temperature is not stable
  • 11/10/2020 à 22:17:47 Auto tune phase 3, peak temperature was 251.1
    11/10/2020 à 22:17:19 Auto tune phase 2, heater off
    11/10/2020 à 22:16:07 Auto tune phase 1, heater on
    11/10/2020 à 22:16:02 M303 H1 S220 C8
    Auto tuning heater 1 using target temperature 220.0°C and PWM 1.00 - do not leave printer unattended
  • M307 H1
    Heater 1 model: gain 545.5, time constant 191.5, dead time 18.0, max PWM 1.00, calibration voltage 24.1, mode PID
    Computed PID parameters for setpoint change: P3.5, I0.059, D43.9
    Computed PID parameters for load change: P3.5, I0.094, D43.9
  • nobody for helping please
  • Moderator
    Is auto tuning successful? Are you starting from room temperature?
    How did you save the resulting values? Sending M500 saves them to config-override.g and M501 at the end of config.g loads them.
  • @chris974M said in Dyzend Pro:
    The problem is the heater, not use 50w. Use 40w or 30w
  • Oui auto tuning ok apres autotun. M500 il enregistre bien dans config-override.g
  • @FBG comment changer cela
  • @Phaedrux
    12/10/2020 à 22:00:22 Auto tune cancelled because starting temperature is not stable
    12/10/2020 à 22:00:02 M303 H1 S220
    Auto tuning heater 1 using target temperature 220.0°C and PWM 0.50 - do not leave printer unattended
  • Moderator
    @Phaedrux
    Does it work, or does it not work?
  • now does it not work
  • Moderator
    I suspect that's because the high temp thermistor is less accurate at low temps. You could try preheating it a bit before starting the tuning process.
  • @Phaedrux OK i try
  • 12/10/2020 à 22:41:21 Auto tune phase 1, heater on
    12/10/2020 à 22:41:15 M303 H1 S220
  • 12/10/2020 à 22:48:39 Auto tune heater 1 completed in 443 sec
    Use M307 H1 to see the result, or M500 to save the result in config-override.g
    12/10/2020 à 22:44:26 Auto tune phase 3, peak temperature was 229.7
    12/10/2020 à 22:44:03 Auto tune phase 2, heater off
  • Now i execut the command M500 and M501
  • Toujours des fluctuation de temp
  • Moderator
    Ok if that successfully worked you can do as DC42 said above and edit the resulting M307 command in config-overide to increase the D value.
