    Duet3 BLTOUCH3.1 Probe deploys but doesn't trigger on Z Home
    5.3k
      It's also possible to use IO_4 or IO_5 instead of IO_7, but I'm not sure about io_9. https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Duet_Num_3
      There were some issues with the BLTouch 3.1 but I believe that was when using a tool board, but directly to the Duet 3.
      Your config looks correct. If you send M98 P"config.g" do you get any error messages?
      vistalertundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti
        M203 X6000.00 Y6000.00 Z1000.00 E1200.00
        this is why your bed is moving so fast; Z1000
        you must have changed the value in the configurator, as the default there is Z180.00
        also the configurator only offers IO_4, IO_5 and IO_7 for the bltouch.
        • vistalertundefined
          vistalert
          I only used io9 for continuity tests, as it's convenient to probe the board, so I could literally prove the signal gets to the PCB, not just the end of the wire 🙂
          I also tried moving and doing config to io5, all same results.
          I'll try the M98 and see what happens.
          I've also ordered a second BLTouch in case that is the issue, I'm planning to build a second machine anyway. Hope that will enable further elimination of 3rd party issues.
          I did find it odd that the self test command wouldn't work with the earlier firmware and with the latest it does.
          I am sure you guys are feeling the same as I am, that there is some issue with the returning signal from the BL touch in an electrical, or fault sense.
          So I can consider other options. What is a good quality alternative to the BL Touch? I have a large aluminium plate with PEI magnetic sheet, so I think there are multiple options, but want the best quality outcomes. Any recommendation are welcome.
          Vetiundefined 1 Reply Last reply Reply Quote 0
            vistalert @Veti
            @Veti I'm not sure it was the speed, as the config I downloaded by default, and used in previous tests has Z180. When I tested bed movement today, and I executed....
            G91
            G1 H2 Z1
            The bed moved more than 1mm....a lot more, so could it have been to do with steps/mm or something?
            That's why you'll see deviations between the config provided by the configurator, as I pasted back in my previous stepper configs.
            Vetiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
            • Vetiundefined
              Veti @vistalert
              @vistalert said in Duet3 BLTOUCH3.1 Probe deploys but doesn't trigger on Z Home:
              I actually prefer this over the bltouch.
              https://www.thingiverse.com/thing:3303618
              Its cheaper
              it uses an optical endstop, same (or even better) accuracy, but it gives a constant signal.
              same form factor
              • Vetiundefined
                Veti @vistalert
                as far as i can see both have Z400 for steps/mm
                  vistalert
                  That's a very smart solution with the optical endstop and easy to comprehend 🙂
                    vistalert @Phaedrux
                    @Phaedrux said in Duet3 BLTOUCH3.1 Probe deploys but doesn't trigger on Z Home:
                    M98 P"config.g"
                    OUTPUT - no errors just the heater warnings...
                    M98 P"config.g"
                    Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                    Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 318C
                    Warning: M307: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 937C
                      Phaedrux Moderator @vistalert
                      If you send M92 by itself it will report the currently configured steps per mm for all axis. Are you sure 400 is correct?
                      Formula for calculating z steps per mm with lead screw (without gearing) is:
                      Z_steps_per_mm = (motor_steps_per_rev * driver_microstep) / screw_lead
                      • Thaliosundefined
                        Thalios
                        I could not get my BL touch to work at all on ports IO6 and IO7. Only when plugged on IO5 did it work.
                        I'd try that first, easy swap.
                        Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
                        Heavily modified Ender 3 Pro (Duet 3 6HC)
                        Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
                        CR-10S Pro V2 (Duet 3 Mini 5+)
                        and a bunch of SLA printers..
                          vistalert
                          @Thalios I have tried io5 yes, didn't work. Could you please share your relevant rows from config.g for anything to do with the BL Touch and endstops. Also your deploy/retract probe.
                          What version of the BL Touch do you have? Confirm you have a Duet3 with v3.1.1?
                          Thanks!
                          Thaliosundefined 1 Reply Last reply Reply Quote 0
                            vistalert @Phaedrux
                            @Phaedrux - I have a lot to learn yet, so appreciate the input. I can't state with much confidence that anything about my configs is correct yet. I'm just in the commissioning phase of "getting things to move, or blink" and hoping that nothing goes "bang!"
                            Once I get through the BL Touch issue, I'll feel at least in control of the basic functions, and can then learn and refine as I start to do the calibration work.
