    T1 Offset on dual extrusion
    • koreandiundefined
      koreandi
      Hi there.
      I finished building up my Kodak Portrait printer with the DUET Wifi Board. It works all fine until now. 🙂
      I want to enable my second Nozzle but don´t get it.
      I put in the T1 offsets in config.g:
      M563 P0 D0 H1 F0                                  ; define tool 0
      G10 P0 X0 Y0 Z0                                   ; set tool 0 axis offsets
      G10 P0 R100 S200                                  ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 D1 H2 F0                                  ; define tool 1
      G10 P1 X-28 Y0 Z-2.0                              ; set tool 1 axis offsets
      G10 P1 R100 S200                                  ; set initial tool 1 active and standby temperatures to 0C
      By manually testing the Z-offset it sees to work.
      1. Homing Z with T0 (Probe is nozzle-triggered)
      2. Check nozzle height of T0 --> Okay
      3. Change to T1
      4. Move T1 to bed
      5. Check nozzle height --> Okay
      But if i run a S3D sliced file my Nozzle T1 will drive a few mm against my bed. It seems that the Z-offset is not recognized.
      Any clue what I did wrong?
      Is there any file I should provide you?
      Compared to my T0:
      X: T1 is about 28 mm left of T0.
      Z: T1 is about 2 mm closer to the bed when activated
      Y: T1 is nearly the same position as T0
      In S3D there is nothing set in Offsets.
      Greetings
      Andreas
      TCundefined 1 Reply Last reply Reply Quote 0
      • TCundefined
        TC @koreandi
        @koreandi first you should manually switch between Tools using T0 P0 and T1 P0 and check if the Coordinates displayed in DWC change as expected
        • koreandiundefined
          koreandi
          Yes, by switching manually the X-coordinate changes for 28 mm and also the Z-axis moves 2mm as expected.
          • koreandiundefined
            koreandi
            If important:
            I have nothing declared in tfreex.g or tprex.g files.
            I put in my toolchange script in tpost
            tpost0.g:
            ; tpost0.g
            ; called after tool 0 has been selected
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 30 2020 18:35:35 GMT+0200 (Mitteleuropäische Sommerzeit)
            ; Wait for set temperatures to be reached
            G91				;set to relative
            G1 Z5 F9999		;move Z 5 mm up
            G90				;set to absolute
            G1 X195 F9999	;move quickly near switch position
            G1 X215 F250	;switch to E1
            G1 X195 F9999	;move back
            G1 Z-2 F9999	;go back to initial Z-Position
            M116 P0			;wait for extruder
            tpost1.g
            ; tpost1.g:
            ; called after tool 1 has been selected
            G1 X0 F9999		;move quickly near switch position
            G1 H1 X-14 F250	;switch to E0
            G1 X0 F9999		;move back
            G1 Z-5 F9999	;go back to initial Z-Position
            M116 P1			;wait for extruder
            • koreandiundefined
              koreandi
              Has anyone else a clue?
                Phaedrux Moderator @koreandi
                @koreandi said in T1 Offset on dual extrusion:
                These relative moves are just raising the Z further and further. raise by 5, lower by 2? That doesn't seem right?
