    IDEX Printer Commands
    1.2k
    • jensus11undefined
      jensus11
      I have a problem, I don't understand what I have to enter in the slicer (S3D) when I want to print mirror duplication.
      Can someone explain this and help me to set up?
      regards
      Jens
      oliofundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • oliofundefined
        oliof @jensus11
        @jensus11 a mirror print is a copy print with the U axis reversed. Basically you need to define a "virtual tool" using both print heads where the U axis is reversed.
        S3D should not need any special settings other than choosing that virtual tool in the startup gcode. You need to make sure the mirrored part is not too large and stays within each tool's print area and doesn't overlap.
        • jensus11undefined
          jensus11
          Ah, i understand but what is the command for the tool in the start code?
          • oliofundefined
            oliof
            @jensus11 if you follow the instructions for IDEX machines at the wiki (cannot copy and paste right now, so no link, sorry), the first tool is T0, the second is T1, and the copy mode virtual tool is T2. If you were to add a mirror mode virtual tool, it would be T3. But it depends on your configuration. mirror mode is achieved by modifying your tfree and tpost macros as outlined in the section I link to in the next comment.
            • oliofundefined
              oliof
              And a reboot later, here is Creating a Tool that Uses More than One Carriage to Print Multiple Copies of an Object.
                dc42 administrators @jensus11
                @jensus11 said in IDEX Printer Commands:
                regards
                Jens
                If you have set up your M208 commands so that X0 Y0 is the centre of the bed (and configured your slicer to centre the print on X0 Y0), then you just need to do two things to use duplication or mirror mode:
                1. Make sure that the print fits in the available width. This will be half the normal width using duplication mode, and a little less using mirror mode.
                2. Tell the slicer to use the duplication tool or the mirror tool. If you followed our suggestions in the wiki, these are T2 and T3 respectively.
                • jensus11undefined
                  jensus11
                  Thanks for your help. I configured everything as in the manual. But my problem is that I don't know how to insert this into S3D.
                  Can you give me a sample for T2.
                  Then i do a test print, when its not work i post my configs.
                  • oliofundefined
                    oliof
                    Add this to your GCode start code for mirror prints:
                    T2
                    And you should be done.
                    S3D does not need to know this is a mirror print. If you set the tool offsets correctly, the printer should do the right thing and just print in mirror mode.
                    It might be easier to do this if you set the origin to the middle of the print bed, so the X offsets for the tools are modified by (-(X axis width/4)) and (X axis width/4) for X and U. It could be helpful but is not necessary to have a printer profile with bed dimensions where X is halved and Y is full length (or limited to the length reachable by both print heads if one happens to be offset) to avoid slicing too large a model. Having the origin set to the center of this "virtual" printer with only the bed size changed should be enough to slice a model that ends up mirrored nicely.
                    This assumes both hotends run the same material(s) and can use the same cooling and temperature settings. But without that, mirror mode seems ... risky.
                    • jensus11undefined
                      jensus11
                      also it doesn't work. E0 print one thing on the left side from bed. E1 is heating and not more.
                      Can you check my config.g?
                      i don't know what it is.
                      Which file i should also upload?
                      config.g
                      • jensus11undefined
                        jensus11
                        I have looked the gcode an then i see that S3D after the T2 command a T0 write. I have delete the T0 and it is ok.
                        Now the printtools are starting from the correct position and the move looks great.
                        But the new problem is, when the tools are start to print goes the heater E0 and E1 off. The print are continues.
                        Why is that?
                        • oliofundefined
                          oliof
                          I get a "not found" on that config.g
                          It'd be best if you shared your tpre/roost/tfree macros too.
                          • jensus11undefined
                            jensus11
                            ok, here the other files.
                            tpre1.g tpre0.g tpost2.g tpost1.g tpost0.g tfree2.g tfree1.g tfree0.g
                              Can you upload your config.g again? It didn't work the first time.
                              • jensus11undefined
                                jensus11
                                please,
                                config.g
                                • jensus11undefined
                                  jensus11
                                  i know i have found the solution. S3D write on the false position the tool command.
                                  this is from S3D:Bildschirmfoto 2020-11-03 um 19.56.42.png
                                  and this is what i have change:
                                  what can I do to avoid changing every file?
