    Mesh calibration always outside printbed
    mesh area compensation mesh compensation mesh leveling print move
    860
    • vcaldasundefined
      vcaldas
      Hi guys,
      DuetMaestro/Firmware3.2-beta/
      I manage to get the homing with a BLTouch working.
      The endstops are set and the printer is measuring correctly the distances.
      Howerver, if I run mesh compensation (G29), the probe always start outside the printbed.
      It seems that it is ignoring M557
      This is what I have on config.g
      M950 S0 C"^zprobe.mod" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F240 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X35 Y35 Z0.1 ; set Z probe trigger value, offset and trigger height
      M557 X35:200 Y35:200 S55 ; define mesh grid
      I will be happy to provide all the files. Any suggestion on where to start?
      Vetiundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti @vcaldas
        @vcaldas
        the rest of the config file would help
        if you go to X0 Y0 is the nozzle on the bottom left corner of the bed?
        is your prove 35 milimeter to the right of the nozzle and 35mm behind?
        • vcaldasundefined
          vcaldas
          @Veti
          Adding the config fileconfig (2).g
          If I go to X0 Y0, the nozzle is exactly at the corner of the printbed and the probe is out of the printbed.
          If I go to X35 Y35 , then both are where they should be.
          • Vetiundefined
            Veti @vcaldas
            @vcaldas
            M208 X220 Y220 Z210 S0 ; set axis maxima
            There is your problem 200+35 = 235
            that is larger than your bed.
            • vcaldasundefined
              vcaldas
              @Veti Thanks for the suggestion.
              I changed to X50:150 S50 So it is now for sure smaller than the bed and is still having the same issue.
              It's not zeroing on X50 for mesh levelling, but on X0 Y0
              • Vetiundefined
                Veti @vcaldas
                @vcaldas said in Mesh calibration always outside printbed:
                what do you mean by zeroing?
                • vcaldasundefined
                  vcaldas
                  Sorry for lack of clarification.
                  Zeroing was the first point to be probed.
                  I would expect the probe starts at X50 Y50 but it is going again to X0 Y0
                  • Vetiundefined
                    Veti @vcaldas
                    @vcaldas
                    did you change y as well. it has the same problem as x
                    did you restart after the changes?
                    • vcaldasundefined
                      vcaldas
                      Yes. Both X and Y and giving the same error.
                      I restarted the machine, Checked the files, all is updated.
                      I even put the printer and X40 Y40 and I would expect to be on X50 Y50... it went directly to X0 Y50...
                      Not sure what to do...
                      • Vetiundefined
                        Veti @vcaldas
                        @vcaldas
                        post your changed config
                        vcaldasundefined 1 Reply Last reply Reply Quote 0
                        • vcaldasundefined
                          vcaldas @Veti
                          @Veti Found the issue!
                          I was adding the offsets for X and Y as well and they should be 0
                          The new line becomes
                          G31 P500 X0 Y0 Z0.1 ; set Z probe trigger value, offset and trigger height
                          Problem solved!
                          Thanks for the patience and help!
                          • Vetiundefined
                            Veti @vcaldas
                            no this is incorrect for a bltouch. this means that the nozzle would be the probing point. this will give you an incorrect mesh.
                            • vcaldasundefined
                              vcaldas
                              @Veti that's a very good point.
                              Fixing it to the correct values, there is no more error.
                              G31 P500 X-22 Y0 Z0.1
                              Thanks for pointing that out!
