Job Processing
Duet Web Control
  • undefined
    Sculpt Fabricator
    Everything was working fine yesterday, but today we went to start a job and the print never starts, just processing
    we have tried sending a different job, and even the old turn off and back on
    we ran a m122 but really don't know what it might dhow as the problem that we are missing
    8:11:34 AM=== Diagnostics ===
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later + DueX5
    Board ID: 08DLM-996RU-N85T0-6J1D4-3SJ6K-TAVZR
    Used output buffers: 1 of 24 (11 max)
    Static ram: 25712
    Dynamic ram: 94196 of which 0 recycled
    Exception stack ram used: 424
    Never used ram: 10740
    Tasks: NETWORK(ready,628) HEAT(blocked,1176) DUEX(suspended,160) MAIN(running,3728) IDLE(ready,160)
    Owned mutexes:
    Last reset 00:07:25 ago, cause: software
    Last software reset at 2020-10-14 08:04, reason: User, spinning module GCodes, available RAM 10764 bytes (slot 2)
    Error status: 0
    Free file entries: 9
    SD card longest block write time: 20.1ms, max retries 0
    MCU temperature: min 32.1, current 32.4, max 33.2
    Supply voltage: min 23.3, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 2: standstill, SG min/max 0/538
    Driver 5: standstill, SG min/max not available
    Driver 6: standstill, SG min/max not available
    Driver 7: standstill, SG min/max not available
    Driver 8: standstill, SG min/max not available
    Driver 9: standstill, SG min/max not available
    Date/time: 2020-10-14 08:11:33
    Cache data hit count 1339471581
    Slowest loop: 55.31ms; fastest: 0.07ms
    Hiccups: 0, FreeDm: 160, MinFreeDm: 158, MaxWait: 101266ms
    Bed compensation in use: mesh, comp offset 0.273
    === DDARing ===
    Scheduled moves: 6, completed moves: 6, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    Bed heaters = 0 -1 -1 -1, chamberHeaters = 5 -1
    Heater 0 is on, I-accum = 0.0
    Heater 1 is on, I-accum = 0.2
    Heater 5 is on, I-accum = 0.7
    Segments left: 0
    Movement lock held by file
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is doing "M116 " in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 30.55ms; fastest: 0.01ms
    HTTP sessions: 2 of 8
    • WiFi -
      Network state is running
      WiFi firmware version 1.23
      WiFi MAC address ec:fa:bc:5b:41:b9
      WiFi Vcc 3.38, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 26184
      WiFi IP address 192.168.5.248
      WiFi signal strength -56dBm, reconnections 0, sleep mode modem
      === Filament sensors ===
      Extruder 0 sensor: ok
      Extruder 1 sensor: ok
    Duet WiFi 1.02 or later + DueX5 Firmware Version: 2.05 (2019-12-13b1)
    Thank You
    • undefined
      jay_s_uk
      I would suggest updating to 2.05.1
      https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1
      • undefined
        If that doesn't help, try a different SD card.
        Are you sure nothing has changed in the config or slicer setup?
        Are temperatures reporting correctly?
        Can you jog axis at all?
        How are you trying to start the print job?
        1 out of 3
