    More Blobbing
    92
    • tommyb
      tommyb last edited by
      Hi - using Cura 4.5 and Duet 3.1 on a Duet Wifi. I have a blobbing issue on the OD of an internal feature that is so large it is cause nozzle strikes.
      The part is a 20mmx20mm cube with 8mm hole. I am trying to dial in fits and am .05mm large on outside of cube and on ID, which I am can fix in Cura.
      Any bright minds how to tackle this type of blobbing.
      Cheers,
      Thomas
      engikeneer 1 Reply Last reply Reply Quote 0
      • engikeneer
        engikeneer @tommyb last edited by
        @tommyb a few things to try:
        • pressure advance is the main one. Looks like you need to apply some/more from that photo
        • try varying temperature a bit
        • going back to basics, how well calibrated is your extruder E-steps?
        • do the blobs occur on a layer change? Could be worth using retraction on layer change
        i3 clone with a bunch of mods
        • Veti
          Veti last edited by
          post your config
          • tommyb
            Forgot to mention E3D V6 hot end @ 195C on PLA with calibrated extrude.
            The blobs are definitely at the end of extrude. Aand now I suddenly noticed that the exact blob form is shown at the random corner seams. Probably more PA as you mention.
            Thanks for the help.
            config(1).g
            M569 P0 S0 ; physical drive 0 goes forwards
            M569 P1 S0 ; physical drive 1 goes forwards
            M569 P2 S1 ; physical driv e 2 goes forwards
            M569 P3 S0 ; physical drive 3 goes forwards
            M92 X320.00 Y320.00 Z1600.00 E410.00 ; set steps per mm
            M566 X900.00 Y900.00 Z12.00 E6000.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X8000.00 Y8000.00 Z600.00 E1800.00 ; set maximum speeds (mm/min)
            M566 P1 ;Mimic Marlin jerk
            M572 D0 S0.015 : PA
            201 X1000.00 Y1000.00 Z200.00 E600.00 ; set accelerations (mm/s^2) ----was250
            M906 X2800 Y1800 Z800 E800 I20 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            ;M915 X Y S5 F0 H200 R0 ; X / Y Axes Stall Detection
            • Veti
              Veti last edited by
              B4138
              your thermistor is not correct for e3d. you are printing at the wrong temperature.
              please select semitec in the duet configurator for your thermistor.
              • Veti
                Veti last edited by
                @tommyb said in More Blobbing:
                that line is broken
                • Veti
                  Veti last edited by
                  M92 X320.00 Y320.00
                  what kind of setup are you running. thats an unusual number
                  • tommyb
                    The cut and paste of text deleted M in Accel line, the config.g file has it...sorry for not checking.
                    I am running Core XY with with Z on X axis & 200mm bed size. I am using surplus KR ball screw rails that are way oversized in length, hence home switches are far off from bed edge. I do have to admit getting the home switches set up was far more complicated then it should have been so while this works, I am sure it could have been done better.
                    Veti 1 Reply Last reply Reply Quote 0
                    • Veti
                      Veti @tommyb last edited by
                      nice. would you post a picture?
                      • tommyb
                        Well, it is quite the monster; everything but hot end, probe and Duet are surplus $0.
                        ![0_1602866269855_1602865759210 (2).jpg](Uploading 100%)
                        • Veti
                          @tommyb
                          you have to wait a bit after the upload reaches 100%
                          • tommyb
                            Thanks for the tip.
                            • Veti
                              Veti last edited by
                              did you change the thermistor stettings? did it improve the print?
                              looking at the printer (or cnc machine), i am wondering if the long metal holding the extruder introduces wobble
                              • tommyb
                                @Veti said in More Blobbing:
                                I missed the B factor comment above. The configurator still produced a B=4138 value. I look around and saw Duet requires B=4388, tried that and way under temp on print. I will let it cool down and execute a calibration. The stability looked ok.
                                I may have an odd thermistor, is there a way to tell? It came with the Hot End.
                                Also dug a little deeper on circumferential blob and turns out Cura places a small extrusion path at the start of the layer right at the end of the path. And then follows up with at the end of the layer to join with the initial small path. This image show the HE after rotating clockwise past the initial extrude.
                                  Phaedrux Moderator @tommyb last edited by
                                  Did you add the missing M to the start of that line?
                                    What hotend exactly do you have?
                                    • tommyb
                                      The M was only missing in the cut and paste, not the actual Config.g. Thanks for checking.
                                      I have a V6 Light HE...if anybody has experience to move on from this, let me know. I need a reason to convince the wife to spend any more $ on this sport. The Heat break is SST and not easily damaged...and cheap! So far PETG and PLA seem to work fine, but I am happy to be convinced of other models (Humera)?.
                                      So after have a sudden bed thermistor open error (did not touch any wiring) and some more time troubleshooting and fixing, I looked hru various references with conflicting info and confirmed B=4275 for the Simtec 104 GT thermistor. HE and Bed have been Auto recalibrated.
                                      PA so far seems about the same from 0.05, 0.10, 0.15, 0.20 and no change vs first picture.
                                      No for twhe real problem all along. With a pretty decent print in progress, the part fails each and every time at layer 26/88 at the exact same spot in the print and with sound of skipping stepper . The part shifts the exact same 10mm of the 20mm block wall distance and prints a wall in the very middle of the part. All motors are cool and there is nothing unique in the print at this point.
                                      I started to look at the G code to see if it is somehow corrupted at that point, but is getting late. Ill also try a slower print to see if motor just needs a different input that instant. More to come.
                                      • Veti
                                        Veti last edited by
                                        that is only valid if you specify the c value as well.
                                        • tommyb
                                          Thank you Veti, yes I added a C and here is my HE config.
                                          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; RR3define E0 temperature sensor was B4138
                                          M950 H1 C"e0heat" T1 ; heater 1 uses the e0heat pin and sensor 1
                                          M570 H1 P90 T15 ; Heater@1 temp@15 out of range alarm >@90sec
                                          M143 H1 S245 ; set temperature limit for heater 1 to 250C
