    NOBODY USE RJ11, IT IS 2020 !! PLEASE USE RJ45 LIKE EVERYONE !!!
    11
    723
    • jrocklandundefined
      jrockland
      I just realize you guy used rj11 instead of rj45 like normal person in 2020. we are not in 1980 anymore, and we cant find those cable connector anywhere !! now Ill have to wait another week to get them and HOPE they fit my crimpers.
      Vetiundefined fcwiltundefined 2 Replies Last reply Reply Quote -3
      • Vetiundefined
        Veti
        i just went to amazon typed in rj11 and it came up
        https://www.amazon.de/-/en/100-Pcs-RJ11-Plug-Telephone-Modular-Adapter/dp/B06XNLYFBN/
        • dragonnundefined
          dragonn
          This is still a standard in 2020, just for different things. And RJ45 would be an overkill for CAN bus and just to bulky.
          Also you could really read that before you did by the board, and they is no "HOPE they fit my crimpers". Or you have RJ11 compatible crimpers or not, you should know what tools you have...
          • Vetiundefined
            Veti @jrockland
            @jrockland said in NOBODY USE RJ11, IT IS 2020 !! PLEASE USE RJ45 LIKE EVERYONE !!!:
            i want to see you sticking an rj45 connector into an standard asdl modem. you are gonna be surprised to find them to be rj11. even in 2020.
            • sebkritikelundefined
              sebkritikel
              https://www.digikey.com/en/products/filter/modular-connectors-plugs/367?s=N4IgTCBcDaIE4CsCMSQF0C%2BQ
              Happy to help.
              Large(ish?) IDEX - 6HC, 1HCL
              Stratasys Dimension 1200es to 6HC Conversion
              • JuJuDeltaundefined
                JuJuDelta
                HAHAHAHAHAHA !
                With respect to Duet3, I personally think it's a good idea to have RJ11 for the CAN and RJ45 for the Ethernet. Stops me putting things in the wrong hole !
                Remember Duet3 CAN wiring is 1:1 on the RJ11.
                Cross over cables often come bundled with modems etc.
                RJ11 lives matter.
                T3DP3D Kossel XL+, Duet2Wifi, PanelDue 7i, RRF V3.2, Fl3xdrive, SmartEffector, Berd Air annulus, Cura 4.x, PrusaSlicer, RPi WiFi Camera, Heated Chamber
                A Former User? 1 Reply Last reply Reply Quote 1
                • A Former User?
                  A Former User @JuJuDelta
                  RJ11 lives matter.
                  (but nobody cares about RJ10 and RJ12!)
                  • fcwiltundefined
                    fcwilt @jrockland
                    @jrockland
                    RJ11 and RJ45 are not the same at all.
                    Using RJ11 for the CAN Connections on the Duet 3 makes sense.
                    The CAN bus has no need of the pins or the capabilities of a RJ45 connection.
                    So take a deep breath and relax.
                      For making CAN connections, I mostly use ready-made high speed ADSL cables from here https://www.kenable.co.uk/en/search?controller=search&search_query=high+speed+adsl. When I have to make my own cables, I use one of these https://www.amazon.co.uk/RJ45-Crimping-Crimps-Plugs-Insertion/dp/B006P0EG7C/ref=sr_1_6.
                      Both the cables and the crimper are inexpensive.
                      • A Former User?
                        A Former User
                        So much butthurt
                        JuJuDeltaundefined 1 Reply Last reply Reply Quote 0
                          JuJuDelta @A Former User
                          @CaLviNx said in NOBODY USE RJ11, IT IS 2020 !! PLEASE USE RJ45 LIKE EVERYONE !!!:
                          So much butthurt
                          No don't plug it in there !
