    Duet3 BLTOUCH3.1 Probe deploys but doesn't trigger on Z Home
    5.3k
    • vistalertundefined
      vistalert @Veti
      @Veti I haven't yet got a reliable homeall.g as I haven't commissioned the BLTOUCH.
      I have Home X and Home Y, which are sensorless (pending delivery of endstops)
      So what I'm trying for test purposes is this:
      1. Execute M401 - probe deploys - touch the end of the probe briefly enough to make the BLT light red. It must be released in < 650ms is my understanding, else it errors. At no time during repeated touches does the Z sensor in DWC show anything other than 0.
      2. I use a macro to drop the bed 10mm. I execute HOME Z - with my hand on the power button, because every time I test this, the bed is going to hit the nozzle.
      For what it's worth, this is the homeall.g I've built from copy / paste / learning about sensorless homing:
      My objectives here, home to front left using sensorless. Then move to centre of bed and probe there for Z home. Welcome your comments recommendations, as always.
      M400 					; wait til stuff stops
      M574 X1 Y1 S3 			; use stall guard for endstops
      M201 X2000 Y2000 		; reduce acceleration on X/Y to stop false triggers
      M915 P0:1 S3 R0 F0 H400	; both motors because corexy; Sensitivity 4, don’t take action, don’t filter, 400steps/sec
      G91 					; relative Positioning
      G1 H2 Z5 F1200			; lower the bed
      M913 X44 Y44  			; drop motor currents
      G1 H1 X-500 F5000 		; move until the motor stalls - COARSE HOME
      M913 X100 Y100  		; motor currents back to 100%
      G1 H2 X30 Y0 F1200		; move away from end
      M913 X32 Y32  			; drop motor currents
      G1 H1 Y-500 F4000 		; move until the motor stalls - COARSE HOME
      G1 H2 X0 Y10 F1200		; move away from end
      G90 					; back to absolute positioning
      M201 X3000 Y3000 		; accel back to original
      G90 					; absolute positioning
      G1 X250 Y250 F13000 	; Move x and Y axis over to bed center so probe is on top of bed
      M558 A1 F400 			; Set single probing at faster feed rate
      G30 					; Do a single probe to home our Z axis
      M558 A3 F100 			; Set tripple probing at slower feed rate
      G30 					; Probe again to get a more accurate position
      G28 X Y
      Vetiundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti @vistalert
        @vistalert said in Duet3 BLTOUCH3.1 Probe deploys but doesn't trigger on Z Home:
        the bltouch pulse is so fast that you will not see it go to 1000.
        have you run the bltouch self test? its
        M280 P0 S120
        (edits it S120)
          vistalert
          I will try. But that runs on power up no?
          At power on, I see the pin bounce twice then the BLT tests with solid red LED.
          • Vetiundefined
            Veti @vistalert
            no the self test will retract and deploy the pin 10 times
            vistalertundefined 1 Reply Last reply Reply Quote 0
            • Vetiundefined
              Veti
              what firmware version are you on (i hope the latest 3.1.1)
                vistalert @Veti
                @Veti understood
                M280 P0 S120 - Don't get any activity from BLT
                My firmware is:
                RepRapFirmware for Duet 3 MB6HC version 3.01-RC9 running on Duet 3 MB6HC v1.01 or later
                • Vetiundefined
                  Veti @vistalert
                  3.01-RC9
                  please update to 3.1.1 there were some versions with bltouch problems
                    vistalert
                    Sure thing
                      vistalert
                      @Veti Completed all the upgrades to 3.1.1
                      Confirming that the BLTOUCH 3.1 self-test does now execute after the upgrade to 3.1.1.
                      M401/402 deploys and retracts.
                      Home Z does not stop the bed raising when probe touches the bed.
                      Lightly touching the probe doesn't register on DWC Z sensor, the value stays at 0.
                      A reminder, that as the bed doesn't retract within 650ms, the BLT goes into error.
                      If I manually push the pin up, then issue the BLT reset command, it does reset ready for next test cycle.
