What the frick is that? stuttering
  • Hey guys,
    since yesterday I am getting weired issues while printing. The printhead is moving a little and then pausing (and so one) causing ugly and failed prints.
    https://ufile.io/xfq2p9iu
    Anyone has an idea?
    EDIT:
    After the stuttering occurs I ran a M122 - is there a problem with the hiccups?
    Could it has something to do with temperature - sometimes is happens on the seccond layer - sometimes 90% through the print.
    I already cleared some files from the duet but no change in behavior
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.0 running on Duet WiFi 1.02 or later + DueX5
    Board ID: 08DLM-996RU-N8PS0-7J9FA-3S86S-9B8HP
    Used output buffers: 1 of 24 (19 max)
    Static ram: 28180
    Dynamic ram: 96388 of which 44 recycled
    Exception stack ram used: 592
    Never used ram: 5868
    Tasks: NETWORK(ready,44) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1552) IDLE(ready,80)
    Owned mutexes:
    Last reset 01:37:27 ago, cause: power up
    Last software reset at 2020-10-30 17:12, reason: User, spinning module GCodes, available RAM 6480 bytes (slot 0)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
    Error status: 0
    MCU temperature: min 15.1, current 43.1, max 43.2
    Supply voltage: min 23.3, current 23.6, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: standstill, SG min/max 0/1023
    Driver 1: standstill, SG min/max 0/1023
    Driver 2: standstill, SG min/max 0/1023
    Driver 3: standstill, SG min/max 0/186
    Driver 4: standstill, SG min/max 0/44
    Driver 5: standstill, SG min/max 0/1023
    Driver 6: standstill, SG min/max not available
    Driver 7: standstill, SG min/max not available
    Driver 8: standstill, SG min/max not available
    Driver 9: standstill, SG min/max not available
    Date/time: 2020-10-31 13:00:01
    Slowest loop: 54.93ms; fastest: 0.14ms
    I2C nak errors 14, send timeouts 517456, receive timeouts 13, finishTimeouts 517471, resets 517470
    === Storage ===
    Free file entries: 8
    SD card longest read time 5.0ms, write time 127.4ms, max retries 0
    Hiccups: 3085(0), FreeDm: 169, MinFreeDm: 85, MaxWait: 587524ms
    === MainDDARing ===
    Scheduled moves: 106440, completed moves: 106439, StepErrors: 0, LaErrors: 0, Underruns: 0, 4 CDDA state: -1
    === AuxDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
    Heater 0 is on, I-accum = 0.0
    Heater 1 is on, I-accum = 0.5
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    Daemon is idle in state(s) 0 0, running macro
    Code queue is empty.
    === Network ===
    Slowest loop: 129.63ms; fastest: 0.00ms
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is active
      WiFi firmware version 1.23
      WiFi MAC address 84:0d:8e:b3:04:fb
      WiFi Vcc 3.41, reset reason Unknown
      WiFi flash size 4194304, free heap 24280
      WiFi IP address 192.168.2.100
      WiFi signal strength -56dBm, reconnections 0, sleep mode modem
      === DueX ===
      Read count 503, 5.16 reads/min
  • Can you post the Gcode of the file and the config.g and the output of the M122 ? 😉
  • @taconite said in What the frick is that? stuttering:
    its your wiring to the duex that is causing the problems
    did you adhere to the wiring described here?
    https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
  • seem like a lot of time-outs.
    About the wiring:
    • ribbon cable --> check
    • short connection of the 2 GNDs --> check (30mm cable) (in my configuration the duet2 and the duex5 are mounted back to back with 20mm of air flow gap) The gap is ventilated by 2 fans. The electronics compartment is under the heat bed and is againd ventilated by a big fan. The temperatures never rise beyond 45 °C.
    • low resistance --> check, 2,5 mm²
    • not reversed --> check
    try the wiring as it is in the pictures. maybe that helps.
  • @Veti but why would that help?
  • @taconite
    i seem to remember that the i2c error can stem from grounding issues.
  • start of a new print (2 mins in)
    M122
    Used output buffers: 3 of 24 (24 max)
    Static ram: 28180
    Dynamic ram: 96288 of which 44 recycled
    Exception stack ram used: 512
    Never used ram: 6048
    Tasks: NETWORK(ready,60) HEAT(blocked,1168) DUEX(suspended,160) MAIN(running,1552) IDLE(ready,80)
    Owned mutexes: WiFi(NETWORK)
    Last reset 00:15:21 ago, cause: power up
    Last software reset at 2020-10-31 15:15, reason: User, spinning module GCodes, available RAM 6696 bytes (slot 2)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
    Error status: 4
    MCU temperature: min 32.8, current 33.2, max 33.4
    Supply voltage: min 23.5, current 23.5, max 23.7, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: ok, SG min/max 0/256
    Driver 1: ok, SG min/max 0/348
    Driver 2: ok, SG min/max 0/344
    Driver 5: ok, SG min/max not available
    Date/time: 2020-10-31 15:31:19
    Cache data hit count 1437815031
    Slowest loop: 4.68ms; fastest: 0.15ms
    === Storage ===
    Free file entries: 9
    SD card longest read time 3.5ms, write time 0.0ms, max retries 0
    Hiccups: 0(0), FreeDm: 156, MinFreeDm: 121, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 2036, completed moves: 1996, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3
    === AuxDDARing ===
    Segments left: 1
    === Network ===
    Slowest loop: 199.87ms; fastest: 0.09ms
    • WiFi -
      Failed messages: pending 0, notready 0, noresp 4
      WiFi Vcc 3.42, reset reason Unknown
      WiFi flash size 4194304, free heap 24048
      WiFi signal strength -57dBm, reconnections 0, sleep mode modem
      === DueX ===
      Read count 0, 0.00 reads/min
    3.1.0
    just for completeness. you should update to 3.1.1
  • I tried multiple times - failed multiple times (got stuck) and I had to bossa back to 3.1.0.
    what was the error?
  • Moderator
    Sounds like you might be missing some files.
    Try uploading the entire 3.0 zip file and then the 3.1.1 zip file.
    https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
    https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
    Upload them one at a time to the system tab in DWC. Don't extract them first.
