Glue for the bed surface?
@oozeBot said in Glue for the bed surface?:
Rapid Tac
Thanks for the idea.... I got told that the M3 thingy can not be applied wet. For an unknown reason. I do not fully trust the source and you confirmed my scepticism now.
Btw: Amazon in Germany want me to pay 95,44€ for that "magic fluid". I guess that I will give the old traditional way a chance. Just some soap/window cleaner and water.
@Chriss Here is what I found when googling for a homemade formula. I'd try this over spending too much. I forget when I picked up this bottle of rapid tac as it's been years ago - and as you can see in the photo, it is going a looong way for our needs.
*alcohol,soap and water is all that I use and I go through a gallon every two weeks. I trierd a bottle of rapid Tac and other than smelling better,couldn't see a difference. When I bought the rapid tac,the guy at the sign supply place told me I was wasting my money,that the recipe I use now is just as good. I wanted to see for myself,and I did. I haven't wasted any money since.
One Gallon:
Fill gallon jug about 7/8 full. add 3 or 4 good squirts of sihwashing liquid soap. I use all kinds of brands,no one seems to be any better than the other. Add alcohol to fill rest of gallon. If you want it to smell like the expensive store-bought stuff,add some vanilla falvor.
Alternate,that I have used if you don't mind it being BLUE: (I got this from a sign guy with 40 years in the business)
3/4 gallon water,1/4 gallon windshield wiper solution. And the soap.
There are those who will say its not as good as the store bought stuff but I do amywhere from 2 to 5 signs and banners a DAY,every day,and mostly wet. I have NEVER had a proble with it. I am usually able to remove the tape after 2 minutes or less on glossy surfaces, about 5 minutes on banners that are not glossy.
Never a bubble,never a wrinkle. And I can tell you taht from having to REMOVE a few letters here and there(people do chaneg their minds)...the stuff does NOT affect the bond of the vinyl to the substrate.
Let me say one thing..I have a background in chemistry and there is NO magic ingredient in Rapid Tac or any other that makes it special. They like to say there is. But there isn't.*
@Chriss said in Glue for the bed surface?:
I understand that the most commercial suppliers use that M3 4xx "tape" which is stable at higher temperatures. I had a lot of problem to apply it manually to surfaces.
What type of problems? I never had a problem applying the M3 4xx sheets to the bed, the problem I had is that after a while the glue fails at some points and when I use it to attach the heater to the bed in places where glue fails the heater chars up and dies. For the surface plate I never had a problem applying 4xx but I attach the surface plate to the glass and then I add glass on top of aluminium bed. The contact aluminium-glass I make from silicone heatsink pads, they are sticki enough to hold the glass tight, thermally conductive enough to allow glass to heat up, and when required you can remove the glass without too much issues. The print surface I attach to the glass.
The issue I had with all M3 adhesives when printing "nasty" plastic is that M3 adhesives stay "soft" and when you have many tens of kilograms pulling the few square millimeters due to warping forces the adhesive tends to allow print surface to disconnect from the glass and break, bend, crumble...
This was solved with the latest version of printbite (actually probably some times before but I had some very old versions and recently got new ones for new printers so dunno at which point Jason changed the adhesive) where the adhesive used is some industrial thing that after curing (you stick the surface to glass, you heat your bed to 120C, you put a dump towel on your bed, keep it at 120C for 60 minutes and then let it cool, then do it again) the "glue" turns into "stone" ... bad side of it - you won't be removing that surface from the glass ever again, good side - it works awesome ... no clue what that industrial glue actually is but if you contact Jason from Flex3Drive I'm sure he'll share the info, he's pretty straight forward with that type of details.
Whatever he's using works awesome for sure till 150C, dunno if it goes over that I have not tested, but 150C survives without a problem