                              Can you provide the results of M122 and M98 P"config.g"?
                              Are you using the Duet 3 in SBC mode?
                              M574 Z1 S2                                   ; configure Z-probe endstop for low end on Z
                              M950 S0 C"io5.out"                           ; create servo pin 0 for BLTouch
                              M558 P9 C"^io5.in" H5 F120 T6000             ; set Z probe type to bltouch and the dive height + speeds
                              G31 P500 X0 Y0 Z2.5                          ; set Z probe trigger value, offset and trigger height
                              M557 X15:215 Y15:195 S20                     ; define mesh grid
                              M280 P0 S10 ; deploy BLTouch
                              M280 P0 S90 ; retract BLTouch
                              Have you seen the BLTouch 3.1 manual?
                              https://5020dafe-17d8-4c4c-bf3b-914a8fdd5140.filesusr.com/ugd/f5a1c8_d40d077cf5c24918bd25b6524f649f11.pdf
                              Or seen this?
                              https://www.antclabs.com/logic
                                vistalert
                                @Phaedrux
                                OUTPUT FROM M122:
                                m122
                                RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                                Board ID: 08DJM-956BA-NA3TJ-6J9DL-3S86J-9T9AT
                                Used output buffers: 1 of 40 (10 max)
                                Static ram: 154604
                                Dynamic ram: 162760 of which 60 recycled
                                Exception stack ram used: 224
                                Never used ram: 75568
                                Tasks: NETWORK(ready,1972) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4952) IDLE(ready,76)
                                Owned mutexes:
                                Last reset 00:03:18 ago, cause: power up
                                Last software reset at 2020-10-21 11:50, reason: User, spinning module LinuxInterface, available RAM 75240 bytes (slot 2)
                                Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
                                Error status: 0
                                MCU temperature: min 16.2, current 28.4, max 28.5
                                Supply voltage: min 27.9, current 29.4, max 29.5, under voltage events: 0, over voltage events: 0, power good: yes
                                12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
                                Driver 0: standstill, reads 59066, writes 14 timeouts 0, SG min/max 0/0
                                Driver 1: standstill, reads 59066, writes 14 timeouts 0, SG min/max 0/0
                                Driver 2: standstill, reads 59067, writes 14 timeouts 0, SG min/max 0/0
                                Driver 3: standstill, reads 59067, writes 14 timeouts 0, SG min/max 0/0
                                Driver 4: standstill, reads 59068, writes 14 timeouts 0, SG min/max 0/0
                                Driver 5: standstill, reads 59068, writes 14 timeouts 0, SG min/max 0/0
                                Date/time: 2020-10-21 23:54:43
                                Slowest loop: 3.90ms; fastest: 0.14ms
                                === Storage ===
                                Free file entries: 10
                                Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
                                === MainDDARing ===
                                Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                === AuxDDARing ===
                                Segments left: 0
                                Movement lock held by null
                                HTTP* is ready with "M122" in state(s) 0
                                Telnet is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Queue is idle in state(s) 0
                                LCD is idle in state(s) 0
                                SBC is idle in state(s) 0
                                Daemon* is idle in state(s) 0
                                Aux2 is idle in state(s) 0
                                Code queue is empty.
                                === Network ===
                                Slowest loop: 0.83ms; fastest: 0.01ms
                                Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
                                HTTP sessions: 0 of 8
                                • Ethernet -
                                  State: disabled
                                  Error counts: 0 0 0 0 0
                                  === CAN ===
                                  Messages sent 723, longest wait 0ms for type 0
                                  === Linux interface ===
                                  State: 0, failed transfers: 0
                                  Last transfer: 18ms ago
                                  RX/TX seq numbers: 5844/5845
                                  SPI underruns 0, overruns 0
                                  Number of disconnects: 0
                                  Buffer RX/TX: 0/0-0
                                  === Duet Control Server ===
                                  Duet Control Server v3.1.1
                                  Code buffer space: 4096
                                  Configured SPI speed: 8000000 Hz
                                  Full transfers per second: 0.13
                                  vistalert @Phaedrux
                                  @Phaedrux
                                  OUTPUT FROM M98 P"config.g"
                                  10/22/2020, 6:55:46 AM M98 P"config.g"?
