    straight lines are (no longer) straight
    535
    • spllgundefined
      spllg
      sorry for this new request for help ..
      we just have experienced that straight lines are (no longer) straight but kind of crooked in x- and in y-direction.
      we tested using cura 4.7.1 and slic3r 1.3.0
      is there a known solution for this issue?
      tia for any assistance.
      • Vetiundefined
        Veti
        this is most likely a mechanical issue.
        what kind of printer is it?
        spllgundefined 1 Reply Last reply Reply Quote 0
        • spllgundefined
          spllg @Veti
          @Veti it's a self made printer (blv mgn). what do you suggest to check/fix?
          • Vetiundefined
            Veti
            check belt tension
            and recheck that each corner is still 90 degrees
            • spllgundefined
              spllg
              thanks for your answer.
              we checked and did not find any issue.
              the strange thing is that that 2 lines (left and bottom) are fairly straight while the other 2 lines (right and top) are crooked. because it's a core xy printer this makes us think that the issue might be related to the direction of rotation of the steppers.
              have you got any further hints?
              • spllgundefined
                spllg
                we can see the head moving in x and y direction where it should not move in these directions.
                • Vetiundefined
                  Veti
                  remove the belt and see if everything moves without resistance.
                  • mrehorstdmdundefined
                    mrehorstdmd
                    Does the machine have steel core belts?
                    • spllgundefined
                      spllg @mrehorstdmd
                      @mrehorstdmd no, it's got fiberglass belts as.
                      • spllgundefined
                        spllg @Veti
                        @Veti when i last had removed the belts everything moved without resistance but i'll check when a find enough time and energy after my bread and butte job.
                        • JamesMundefined
                          JamesM
                          I just took apart my first blv printer because I was noticing the same thing and it turned out it was no longer square. I would check the frame by measuring on diagonals....front right to left rear and front left to right rear. See if they are identical. If not then it's time for a tear-down.
