Capacitive Sensor
  • Hello,
    I would like to test with a 12mm NO capacitive sensor.
    I have a Duet3D 2 and RRF 3.1.1 card, do we have to put a diode on the Z_Probe?
    Thank you.
  • You shouldn't need one no.
    (IIRC when its triggered, a NO NPN device will be connecting the black wire to the ground.)
    I'm running the same type of device, just the inductive sensor version.
  • @Rudy2A said in Capacitive Sensor:
    are you sure its npn and non pnp?
    do you have a duet wif v1.04?
  • Hi,
    I tried one on my printer because of problems with an inductive sensor interacting with my magnetic build surface.
    The problem with the capacitive one was it's slow response time. It has a 50 Hz switching frequency.
    The inductive ones I tried ranged from 800 Hz to 3000 Hz.
    Let us know how it works.
  • Yes.
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
    not the firmware but the hardware revision.
    see https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
    Duet 3, Duet 2 Maestro, or revision 1.04 or later of Duet 2 WiFi or Duet 2 Ethernet: you can connect the output of the sensor directly to the Z-probe IN pin.
    on 1.04 you dont need the diode
  • @theruttmeister said in Capacitive Sensor:
    What result do you get? Are you satisfied?
  • @Veti
    So for me, I need one ... I'm Duet WiFi 1.02 if I understand correctly?
    no you look up the writing on the board.
    the firmware can not tell the difference between 1.02, 1.03 and 1.04
  • @Veti said in Capacitive Sensor:
    ok, on my packaging box is written . V1.04b
    just to be sure check under the 2 thermistors plugs
    see https://www.duet3d.com/image/cache/catalog/v104/Wifi_v1.04_above_wb_small-800x800.png
    where it says duet2 V1.04
    Thank you, that's it ... duet2 v1.04
    Yes.
    But I'm using a relatively expensive sensor (from IFM), and with printers that have either steel beds or steel flex-plate type surfaces.
    There was a bunch of testing done a few years ago, we looked at most types of proximity sensors... we found that while inductive are not the most accurate, they are much more consistent than the other options. We found that capacitive sensors vary a lot with ambient temperature, for example. Optical could vary wildly if you use glue on your build surface.
    They are not perfect, but good enough that I don't worry about finding something better.
  • there is a video from tom about it
    https://www.youtube.com/watch?v=il9bNWn66BY
  • Return to the installation.
    The wiring is very simple and the adjustment of the probe in Config.g too.
    Where it goes wrong is with the mesh of the bed ... impossible to have a complete mesh. The nozzle only probes the 2 ends of the front of the deck and stops ... yet normally it should probe all 4 corners as configured.
    Tired of searching, I will put back my mini IR probe which for me is not exceptional either (I expected to be frank to be more precise).
    this is most likely because you did not take the probe offset into consideration.
    post your config.g
  • @Veti
    Exactly, I thought about taking the offset of my probe ... the G32 work good.
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 26 2020 11:25:15 GMT+0100 (CET)
    M550 P"My Printer+" ; set printer name
    M669 K1 ; select CoreXY mode
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0 S0 ; physical drive 0 goes forwards
    M569 P1 S0 ; physical drive 1 goes forwards
    M569 P2 S0 ; physical drive 2 goes forwards
    M569 P3 S0 ; physical drive 3 goes forwards
    M569 P4 S0
    M584 X0 Y1 Z2:4 E3 ; set drive mapping
    M671 X-58:317 Y132:132 S10 ; vis à plomb à gauche (connectées à Z) et à droite (connectées à E1) de repère X
    M92 X80.00 Y80.00 Z1600.00 E830.00 ; set steps per mm
    M566 X600.00 Y600.00 Z60.00 E2400.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X11639 Y11639 Z200 E600 ; set maximum speeds (mm/min)
    M201 X800.00 Y800.00 Z40.00 E300.00 ; set accelerations (mm/s^2)
    M906 X950 Y950 Z950 E1120 I20 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X0 Y0 Z-0.5 S1 ; set axis minima
    M208 X270 Y270 Z245 S0 ; set axis maxima
    M574 X1 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
    M574 Y1 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
    ;M574 Z1 S2 P"io2.in" ; Axe Z avec deux moteurs, butées min.
    M558 P5 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
    G31 P500 X0 Y-43 Z1.30 ; set Z probe trigger value, offset and trigger height
    M557 X11:250 Y11:252 S20 ; define mesh grid
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
    M307 H0 A435.0 C388.3 D7.8 B0 S0.8 V13.4
    ;M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
    M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
    M307 H1 A650.7 C221.3 D4.8 B0 S1 V13.3
    ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
    G32 does not create a mesh. G29 does
    G32 does true bed leveling.
    post your bed.g
  • @Veti
    I have known this for a little while and thanks to this forum that there is a difference between G32 and G29. It was just a tip in case ... 😉
    ; bed.g
    G28 ; Home all Axes
    M561 ; Efface la correction de plan
    M290 R0 S0 ; Efface Baby-stepping
    ; Bed levelling (G32)
    G30 P0 X0.0 Y132 Z-99999; sonde près d'une vis sans fin, à mi-chemin le long de l'axe Y
    G30 P1 X260 Y132 Z-99999 S2; sonde près d'une vis et calibrez 2 moteurs
  • @Rudy2A
    that only has 2 probe point. why do you think it should probe 4 points?
  • This configuration works perfectly with the IR probe.
    S2 probes the 4 corners (2X2).
    If you put S4, it will probe 4 points on the first line multiplied by 4, so 16 points on the bed.
    This is valid for S3, S6 ...
  • @Rudy2A
    so you are talking about G29 and not G32.
    This does not match.
    Also there will be an error message in the console telling you whats wrong.
    Y252 can not be reached with an offset of -43
    change this to
    M557 X11:250 Y11:220 S20 ; define mesh grid
    Y252 ne peut pas être atteint avec un décalage de -43
    changez ceci en
    M557 X11: 250 Y11: 220 S20; définir la grille de maillage
    thank you,
    Indeed, with that it works ...
    On the other hand, depending on the tests carried out, the capacitive or IR probe is similar. I would tell you that my finding to come.
  • I definitely left the capacitive probe to the detriment of the mini IR probe.
    The reason is that for me the weight of the capacitive probe was a bit too heavy. She was exerting a difference on my bed when polling.
    FYI, my bed is not absolutely stable and the slightest difference in weight causes a difference in the measurement in the height map.
    I will be working on another much more stable bed system soon, so I will test again.
  • @Rudy2A
    there a small capacitive probes like the pinda probe