                                    vistalert
                                    @Phaedrux
                                    Yes, running with SBC - Pi4. Done all the apt-get update/upgrade stuff. Upgraded firmware on D3 to 3.1.1, validated that the Pi has all the relevant components versioned at 3.1.1 too.
                                      If you're absolutely positive that the wiring is correct, I would suggest trying to setup the Duet3 in standalone mode just to take the Pi and DSF out of the equation entirely.
                                      The easiest way to do this is to create a new SD card with the usual folder structure.
                                      https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
                                      Make sure the /www folder has the contents of the DWC 3.1.1 files.
                                      https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/DuetWebControl-SD-3.1.1.zip
                                      Download your current config files from DWC by clicking the check box to select all files, right click and save as zip. Then extract that zip file into the /sys folder on your new SD card.
                                      Place that SD card in the Duet 3 and disconnect the Pi ribbon cable.
                                      Then test the BLtouch as described here.
                                      https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                                        vistalert
                                        @Phaedrux
                                        With respect to the following - I have seen the documents, but without being told anything is necessary, short of being instructed to do so, I've not done anything other than setup the config.g
                                        Phaedrux Have you seen the BLTouch 3.1 manual?
                                        vistalert: Yes - I note with interest the text "Z trigger with adaptable width: "
                                        Do you feel it's advisable to do something in this context? Has anybody had to do this with a D3, BL Touch 3.1?
                                        Do you guys have a D3 and BL Touch 3.1? I think I saw some posts previously that mentions you have tested this.
                                        Or seen this?
                                        vistalert: Yes I have - Does the Duet3 fall into this category? "A board with a large capacity capacitor in the end-stop input circuit, such as the Melzi"
                                        Being connected to io7 and +5v means that might BL touch out of the box should be good to go, no?
                                        The only thing I can think of from the above documents is the pulse width comment.
                                        I'd like to do any further changes on this premise, if possible:
                                        1. Has the Duet team tested BL Touch 3.1 with Duet3 and firmware 3.1.1?
                                        2. If yes, and it's working, what do I need to do to get to the same level of success?
                                        3. Given my wiring appears to be fine, either the BL touch may be faulty, or there is a comms / timing issue, as indicated by the PWM comment in the 3.1 documentation.
                                        Does the above sound sensible?
                                        I don't want to randomly go off trying stuff, as you guys lose control of the troubleshooting flow, and I may have or leave the device(s) in a dysfunctional or unknown state.
                                        Happy to work step by step with "If you do this, what does M???? report" or "try this, expect this...."
                                        Thanks.
                                          No you're not the first to have some issues with the BLTouch 3.1. There were some issues when connected to the tool board that we are now aware of, but there have also been some cases with it not working as expected with the Duet3. It's also been reported to work fine, so further investigation is necessary.
                                          The reason I bring up the manuals, etc is just to give us all the relevant information while we investigate.
                                          It is certainly possible that the BLtouch is faulty. It wouldn't be the first time. Your config is correct, and you have checked the wiring, so either the BLTouch is faulty or there are some firmware issues with the 3.1 specifically. Both are possible.
                                          I don't have further things to try other than my description of testing standalone mode and testing a new BLTouch. I've brought it to DC42s attention as well, so he may have some things to test soon.
                                            vistalert
                                            Sounds good, and again, thank you. I actually run a tech support team myself, so I truly appreciate how difficult and challenging this is. I'm also willing to do what ever I can to assist...as my first message said, this is an awesome product, and I can't imagine trying to do this stuff if we had to keep flashing firmware. With RR, it's easy to quickly spin a config and diagnose.
                                            I have actually ordered a second BL Touch. It may be here in a couple of days, fingers crossed. Just FYI, my dad (I'm 56, he's 80!) is a micro-electronics guru, and even he grilled me about the risk of bad wiring / crimping. He pointed out, even with continuity, it's possible to have too much resistance, as well as other issues. So we did carefully go through the connector pins and add some solder too to ensure a guaranteed solid connection. Just worth noting, as my initial confidence based on "continuity" isn't necessarily proof that there's nothing wrong with the cabling.
                                            I don't feel inclined to do anything about logical level, as clearly the D3 supplies 5V, and the BLT3.1 seems to work that way by default.
                                            I'm definitely interested in the PWM width comment.
                                            Given I have a D3, and Pi 4, there's two high performing pieces of kit here. If the timing is out at all in the communications via the BLT OUT -> io7.in then there is something worth investigating there.
