Strange fan problem
  • Hi,
    I Duet wifi and I supply it with 24v
    I have a E3D v6 24v setup and corresponding e3D fan for hotend.
    All has been running great until the fan stopped, I have tested another fan and cables with no luck.
    The I took a multimeter and measured voltage on FAN1, it shows 12v.. I have not changed anything.. It should read 24v, right. FAN0 gives 24v..
    Can someone explain if Im being stupid or if something changed.. To make it even odder I tested with another Duet Wifi but with same config card.. same result 12 v on FAN1
  • are you sure that the multimeter is working?
    have you measured the voltage of the powers supply with that multimeter?
  • @Veti
    Yes I did, its working.
    Just because I wrote this post it now turns again.
    Whatever fixes the problem is good 😀
  • @RogerL
    i would suggest you check the wiring.
    maybe there is bare wiring, or the wire is not making good contact