                      So, some progress 🙂
                      Bear in mind I still have questionable bed.g, homez.g - almost all of my config stuff is copy /paste from elsewhere.
                      Not sure if Z endstop setting is needed in config,g as it is put there by the configurator, but then people say it's not needed, and others say it is.
                      Please advise next steps and many thanks for the patient support so far.
                      • Vetiundefined
                        Veti @vistalert
                        i would suggest you create them using the configurator. this will give you clean files with bltouch support. select bltouch there and the generated files should be good.
                        this is not normal, try again with the clean config
                          vistalert
                          Got the clean configs.
                          Do I need to set the Z screw locations AND do something to bed.g in relation to probing close to the screws?
                          • Vetiundefined
                            Veti @vistalert
                            @vistalert
                            for now focus on the bltouch problem
                              vistalert
                              The BLT and bed are intrinsically linked for Z probing, so don't we need to ensure bed.g and homez.g are in alignment?
                              What steps do you want me to take now that I have the clean files? These files are initially not suitable without editing (which as a newbie is challenging). For example, the Z was travelling way too fast. There's no support in the configurator for triple steppers.
                              What specific steps do you want me to take with what specific actions from the UI, or GCODE from the console?
                              I think we need a less generic approach, and I need to be told: do this, expect this.
                              We spent all day yesterday circling around my wiring, to find we should have started with the firmware version. Today you're telling me to use the configurator and without specific knowledge of the stepper setup, the bed almost shot off the top of the screws at high speed.
                              • Vetiundefined
                                Veti @vistalert
                                the bed.g is used for leveling the bed using independent z motors. this required a working probe.
                                the homez from the configurator should be correct. please post it to verify.
                                https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help/11
                                i wanted to rule out any problem in your config file. if the files from the configurator with selected bltouch do not work, we can rule out a config problem.
                                for the 3 z motor just add the motors back to M584.
                                to change the speed of z change it in https://configtool.reprapfirmware.org/Motors Max. Speed (mm/s). the default is 3mm/s. is that too fast?
                                remote debugging is hard. and you did not provide all the information specified in the guide on how to ask for help https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help/11
                                so post the new config files that you generated.
                                see if the bltouch is now working. next maybe the port is bad.
                                so switch to a different port in the configurator and move the wiring.
                                but to be honest, i think the bltouch is broken.
                                  Please post your new files for 3.1.1 config.g, homing files, bed.g and a thorough description of your printer hardware and we can work from there.
                                    vistalert
                                    Thank you @Phaedrux - I will certainly do that. Also, I'd like to apologise to @Veti for the tone of my previous post. I was a little shaken by what happened with the bed raising, but no excuses. I didn't mean to be rude.
                                      Any time testing motor movement on a new printer it's wise to reduce motor currents in case of a crash. And always have a hand near the power switch. This is true of any printer/board/firmware.
                                        vistalert
                                        XYZ Steppers are all: LDO Motors 1.8degree - LDO-42STH47-2504AC
                                        BL TOUCH 3.1
                                        Extension cable from BLT to D3 board is two twisted pairs:
                                        pair 1 is +5v/Gnd
                                        second pair is in/out.
                                        Build plate 500x500x500
                                        Z screw offsets as per config
                                        Thanks again
                                        I can't upload a zip file, but here is the entire set of config files:
                                        tpre0.g tpost0.g tfree0.g stop.g sleep.g retractprobe.g resume.g pause.g homez.g homey.g homex.g homeall.g dwc2settings.json deployprobe.g config-override.g config.g bed.g
                                          vistalert
                                          By the way - I just moved the connector for the BLTouch from io7 to io9 for another quick continuity test, so I could prove continuity by probing from the PCB on the BLT, to the back of the Duet3 PCB. All wires run pin to pin.
                                            It's also possible to use IO_4 or IO_5 instead of IO_7, but I'm not sure about io_9. https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Duet_Num_3
                                            There were some issues with the BLTouch 3.1 but I believe that was when using a tool board, but directly to the Duet 3.
                                            Your config looks correct. If you send M98 P"config.g" do you get any error messages?
